• Happy Red Planet Day! 🚀🛰️
1982 Mohawk Intrepid - To Repair or To Not Repair
Another new guy to the forum looking for guidance on whether or not I should repair an older Mohawk canoe.
I already have a NorthStar Northwind Solo canoe so I am nicely equipped for BWCA/Quetico and Wabakimi (hopefully) tripping.
I have been looking for a 16ft tandem that I can use and abuse, solo or with a guest. I came across a damaged Mohawk Intrepid 16 on FB marketplace that I purchased for $60. Apparently, a tree fell on the canoe damaging the midpoint of the hull. One side of the hull has numerous wrinkles but no cracks that I can see. The other side of the canoe has a few wrinkles with a crack revealing the foam center. I am planning to use 4 oz fiberglass on the outside of the hull and 6 oz on the inside of hull to fix the crack. Wrinkles will be sanded down and reinforced with glass inside and out on both sides of the canoe. West Systems Gflex will be used in the repair. Once done the outside of the canoe will be repainted.
On top of the glass repair I will also replace the gunwales and add a new yoke (maybe, this canoe is Heavy).
I am still contemplating whether or not this canoe is worth the effort to repair. I am not expecting to use this canoe in Class 3 rapids again in its life as it will be used in local lakes and rivers in the UP of Michigan and maybe a trip or two.
Is this worth repairing? Cost wise probably no, for nostalgia purposes, yes.
Is the repair approach appropriate for this old royalex canoe?
Hi Mike-welcome to the site.
I have repaired canoes in much worse condition. Your plan seems reasonable as far as durability.
Only you know if it is worth your time. You will never get a significant amount selling the hull after it’s new again, but it may be worth it to learn new skills and the enjoyment of the project if you’re into that kind of thing.
Please take some photos and share if you decide to fix it up. Feel free to ask any questions if you get stuck.
Good luck!
Bob
This is a royalex hull. The outer-red- layer is vinyl. Epoxy won't adhere to the vinyl. The ABS layer and the ABS foam layer will supposedly work with epoxy resin. I would sand it with no finer than 80 grit so there is some"tooth" to the surface to aid the bond. Get all the vinyl off on the areas you wish to use epoxy for sure.
I would skip painting it. but if you must there are some things to consider. Again the vinyl... There are specialty paints for vinyl. Most paints will not adhere for very longto vinyl, especially if it is flexible. Then the epoxy repair. Make sure the paint you use on the vinyl will work on the repaired areas. Two different paints might be needed.
I have never tried to remove the entire vinyl layer from a canoe, but it might be possible. You would get a much better paint job over the ABS layer. It might lighten up the boat a bit.
Personally, I would make the repairs and beat it around a bit before putting more effort into it. A royalex boat of that vintage is likely to be pretty brittle no matter how well it was kept.
I have 7 Royalex boats, all except one has had patches and or skid plates installed using epoxy over the outer layer of vinyl, the skids on my Explorer were installed over 30 years ago and are still firmly attached, on other boats I have patches that have been holding firm for 20+ years.
Thanks for all of the info. The prior owner had painted the canoe using a primer and a shade of red. As I sand with the 120 grit the red vinyl layer underneath the paint is getting exposed and in numerous areas I think I am down to the ABS layer. It seems that I could probably sand most of the vinyl off of the bottom while the sides may be a challenge. The vinyl on the sides could probably also be removed with 80 grit. Rust-Oleum marine Topside paint after a layer of Rust-Oleum topside primer will be used to paint the canoe, preferably over the entire canoe if possible.
I will use 80 grit around the repair areas prior to fiberglass work and over the remaining vinyl layer.
New fiberglass will be installed on the inside and outside of the canoe where it was damaged by the tree that fell on the canoe. To do this I will have to remove the obvious vinyl layer around the damaged area on the inside of the canoe. Do I feather the GFlex from the new fiberglass over the edge of vinyl layer about 2 inches?
Where is the best place to find replacement gunwales? I am leaning towards vinyl gunwales, no wood.
I will post pics throughout the process....
+1 on not removing the vinyl. I've never had a problem with epoxy or paint sticking to the vinyl skin.
How bad are the gunwales? Unless they're actually broken or so bent that they change the shape of the hull below the top of the chines, I would just leave them be and paddle it.
