I use this old tool for sheet layout: http://delphiforfun.org/programs/cutlist.htm
It's more math project than woodworking software and the GUI is a little quirky, but it suits my needs perfectly.
As to your strongback and assuming you will build more than one boat, I'd be more inclined to make one 8' section and then another, custom length to accommodate your current, diminutive vessel. Fewer joints.
The reason for the extra joints was to get the pieces short enough to go through an attic hatch for long term storage.
Have you received the plans yet ? They should tell what you need for Strongback length.
Also if they are the Mushroom type, or shearline level with the strongback top.
Edited to correct a number of errors. Sorry for any confusion.I don't have Mac's book in front of me.
Here is a pic of a lower ( Non Mushroom style build ) The top of the forms are less than 16" tall. The shearline runs a little above the strongback in the middle. As the shear gets closer to the ends, the shear actually drops below the top of the strongback.
This method requires the strongback to be a certain length, give or take some.
The Mushroom style is built entirely above the strongback. They also require more wood for the forms.
Me ? If the paper plans show the forms as symmetrical (the forward forms match the rear forms) I would space the forms equally fore and aft.
Trying to go Asymmetrical, I doubt you would gain much, on that small hull..
As far as your strongback, the main thing is that it is level and straight, through out the building process.
