A Raven from Scratch
I have noticed that and I've wondered about it. I really enjoy building these and I'm hoping that at least some of the viewers are reading with intent to start a build of their own. If that is the case, they are, hopefully, aware that the members of this forum are extremely willing and able to help (and don't get terribly offended when we won't always agree with, or listen to, the advice given).
Regarding that, I've been re-reading Brian's explanation in post #140.- I'm wondering if I should be building the seats differently and I'm tempted to make a half dozen each way and break them except for one little issue: A fair test would include webbing the seats completely and that takes a few hours the way that I do it. (I guess I could wrap & staple webbing and even build them entirely from Aspen or Pine if the aim was to merely test the joint failure...)
Oh well, that's (maybe) for another day...
I rounded the edges of the seat frame by wrapping sandpaper around them and using it like a shoe shine rag. My understanding is that a radius is stronger than a sharp edge and, while I don't understand the physics of that (in all honesty, I've never bothered to try), I can just go along with the idea as it's more comfortable anyway.
After that, I put small pencil marks every inch from center on all 4 pieces and varnished the frame. When dry, I started wrapping and weaving the current seat using 5/32 inch paracord (I found a roll of dark red and thought it would complement the colors of the Larch & Sassafras really well). Doing it this way eliminates drilling the seat frame but, as mentioned above, it takes hours.
It's also hard on the hands pulling that skinny cord tight but it does make for an attractive (IMO) and comfy seat.
Now: not to discourage any would-be builders but mistakes are made. I believe that all can be remedied but some take more work than others and, in keeping with my "learn from my mistakes" demeanor, I'll share my latest.
Over the course of the past 2 days, I've got a total of about 3 hours weaving this seat. I had a 100 foot roll of paracord and I didn't use anywhere near that on my Freedom seat. This one, however, has almost 3 times the seating area so, much to my dismay, 100 feet was insufficient the way that I'm webbing it.
My options, as I see them: find more red paracord and attempt to hide the knot on the bottom of the web where I won't sit on it (I think I can hide it under the spreader bar) or take it all apart, remark the seat frame with 1 1/4 or 1 1/2 inch spacing and see if 100 feet is sufficient to get coverage with that spacing (pretty sure that it will be).
As mistakes go, this one is relatively minor and the corrective action required is pretty straight forward: "You didn't do it right so try again". Taking it apart will probably take a couple of hours so I'll be searching for red paracord during my travels tomorrow.
RE: testing the seats
If your goal was to test the joint, I don't think you would need to do the webbing, I agree that for a full blown comparison, that would be the ideal ... but the thought here was that the joint construction itself causes a weakness. What isn't clear is whether that weakness is enough to cause failures or if it impacts total strength in any meaning way.
I suspect that could be determined just using a constructed joint, i.e. just one half the seat ... the long member, with 2 completed dado joints. That would simplify the test and reduce the work required to your scratch your curiosity ( and mine/ours)
I may do some testing this winter. I'm hoping to build one more solo (Alan sent me his Bloodvein II plans) and I suppose, having recently become a grandfather, I should put together a tandem at some point. I'm thinking 4 or 5 should be old enough to walk portage trails so I've got a little time.
I found a 50 foot roll of 5/32 red paracord today (paid entirely too much for it but it was there). I had to tie the knot about a half dozen times before I got it to hide beneath the spreader bar after it was stretched tight.
I finished weaving the rest, supported both ends on blocks & parked my posterior upon it. It held me & seemed comfy so I threw it in the boat. I'm very pleased with the color and even more happy that I didn't have to take it apart and start over.
I've got (as usual) too many irons in the fire but I'm thinking I may have this one on the water by Monday night. (I guess I'd better configure some roof rack options on the car soon)
Having met you, and not that I purposely noticed, but I can accurately say that your posterior is in no way adequately large enough to fill in that extremely generous seat. You could have saved paracord cash by moving the side rails in to a point that was more reflective of the bottom line, so to speak.
The seat is overly wide as an experiment or sorts. I'm figuring that, as I slide to the rails, the boat will automatically heel. I probably don't lean the hull enough on turns so the seat may force me to. 🤷‍♂️
If I were to build a seat for you, I could put one of the spreaders in the center and save real cash by only webbing one side. (It really IS excessive at almost 250 square inches of webbing)
...but I'm thinking I may have this one on the water by Monday night.
Wow.
Reality check: it's WAY past "Monday night" & I'm still not done. I have, however, been making some progress...
