Hi there, I've decided to sell my Northstar Trillium for $2200. Location is Newtown, CT.
Purchased new from dealer in September 2020, though the serial number indicates it was constructed in 2017. BlackLite construction with ash and walnut trim. Set up with kneeling drops but price includes seated drops as well. Length is 14’6” and weight is listed at 30 lbs. This is the perfect do everything canoe, whether it is a paddle on the lake with your pup, a cruise down a creek, or a multi-day excursion in the wilderness.
This boat has been well pampered, with washings after each use, regular oiling of gunwales, and frequent 303 UV protectant application. As the photos show, the hull is almost completely devoid of scratches. However, as indicated in the photos, there are two small areas which show a shadow of repair, where a couple tiny cosmetic dings in the superficial layer of the resin were sealed over and then buffed. These could be made completely invisible with sandpaper, resin, and buffing compound. Overall, this boat is structurally excellent.
New MSRP is $3745 for this style of construction and trim…
Save over $1500 with this one in fantastic condition.
For more info, check out: https://northstarcanoes.com/canoe/trillium/
