• Happy National Chocolate Ice Cream Day! 🍫🍦
Newby. Help with tandem selection, please.
Hello! Been lurking for a while and decided to join. New to canoeing but not to boats. 25+ years in jon boats, poling skiffs, a bay boat and I recently built two small composite skiffs. Also recently purchased an Old Town Stillwater to learn on before I drop big money on a nice canoe. (Not the ideal tandem, I know, but the price was right and it’s place to start.)
Looking for a lightweight tandem to be used solo 90% of the time. 3-4hr fishing trips. Mostly within a mile of put in, some trips could be 3-4 miles round trip? Mainly small lakes, coastal SC creeks and FL mangroves. Since I plan to use this into my 60’s and 70’s (hopefully 80’s?) and will need to hoist it up onto roof racks by myself, light weight is imperative. Stability more important than speed.
Considering: Wenonah Heron in either Kevlar or Intek, Northstar Opal in BlackLite k w/carbon fiber gunnels, Swift 15’ Prosector in carbon fusion w/carbon/kevlar gunnels. After researching, these seems to be the best options from low $ to higher end. The Swift would be my first choice but no easy way to look at / paddle one living in SC.
Even considering a 14’ solo Swift Prospector to really keep it light. I understand the trade off in stability if I go solo canoe.
Thoughts / considerations on the good, bad and ugly of these hulls and manufacturers?
Thx
Welcome Mr. Giffman,
If you have built a couple of composite skiffs, you clearly have the requisite skills, experience and suitable place to work.
Don't waste $3,000 on a fancy canoe, spend waaaay less and build exactly what you want.
Just my admittedly biased opinion.
The thought crossed my mind but the idea of starting another boat build makes me want to vomit. lol. 4+ yrs of dirty work and I’m officially burned out. Bucket list item achieved and glad I did it. I’ve sold the boats and the proceeds will pay for a Mac daddy canoe of my choice.
Take a look at a Northstar Polaris with a center seat. The Polaris is a narrow tandem and can be ordered with a center seat. I ordered one this way in blacklite with a footbar for the center seat. After removing the bow and stern seats the canoe weighs 37 pounds. Very stable sitting in the center seat and fast. I added a webbing carry yoke for lifting and carrying. I’m 78 and have no difficulty loading this canoe on my own.
A center seat is the best position for a serious fishing canoe, IME. Other than that, of the canoes you mentioned I would prefer the Opal over the Heron. I think the 16" stern on the Heron is too low when paddled backwards from the bow seat, and I like the look of the stems on the Opal better. The 15' Swift looks very similar to the Opal and has a very traditional look that I like.
I've paddled the Swift P14 and P15. Overall I think the P14 is a great choice since it's an exceptionally stable solo. Why compromise for 90% of your paddling?
That said, if you want a tandem I'd be curious to know what you like and dislike about the Stillwater. The P15 is VERY stable...and in my view a little sluggish. If you will always be on calm water that may not be a problem but the P14 will cover distance more easily and do it in less than perfect weather.
I also have a Northstar Polaris with center seat. Polaris is a bit narrower than the vast majority of tandems and that helps it paddle quite nicely solo. It's still very stable. I like the looks of that Opal too. If you're near SW MI you're welcome to try my Polaris.
Greetings, @Giffman !
If you go with a solo, I think the Swift P14 is a great canoe to fish from and for general use - depending on if you're in the weight/size range it's suitable for. My ~155 lbs found it to be a very easy and comfortable craft, and I would guess that I'm on the lighter end of its ideal spectrum.
If you need to be able to go tandem, I'll defer to the Polaris suggestions. But if you want to get some idea if that will work for you as a solo without risking a lot of cash, you could look for a used kevlar version of some older models with similar dimensions. That list would include the Bell Northstar, Wenonah Escapade, Ranger Otter, and Mad River Malecite. Some of these can be found with a center solo seat, and of course you can always add one yourself.
The Opal and Swift models appear to be symmetrical, making for easy soloing from the bow (reverse); no changes necessary.
All nice looking canoes.
I definitely understand the 90% rule, was thinking that if I get the right tandem, I can just paddle from the bow side when it’s just me and not give up much. That said, I’m warming to the idea of going with a solo and using the Stillwater if/when I need a tandem. The more I read, the Heron is fading. Opal or P15 if tandem, P14, 15 Kewaydin or maybe NS Trillium as solo’s.
Rocker- I understand, or think I do. More rocker equals more maneuverable but doesn’t track as straight as a hull with no rocker. Zero rocker being the most stable. That said, for my purposes (all scenario performance) I’m thinking something like the P14 with 1’ rocker bow and stern may be a better option than something with 2-2.5” of rocker?
I’m 5’ 9” 165. Another consideration is I’m limited on storage so I’d prefer something in the 14-15’ range.
Just a few comments...
I agree that you don't need or want a lot of rocker for your planned use. Although canoe specs are not standardized and can be misleading I think one metric worth looking at is waterline width. I'm very familiar with Keewaydin 15 (I own one) and Trillium. Waterline width on P14 is 28 inches...on the high side for a solo and no wonder it's known for stability. Keewaydin 15 is 27 inches and Trillium is 25 or 25.5. P14 is MUCH more stable than Trillium. P14 is noticeably more stable than Kee15 although Kee15 is a stable friendly boat. I'm guessing that you plan to sit (not kneel) when paddling and fishing; sitting is less stable than kneeling. All that said, I think the P14 is a great choice for your planned use since it has a lot of stability for a solo but will still be easier to paddle (and probably more fun to maneuver) than a tandem.
It would be great if you could try a few boats to help focus your preferences but if you can't I'd recommend that you take your Stillwater out a few times and see how you like it solo...maybe go to the far end of the lake on a day that isn't dead calm. If it works pretty well and you're happy then you'd love a P15. The waterline width of your Stillwater is 37 inches and that's high. Many sporty tandems are 32 inches and Polaris is 31. An inch matters. P15 is in-between so should be super stable but still be considerably easier to paddle than Stillwater.
Good info. I hope to get the Stillwater in the lake this weekend to try it out. Only had it in the pool for a few minutes to play around on it. Couldn’t really tell much other than paddling solo from the stern seat its waaaay outta trim. Didn’t even realize at the time paddling from the bow seat was an option when going solo. Will definitely be paddling from the bow. I’ll use it a few times and report back.
Thx
Stillwater didn’t paddle too bad, but at this point I don’t know what I don’t know. I could easily stand up and fish out of it. I stood up several times and moved around some. No problems at all. What was eye opening was how hard it is to load this by myself on the roof rack. Although a bit unwieldy, even at 50# it’s very easy to get under the yoke and pressing it over my head was no problem. But at 42” wide at the gunnels I can just barely clear the rack (4Runner) and I’m in a very awkward position. Thought better of it and decided to just have my wife help me. Stupid easy with two. This exercise confirms I definitely want a light weight solo. A P14 or Phoenix that would 14-16” narrower at the gunnels would allow me to lift it 4-6” higher. Knock off 20# plus with Kevlar fusion or black lite layups and I’ll be ready to go. Right now I’m fairly certain I’ll order a P14 kevlar fusion w/carbon kevlar gunnels instead of the Phoenix in black lite or BL HD. I’d like to test paddle the P14, but that’s just not an option so I’ll probably rely on the brain trust here. …But I may go paddle a phoenix a couple of hours from me and if that feels fine, the P14 should be even better.
Sounds like a great plan!
