• Happy 1st U.S. Census (1790)! 3,939,214 👪
Multi pocket canoe packs
Alan: That BUSHCRAFTER pack looks like something I could use. How high does it carry on your shoulders? Does it interfere with portaging a canoe?
Gerald
Doesn't sit up too high. I've portaged a canoe with it a fair number of times and never had an issue with it.
There's a draw string at the top of the pack opening which nicely cinches down around the barrel neck to hold it in place, which leaves the lid exposed and easy to access.
Bill, do you have any pictures of how the suspension and harness are attached to that Ostrom pack? I really like the idea of pair bags whether side zip duffel style or some variant of roll or fold over top bag.
Best regards,
Lance
Sorry, not a clue. Just read about it after Ostrom ceased production. maybe 10 years ago? Saw a used one for sale before I ever soloed.
Hello, have you a particular model in mind (as they seem to have various models available on Amazon, Canada) and if so have you ever used it while portaging a canoe at the same time.
Thanks,
G.
I would think the RUSH 2.0 55 liter pack would be good for canoeing. I just purchased a AMP 12 to carry my Ruger TD rifle to the range and as a bug out bag, not planning on using it for canoeing.
For those looking for the two-halves style, there's a new one I just came across. I don't know anything about it other than what I read in the description, so no endorsement here. Maybe the pics will help you DIY seamsters (I'm jealous of your skills!).
I have to say, I may be going back to my backpacking pack to solve the multiple pockets problem. The main compartment can divided into 2, with a part sized for a sleeping bag at bottom and the top of the main being tall enough for my tent. The 'brain' top has interior and exterior pockets, and lots of outside attachments including a web of small diameter bungees. The downside is that with everything packed in lightweight dry/stuff sacks it can be a little hard to fit it all.
But when I bring my Granite Gear portage pack, although it's much easier fit everything, I spend a lot of time rummaging and invariably as I pull out one thing, the smaller stuff falls to the bottom or things shift, and now I'm pulling out everything to get the one small thing. Plus if things shift something often starts jabbing me in the back, even with careful structuring when first packed. The nail in the coffin is that the portage pack doesn't lay down in the ends of my Phoenix (the dog goes immediately in front of me where a canoe pack would fit best).
Regardless of main pack, I double portage and usually bring either a thwart bag or something like a small camelback or cheap lightweight drawstring backpack to keep my 'valuables' (keys, wallet, phone, ditch kit, map, compass, snack, water, extra layer) with me at all times. Obviously the thwart bag is best while in the boat, the mini backpack nicer on the carry. It goes on the front while the main pack is on the back.
I'll note that I'm thus far a short duration tripper. I could certainly see the advantage to those split packs on a longer trip with more gear/food and more need to balance ballast.
I use a large capacity ultralight pack, line it with a 35L drybag for the 'cannot get wet' stuff (sleeping bag, clothing), and use other small drybags for the rest of it, using the pack's pockets as needed. I've tried carrying a small day pack, a thwart bag, and a pocketless drybag w/harness, but none of them work as well.
