Ursacks and Minimalism
SW OH - Land of Opaque Water
My partner had an Ursack this past trip. It didn’t look too bear resistant, but neither did my blue barrel.
I’m thinking my next trip should be one pack. Maybe 3 days. No tent, just a tarp and a quilt, possibly a 3/4 length thermarest (cause rocks are harder nowadays).
Anyone else do this? I think fall would be great time for such a trip, soon as I can reach my feet again. I’ve got a small Bear vault, which might fit 4-5 meals and 6 cups of dog food. No camp chair, though, and I’ll sure miss some luxuries.
Here’s my pack contents:
Tarp
Ground cloth
Quilt
Pot, frypan
Pocket rocket, fuel
Bear Vault with bag meals, kibble
Thermarest on outside bottom of pack
I strap a fishing pole in my canoe and an extra paddle. 2-3 crank lures in my pocket.
Whaddya think? Missing anything? A big lake trout or pike and we can stay an extra day.
Personally, I'd go with a ultralight tent, sleeping bag, and a 3/4 Z-Rest. (The last fits in my canoe pack, taking up less room than a 3/4 Ridgerest, and there's no inflating and deflating to deal with.)
Bring a lightweight campchair, it's worth the comfort. Afterall, we're not backpacking here. How cool does it get where you will be paddling? Lower temps would be a good reason to bring a sleeping pad. Make a beer-can stove and use denatured alcohol. Cooking takes a tad longer, but what's the hurry? Also, it's lighter and there's no canister waste.
Just a tarp works fine if the season is right & bugs aren't an issue. Throw a water filter and a small 1st aid kit into your gear list and you probably have anything that you'd NEED to have but I'd be taking my inReach too.
I'm certainly no ultralight guy but I don't like unnecessary weight either. I don't really want the bulk of a barrel and the Ursack, although typically hung, seems to rely upon puncture / tear resistance. I've gone the other way and (while I still hang whenever possible), I use Opsak bags for food storage.
They're not at all rip-resistant (just like a heavy zip-lock) but what they are (or are marketed to be) is odor-proof. The theory seems to be that no critter is going to rip it open unless it smells like food.
When I first bought them I was skeptical so I conducted an experiment. I cooked up some bacon, put some in each Opsak bag & threw them out in my yard. There is a thriving feral cat colony in my neighborhood and the bags were untouched. Still skeptical, I put a few slices of bacon in regular zip-locks & tossed them in the yard also.
The Opsak bags remained untouched even though the regular zip-locks were pillaged overnight. After 3 days of zip-locks being shredded & Opsaks being ignored, I had to conclude that maybe they actually DO work despite the fact that they certainly do NOT look bear-proof.
They definitely have less bulk than a barrel.
Anyone need a lightly used blue barrel and harness? I weighed my Bear vaults and food pack and got this barrel because it saved a few pounds. It was nice having a dry place for stuff on top of the food, but that would be luxurious for a minimalist.
PM me if you want a good deal on a BB.
After sorting through my necessities, I think I’ll use the CCS food pack with a small bear vault, and the LLBean Continental pack to carry with the canoe. I’m certain I can keep the weight down without a tent, change of clothes, excess food, etc, while keeping some creature comforts. I think just limiting my trips to a few days will help immensely. Probably no more 10-14 day excursions for me, but concessions must be made.
Thanks for the responses.
I don't think I'd ever give up a change of clothes to save weight. One slip and fall while getting out of the canoe after a long day has convinced me of that.
After seeing all the tackle it takes to make a hang in some locations, I wonder if you really safe much weight over a small bear vault. You certainly don't save any time.
I did a 40+ day trip with no extra change of clothes. It wasn't too big of a deal. If I was wet when getting to camp I'd put on my thermal bottoms I used for sleeping and some of the extra layers had. I made a point to never wear all my layers when paddling in case I had to change into something warm and dry. I'd do it again.
Same here--43 days. Lots of portages, so weight was important. Worked out, so another 42 day trip a few years later (and another 30 day wet trip). The last couple of trips I had a very light pair of pants for flying commercially back, with no use on the trips.
