• Happy Invention of Scotch Tape (1930)! 🏴󠁧󠁢󠁳󠁣󠁴󠁿🧻3️⃣🇲
Keel guards
New Hampshire
I have an Old Town canoe made of Royalex. I want to put a keel guard on the bow and stern. What would you use for the guard?
For canoes, these protective layers along the stems and part of the keel are called "skid plates". We have many threads here discussing whether and when skid plates are needed—people disagree—and how to make and install them with many photos. Use the site's search function for the term "skid plates" and check the box to search titles only.
Buying your own materials and installing yourself is much less expensive than buying a kit. As to what material to use, my memory of the consensus here is that Kevlar felt is too bulky and ugly, that Dynel is probably the most durable material to use, and that S-glass is probably in second place.
I use Dynel fabric with West Systems G/flex epoxy.
You might post a picture(s) of the ends in their current state, application might change slightly if they are heavily worn vs just a few light scrapes.
The required tools are very simple and cheap, maybe most important is a good pair of scissors to cut the fabric and a roller of some sort to ensure you wet out the fabric fully without over using the epoxy.
Another good thing to get in addition to the fabric would be a piece of peel ply.
If you read some of the posts mentioned by @Glenn MacGrady you'll find the lots of details of what is needed and tips on little thinks that will make the final result look good and last a long time. My boats are beat up, I do a lot of messy patch jobs but even I am able to produce a reasonably nice skid plate.
Can you link any videos/threads shopwing the Dynel/G/flex epoxy mothod? I can only find kevlar video. Is it the same Method as Kevlar, just the different materials?