Since last check-in, I've glued & screwed the inner gunwales
(mixed up a small batch of epoxy, thickened it with sawdust [from the dreaded sanding of the inside], buttered the inner gunwales with it, & screwed them into place [after having countersunk some holes for the screws]. It is my opinion that a mechanical fastener plus the epoxy has superior strength to either individually and, since my boats are [hopefully] destined to transport me in wilderness settings, I want the most strength possible.DSCN1863.JPG
After that, I fitted 2 grab handles for the bow & stern plus one center thwart (plans call for another behind the seat but, since I'm not hanging the seat from the gunwales, I considered this one optional and went with just one 28 inches forward of the seat... the distance that I've determined that I need so that I can tie the paddles between seat & thwart and eliminate the need for a portage yoke).
I used the oscillating sander to match the compound angle of the inner gunwale (and moved forward or rearward if I missed) until I felt that I had tight fits, then put pencil marks on the support structures and the gunwales. These served to locate the handles as well as to indicate to exact placement and I then eyeballed and countersunk a 5/16" hole where I thought the screw would be centered in these supports and the center thwart. I then drilled through the hull and into the handles/thwart with an 1/8 inch drill.
The inner gunwales were still proud of the hull at this point so they needed trimmed flush. I've refined my jig a little since the 1st build and I am now using a 1/2" x 3" x 48" piece of aluminum bar stock that has been drilled for the trim router and tapped so the base of the router can be attached to it without clamps and the screws remain flush.
This set-up allows me to maintain contact with both sides of the hull so the router doesn't rock and the bearing on the router bit ensures that I can trim the gunwale right up to the hull. (note: I put 2 thicknesses of heat shrink tubing on the bearing [visible in the above picture] in hopes that I could trim a few thousands proud of the hull. The shrink tubing lasted about 5 minutes... oh well...)
I watched the grain carefully this time so as to not catch & tear it out and I found that the Sassafras is far more forgiving than the Cherry was. I had one place where I caught the grain & it started to tear out but it was very minor.
I used the jigged trim router to cut the inner gunwales flush(ish) with the hull then used the long board sander to smooth the cuts, true them to the exterior of the hull and rough up the hull for good adhesion. I then used the 5/16 inch bit to cut slight recesses into the thwarts & inner gunwales figuring the thickened epoxy would fill these voids and provide a little more strength.
I then fit the outer gunwales, cutting them as I had the strips; using the hull as a guide for the shorter side and allowing the other side to run past
At that point, I mixed a double batch of epoxy (knowing that I usually have 45 minutes to work with it), mixed some sawdust in to thicken it, buttered the ends of the grab handles & thwart (and the inner gunwale where they'd make contact) and secured them with 1 3/4 inch exterior deck screws.
At this point, I might need to mention that working times for epoxy are far different (at least in my boat shop) in the winter than they are in the summer. The Raka epoxy has proven to be very forgiving in the past and I figured that a double batch would probably be sufficient for support structures AND outer gunwales so I mixed up a lot. I found out that it was already starting to kick by the time I secured the grab handles and thwart so I wasted quite a bit of epoxy.
Next, I mixed up a 1/2 batch but, rather carelessly, threw a handful of sawdust in and wound up way too thick, thereby wasting another (small) batch of epoxy.
Finally, I got my head on straight and started mixing single batches and adding sawdust slowly until the mixture was somewhere between honey & creamy peanut butter. I then buttered the outer gunwales using the mixing stick like a butter knife and leaving the epoxy tapered slightly so that it was heaped up a bit in the middle. This ensured that I had a good squeeze out when the outer gunwales were clamped into place
I then took my (gloved) finger along the bottom of the gunwale to remove most of the squeeze-out,
waited a couple of hours for the first side to set up (I need to buy more clamps lol) and repeated the process for the other side.
(yes, in case you're curious; the clamps add enough weight that they pull the hull downward within the cradle)
And that's where I am tonite. I should be able to get over tomorrow and scrape away the squeezed-out epoxy, trim the over-run outer gunwale pieces and I might even get the seat drilled. Still hoping to paddle it over the weekend but we'll see...
Went back over this afternoon, removed all of the clamps & scraped the excess epoxy where it squeezed out.
I then used the pull saw to cut off the outer gunwales where they had run past the ends (Personally, I think it looks better when the outer gunwales don't end before the boat does)
I don't, however, like the sharp points that threaten to impale me when wading rapids (worried way to much about that when I left the points sharp for my Steel River trip) so I blunted the end (arbitrarily) with the pull saw
and used the rasp and then sandpaper to smooth & round the ends. I also sanded off the sharp edges of the gunwales, thwart, etc. removing my pencil marks (makes it harder to see where I missed my marks) and smoothing out the scarf joints.