Oh, and I did a fair bit of wading on two of the trips in my single pair. Modern stuff dries quickly.
After seeing all the tackle it takes to make a hang in some locations...
I'm not sure what's needed for a bear hang besides about 100 ft of paracord, a small aluminum carabiner, a small throw bag for some rocks & a large(ish) bag for the grub. (oh, and a stick but those are usually just laying around). All of that will probably be about 10lbs lighter than a blue barrel.
literally everything I use for a hang I already carry anyway- 75' of rope, and a couple of locking carabiners from my ditch kit, and a dirty sock are all I need, if I want to get fancy I add a second 'beener and one of my lining ropes- for a single line lift, I simple fill a sock with sand gravel or small rocks and tie my line to it, toss it over a suitable branch, replace the sock with the beener and clip on.
for the double line I do the same but add a loose beener with my bow line running through it after throwing it over the branch, throw the main line over the second branch and tie off the main line, then I simply grab the ends of my hoist rope, slide the beener to the center between the branches, and attach my bag to one end of this- now I hoist up the bag and tie off the end to a tree roughly perpendicular to the mainline
The only thing I use that's not from my pin kit is my lining " bow" rope, and a (usually dirty) sock that gets washed when I rinse out the sand or gravel...
Well, I hate paracord. It stretches when wet, and it's hard to get knots out of. 1/8" braided poly is easier to use but heavier than paracord. And I'm not comparing to a blue barrel - which isn't an approved "bear proof" container in a lot of places. I'm thinking more about the smaller and lighter approved containers.
It's probably dependent on location, but I've been places that needed a lot of cordage to accomplish a workable hang. I'd have to gather stuff up and weigh, but I suspect that between 'biners, cordage, and bag, I wouldn't be seeing a lot of difference from just an approved bear-proof container on the ground. And that, with a lot less time setting up and breaking camp.
Time savings are certainly real and much depends upon how accurately you can toss the rock bag over your target branch. (My socks are merino wool and I'm cheap so I usually use the bag that holds my tent stakes)
I single line hang exclusively so only 1 'biner is ever needed (I used to use 2 lines but critters can learn to chew ropes that are tied to trees).
That said, I have found quite a few campsites where there were no suitable hanging trees and the Opsaks appear to be critter-proof on the ground.
In my later tripping years, as I knew I was declining in strength and willingness to portage, I transitioned to an Ursack with odor-proof Opsacks inside. I would just tie it to a tree away from from my tent. It can hold a weeks worth of commercial freeze dried meals, which is the only thing I eat other than protein bars. My only garbage is the rinsed-out meal packages, which go in a garbage Opsack.
If I were tripping longer than a week, I'd just get a second or bigger Ursack, whatever their product line now has. I've never used a barrel—too heavy and bulky and incompressible for me—just Duluth packs (usually just one) and a smaller dry bag as a daypack.
Ursacks are good weight minimizers, and I believe they are bear certified in most places. Even if you don't have bear encounters, an Ursack tied to a tree is good protection against more common pests like rodents and raccoons.
To me, Ursacks are the way to go; unless hard containers are required by the land managers where you're traveling. I've been using one for many years and only once have I had any infiltration into the bag. It was one of the new bags after the company changed the material and also started making bags for bears and another one for smaller critters (squirrels, rodents, etc.). My old one feels like vinyl while the new one is more cloth-like but it's the original vinyl-like one that has held up the best.
Like Glenn, I appreciate walking up to a tree, tying it off and forgetting it until morning. At this point, unless I'm required to carry a canister, I'll stick with the Ursack. Lighter, easier to pack and collapses in your pack as it empties out. The only disadvantage? I can't use it as a seat like some claim they do with their canisters.
[The bag failure] was one of the new bags after the company changed the material and also started making bags for bears and another one for smaller critters (squirrels, rodents, etc.). My old one feels like vinyl while the new one is more cloth-like but it's the original vinyl-like one that has held up the best.
This seems to be a less-than-glowing endorsement of Ursack's current offerings.
