• 2026-29 Fund Drive needs only 6 MORE DONATIONS to reach target. Read the Featured Thread for details. Please donate!!!
Light Weight Prospector 16 stripper build
I'm enjoying following along, and appreciate your posts. I'm almost done putting strips on my second canoe, but this is acting as a great refresher since some of the finer details have been lost on me since 7 years ago.
I'm even picking up some new tips. Laying the inside fiberglass in 3 pieces has me intrigued and seems like it will help get into the narrow stems easier & with better precision than one continuous piece. I remember that step proving difficult in my last build. It ended up looking sloppy in those areas so I just covered them up with float chambers. How do you feel the 3 piece method went?
I think the 3 piece method is a fantastic idea. If executed properly, I think it can make the install easier. It can definitely save material, and it can even save material while granting you the opportunity to have structural overlaps. Although my execution was clumsy for reasons I described.
Here is a great description and execution of that method:
If you carry on through that build thread, there’s a great discussion about feathering and hiding overlaps. At the time of my wetout, I think I vaguely understood that you can bury an over lap and make it almost invisible without having to come back and massage it. I intended to make the best of it, but things got a little bit out of hand and I forgot which order I wanted to lay things down as I was going through the whole process.
When I lay interior glass again, my plan will be to pre-wet the bias strip stem area first, give it a moment not to really tack, but enough to hold my bias strip in place. Then cut a hard cardboard stem temple that I can fold my bias strip onto such that I can hold the strip on it, then push the assemble into place without fuzzing up the feathered strands, then lean/push it to once side to get it on the wetted surface on the port, then lean/push to the opposite to adhere the starboard. I’ll also be making sure that my bias strip extends back down the hull and the cheeks of the bow or stem at least to an area that can fit my fingers, then let it come back a little bit more.
I would intend to complete the bow and the stern stems and let them set up (epoxy dependent I think). The goal would be to then have your bias strip already installed, no need to stick your sausages into that tiny little gap and the cheeks of your interior glass sheet can marry into that easily and in an area where you can reach with tools during installation and after. You can clean up and sand if you need to after the fact without being a watchmaker, and arguably, most importantly for me, if it all goes sideways, and she looks like a bag of beans… Hopefully most of my ham fisting will be hidden in the shadows or under the decks.
I will also personally try to make sure that I am making the wet out exercise as easy on me as possible. This means when the first sheet goes on (I’ll be starting at the stern) it overlaps your bias stem strip and will be under the middle sheet, middle sheet overlaps the stern and lands under the bow sheet. then when it is bow time, you can start by fussing the cheeks into place and work your way back to overlap the middle sheet.
At the overlap, the sheet touching your hull just completely disappears, and the overlapping middle sheet can be eyeballed to land somewhere under your Stern seat. Then at the bow with the bow sheet overlapping the middle sheet, that potentially visible overlap can be underneath your bow seat. I things stretch or move an inch or 4 during wetout, your seat is probably going to cover it.
At least on my light build, anything I could do to make sure no more epoxy had to come back to the boat was very important. I think (thought) I would apply this bias strip overlap schedule on the exterior of a boat too. Having said that, there’s a slight chance that I will (or maybe I just did) completely forget to exploit this technique…. Evidently this build thread should be for entertainment purposes only if I’m the one offering it.
For some reason, I thought I could illustrate it…see attached.
Here’s another Cruiser build thread that very much worth checking out.
Both the thread above and the one I mentioned earlier are more comprehensive and probably a lot more coherent than what I’m posting.