The result is an aesthetically pleasing (to me), gunwale that provides adequate rigidity without excessive weight and is unlikely to skewer me it I slip while wading a rapid and fall upon it.
Satisfied with that, I removed the seat and used the orbital sander and some 80 grit to scuff the inside for spar varnish. That went well until I caught an edge while roughing up the stern float tank and the sander quickly cut through the glass (remember, there are no fill coats inside; just a wet-out)
The area wasn't large and a strip canoe will float without float tanks so I was tempted to pretend that I didn't see it but, in the end, I decided that, any canoe with float tanks should actually have the extra floatation of those tanks and I decided to cut a small strip of cloth (4 oz, I think, but it was a scrap so who really knows?), mixed up a half batch of epoxy and wetted out the patch with a paint brush (the one I intended to use for the spar varnish, actually... I think I've got more at home. Hope so as most local stores are closed for the 4th tomorrow...)
After one final sanding on the trim, I swept up the sanding dust and I think I'm ready to spar varnish the gunwales & inside tomorrow (unless someone can definitively say that I should allow that float tank patch for cure a few days). The outside (IMO) can wait until I get the tie-dyed Merlin done as I can do them both outside at the same time and I doubt that a couple of paddles will destroy the Raven in the meantime.
Time to wrap this up (I've done a little better at working on it than I've done at reporting progress)
I don't recall if I waited a couple of days or not (I think I got distracted so it's likely) but I got 3 coats of spar varnish in the inside and then tackled the seat installation.
I wanted this seat removeable so I'd previously epoxied tabs to the hull. I clamped the seat into position so that all of the holes would line up and drilled through the seat and into the tabs using a long 3/16 inch drill.
I used the long drill to get as close to the gunwales as possible but, due to the tumblehome, the holes were still angled. I slipped brass bolts through the holes as I drilled them but kept 2 clamps on at all times to prevent misalignment.
I pretty much eyeballed the angle and was very pleased that I wound up nicely centered on the mounting tabs.
(note: due to the tumblehome, the hole is going deeper into the tab [closer to the hull] as it goes down)
The next order of business was to install wood anchors so I enlarged the holes to 9/32, checked the length of the bolts vs the thickness of the seat rail
and threaded the anchors in using a hex head socket until I figured that they were about 1/2 was through
The seat was then mounted using cupped washers to allow solid contact across the top rail despite the angled holes and the bolts were tightened as much as I thought I dared (how's that for a torque spec, huh?)
The seat seems solidly mounted but doesn't have that "rock solid" feel that I got from epoxying the seat directly to the hull as I did last time. Still, it removed any flex from the hull at that location and I can lift the boat by the seat so I think it will hold. I am glad, however, that I've got time for some extended paddling around here before taking it on a 2 week solo in the boreal forest.
That paddling started today as I went to the shop between rain showers, slid the Raven out the door and lowered it to the ground.
(that one's for you @Roybrew ... I know you liked that shot in the last build)
Once outside, I borrowed my buddy's bathroom scale, carried it out onto the sidewalk and prepared for the moment of truth... We set the over/under at 55 lbs, weighed me and then me with the boat... (any speculation?)
My Aspen / Cherry Freedom Solo came in at (IIRC) 45 lbs and I figured that, with the heavier Tamarac and the higher volume of the hull, I would be pleased if I'd only added 10 lbs to that weight. I was absolutely ecstatic when the Raven tipped the scales at 50.2 lbs (22.8 kg)!
It was then portaged for the first time by throwing it over my shoulder and taking it to the bottom of the driveway where my buddy has a small pond
I paddled though the raindrops and I am extremely pleased with this hull
Initial impressions are that it was easy to get up to cruising speed (as best I could in the small pond), tracked well with minimal correction yet turned easily and I expect it to be far more maneuverable than my Freedom.
Initial stability was worse than the Freedom and it seems like a very lively hull but, then again, all that was in it was my 210lb carcass so I expect it to settle down nicely with 60lbs or so of gear in front of that thwart. I'll probably take it to the Conemaugh River and lean it over until it dumps just to know where the tipping point is.
