- Joined
- Nov 22, 2021
- Messages
- 347
- Reaction score
- 228
Seems like interest in double bladed paddling is increasing.
That's good. I'm sold on it.
I first started experimenting with paddling my Wenonah Encounter, with a double blade, back in the mid 1990s.
I currently own two solo canoes that have been converted to pack style and I have over a dozed double bladed paddles. I also own a number of kayaks.
I'm still sorting things out. As soon as I think I've come to a final decision on something I go for a paddle and change my mind.
But, having said that, I think I can provide a useful opinion or two.
The downside of double blades is water runs off the blade, hits the drip ring and goes right onto your legs and into the canoe.
Yes, a long paddle prevents or diminishes this but, if you take that too far it's a case of the solution being worse than the problem.
Anything over 240 cm is getting too long, in my opinion. I like 230 for low angle and 220 for high angle and I'm over 6 feet.
I've found that I don't get as much water in the canoe as I used to. To be honest, I'm not sure why. Better technique? Faster stroke rate?
I think smaller blades and a faster stroke rate do help. I also think expensive paddles with a smooth back face to the blade, (no reinforcing spine) lift up less water.
For crying out loud, get yourself a decent paddle. Maybe I'm a snob, but if it has an aluminum shaft it's not good enough for me.
I think the Werner models with a carbon shaft and fiberglass blade offer a good balance between cost, weight, and toughness.
Don't let your ego determine blade size. Bigger isn't always better.
I've been experimenting with high angle and like it if the boat is narrow and the seat low, but most people are going to be happier with low angle.
That's my two cents.
