To go along with the OC-1 is the
V-1 correct?
			Just not sure how I could navigate on of these down a twisty river with logs in it.
What they are now calling a V-1 is an outrigger canoe designed for the flatter waters of Tahitian lagoons, as opposed to the big ocean swells of the Hawaiian islands.
The differences between an outrigger V-1 and OC-1 are that the V-1 has no rudder, has a more sit-in enclosed cockpit, which can retain more water than the more sit-on-top OC-1 with Venturi footwells, and is longer with less rocker. The V-1 is a faster flatwater canoe because a rudder can increase drag by as much as 7%, but is not as good a wave surfer. Without a rudder, the V-1 requires more single blade correction skills like a CanAm open canoe.
I've never paddled open ocean waves. I bought my OC-1 (which confusingly contains the model name V1-B) for use on inland waters, though I have paddled around Sanibel Island in Florida and in Cobscook Bay (Bay of Fundy territory) in Maine. The narrow beam, long length and rudder make the outrigger a great canoe to paddle upstream in sufficiently wide rivers and Florida spring runs. You couldn't run it down a very narrow, twisty creek of course.
I have taken the rudder off, which takes 20 seconds, to run beaver dam streams off Georgian Bay in Canada. My canoe has so much rocker that it can be turned relatively well for 22', and it can just slide right up a beaver dam. When you are on top of the dam, you don't have to "get out" of the canoe; you just stand up, easily straddling the 14" beam-at-rail hull.
My canoe was not built for racing lightness, as I had an extra layer of fiberglass put on the bottom of the carbon/Kevlar hull. It weighs about 30 pounds and is easily carried on the shoulder for portages, which I have done in the BWCA and Adirondacks.
Unfortunately, most of my outrigger photos as I drove it all over the American west, Yellowstone, the BWCA, Algonquin, Georgian Bay, and the Adirondacks are on an old, dead computer, and I don't know how to get them off.
Here I am on the Lewis River in Yellowstone in 2004. The park rangers who took the photos said I was the first outrigger canoeist ever seen in Yellowstone.