Oh... speaking of leaning... the widely curved seat works perfectly to heel the boat. Sliding toward either gunwale will automatically result in the hull heeling to that side at which point you can turn it on a dime. (I'm not tight to the gunwale on the next pic as I'd neglected to take my phone out of my pocket & didn't want to risk a swim)
I'm really looking forward to tossing a tripping load into this boat and paddling the heck out of it. The Sassafras should darken as it ages and the colors are outstanding. Given the splintering, I'm not positive that I'd recommend Tamarac but I'm not sorry I tried it. I've carried the 45 lb Freedom on some long portages and, at only 5 lbs heavier, this will be my choice for the next trip unless it becomes extremely unruly in moving water.
Fifty pounds is great for that canoe. People who haven't seen a Raven before are often surprised by how big it is. I've never found it tender, pretty much the opposite. It was designed by J.Winters as a down river tripper, it does well in river travel. Because of the asymmetrical hull and your seat placement, you will want to load your gear forward to try for a balanced water line in order to achieve top manoeuvring. I hope you like it once you take it on a trip!
Nice job on the gunnel fitting. Always a bit tricky for me.
It's a bit nerve-wracking for me too but I keep cutting until it turns out OK. I'll try to get a couple of close-up pictures of "oops" areas that I had to play with. (horses after work tonight so it'll probably be Thursday before I get back to the shop)
I usually tell people that you don't have to be a wood worker (I'm not) if you're willing to destroy alot of wood and keep messing with it until it looks ok (I am).
I already like it better than my Freedom as it handles better and has more freeboard (which will be comforting on lakes like Ara). I need to tweak the portage system on the Fusion and I'll haul it out to the river and give it a proper test. (Debating sending it down a set of class 3s nearby that my son & I portaged around last trip but that might be a little extreme until I get used to it a bit more)
The tenderness might have been due to lack of sea legs also... that's (I think) my first paddle since returning from Ontario a year ago. (gotta fix that too...)
Stopped by the shop after horses and took a few pics. I add this for anyone considering wood gunwales but finds fitting them intimidating:
I use 2 piece gunwales because the thought of getting the compound angle correct in the first try would scare the bejesus outta me. For 16 foot(ish) boats, I've been machining the gunwale stock from 10 foot boards. This allows me several attempts at getting a nice fit at the stems and then I use a miter box to cut the gunwales near the middle of the boat. For strength reasons, I make sure that I overlap inners & outers.
I have usually been successful at getting the 45s to fit nicely by starting them a bit long and gradually trimming to a good fit (the miter box gives a very consistent angle so there's little need to cut both pieces at once).
On this boat, however, I wound up a little short so I took a small scrap piece from the other side and spliced it in.
It's also important to remember that thickened epoxy is your friend and you can fill gaps with it if you cut your 45° angle a little wonky
It can also fill gaps if you screw up a little on the stem cuts
Don't get me wrong, I love the way the gunwales look on my hulls and I don't point out the flaws to minimize any of it.
I do it in the hopes that anyone considering building (or, in this case, replacing gunwales with wood as a DIY project) understands that it doesn't have to be perfect. I highly doubt that many would notice the defects that I point out in this post if they see the canoe in person (note the close-up pics) and I might recut the entire gunwale if I were trying to sell this boat for a ridiculously high price.
The boats that I build, however, are pretty utilitarian. That doesn't mean they can't be pretty or that I can't try to make them pretty but they don't have to be perfect. They're going to float for dang sure (silly profanity filter)... If you're considering building, channel your inner 90s Nike ad campaign and "Just Do It".
Since gunnel joints are end grain joints, I would suggest those 45 joints should be quite a bit longer ... just thinking out loud.
I like using epoxy anywhere I use a saw cut, because of what you said, it has void filling capabilities and keeps the joint strength even with a few defects.
The gunnels are looking good.
Very nice job and thank you for making the effort and taking the time (lots!) to post your build. I like that after asking for advise you have the confidence to find your own starting point and then share how things work out. Thinking different and being willing to try new ideas is what pushes knowledge and practice forward. Well done!
...Because of the asymmetrical hull and your seat placement, you will want to load your gear forward to try for a balanced water line in order to achieve top manoeuvring. I hope you like it once you take it on a trip!
I finally wet the hull properly on Sunday (TR pending). Water levels are unbelievably low here so I headed to Pittsburgh & paddled a few miles on the Allegheny River (in addition to the lock & dam system, it has water storage dams upstream to maintain adequate water depth for commercial barge traffic).
It was an all flatwater trip but I took my pack with base weight gear to simulate tripping load and I am really liking this boat!
I got up pretty close to a dam so I could catch some moving water and it seems to move effortlessly up, down & across the current. It handled wakes from motorboats, responded well to paddle inputs and received no end of compliments on its appearance.
I'm really looking forward to tossing it on a train next summer.