Unfortunately, the gunwales are cracked in numerous places and flesh wounds will be had when paddling. Sanding was limited to the removal of the three paint layers the previous owner put on the boat. The outline of the Mohawk label appeared after the third layer was sanded off. There appears to be a thin layer of vinyl remaining on the sides of the canoe, patchy areas of vinyl remain on the bottom. I think the previous owner had a lot of fun on this canoe.
I am moving forward with fiberglass patching with GFlex inside and out this weekend, perhaps painting the following weekend. I think paint is needed due to there being areas where the ABS is showing. Planning to use red tinted base coat followed by Oxblood red topside paint.
Gunwales must be ordered or manufactured. There is a local hardwood supplier in my town where I can get some nice Ash from for the gunwales. Cut the strips to size for each side and fasten them together with screws. I am concerned about wood contracting in the winter and causing stress cracks on the canoe. It will be stored in an unheated area, covered, but it will get COLD! I think this is why the aluminum/vinyl gunwales will be a better option. A road trip to Minnesota is likely in my future to pick up new gunwales.
The canoe will end up being a useful recreational canoe that I can use, abuse, and have fun with for many years to come, regardless of how it looks in the end. Already thinking of a 10 hour river trip that will include some outstanding Brook trout fishing.
Hi Mike and a hearty welcome to the site.
The guys on this site are like having a platoon of engineers at your disposal with beaucoup knowledge. I also am starting a Rolalex project and looking to repatch a large bow boo-boo. While somewhat new to this hobby, I do have one piece of advice if you choose the ash gunnels. I doubt you will find 16-17 ft long single pieces for the gunnels thus they will have to be spliced. I spliced mine amidships and neither held as that's where the greatest stress/bend is located. Thus, a better option appears to be to have two splices, each about a quarter of the way from the ends. You put an 8 footer clamped in the middle with a splice on each end and then clamp from the middle out. Love to hear what the Rear Guard thinks of this ( Gamma 1214).
Lots of people here have far more experience than I have with repairs but I'm not sure wood is the right choice for this hull. Wood gunwales on a Royalex hull need loosened & tightened with the seasons or cold cracks will develop. If the boat is to be treated with little/no maintenance, vinyl or aluminum may be the more trouble-free option. Besides, road trips are fun.
As for the splices: I'm unsure why Bill's broke. The splice itself should be stronger than the surrounding wood if the splice is sufficiently long & is glued / epoxied & allowed to cure. Mine have always been simple 45s but I glue & screw them in 2 pieces while overlapping the splices on inner & outer.
Not sure how I missed the OP but welcome to the site Mike. Great to see new people posting and I'm glad that you've started a repair thread especially since the canoe means something to you. ("...for nostalgia purposes, yes.")
Canoeing itself is a sport where ROI cannot be measured solely on finances. The intangibles of nostalgia, personal enjoyment and peace of mind are often the greatest returns. Thanks for continuing to update repair progress.
I appreciate the responses and advice provided in this forum.
There was one crack on one side of the canoe that was repaired with GFlex followed by a couple of layers of fiberglass inside and outside using GFlex as well. There was one interior crack on the deck of the bow, fixed the same way with only internal fiberglass layers. The other side of the canoe was wrinkled from the tree, but no cracks. I removed the internal vinyl around the wrinkled area to confirm that there were no internal cracks. I overlayed fiberglass onto the interior vinyl around the work areas to "reseal" the internal vinyl layers. Gunwales were replaced with vinyl and new end caps. A new yoke and thwart were also installed. New skid plates to be installed this week. Paint will follow after my upcoming BWCA trip where the canoe will used.
Cost for the materials was around $400. I probably used more GFlex than necessary, but it is a solid canoe now.
This is a fantastic canoe to paddle, and the canoe is very stable. Portaging the 73 lb canoe will be a chore, but it can be done.
I am still in the process of painting the canoe and I am considering using Krylon Fusion Matte Red Pepper as a base coat followed by Rust oleum top side paint. Will the topside paint adhere to the Krylon that is being used as a base coat? I could use Rust Oleum wood and fiberglass base paint, but it is not red, and the base coat will show after a few scrapes and scratches. The Kryon Matte Red Pepper is a close match to the red topside paint. Of course, I could just use the Kryon fusion as the final coat.
It's always good to see these older hulls brought back into serviceable condition. I picked up an Intrepid 16 this spring and was fairly impressed by it's stability in moving water conditions.
The canoe was finally painted with Rustoleum Topside paint. Skid plates are next. I am looking forward to taking on a river trip, probably next spring.
