Wood Glue versus Epoxy
One of the main differences between TB III and epoxy, is the gap filling capabilities.
I mix Cab O Sill ( Fumed Silica) and ground glass, for anywhere I need to fill gaps, and still be strong.
I will also add very fine saw dust for color, if needed.
The result is a putty, that I can adjust the thickness.
It is the compatible with fiberglass cloth, or wood.
Good to see other's experiences, with TB III.
I used Titebond 3 to glue a wooden do-dad that sat outside on the ground and in the weather for two years. I was surprised that the glue was holding up strong. TB3 might not be good for immersion, but it’ll stand up to weather.
