• The 2026-29 Fund Drive needs 14 MORE DONATIONS to reach target. Read the Featured Thread for details. Please donate!!!
Need help with sending replies
Illinois
Hello!
I'm a returning member from last year who had a question about sending replies.
When I'm replying to a message in a particular person's thread from several months ago, I notice that it appears at the end of the final page of the thread. Is there any way of moving my reply up to the first page so maybe the author will notice it ? I do know that there is a section listing the most recent posts...do y'all check this on a regular basis?
Thanks, Gail
This site does not use Threaded Posts, personally I much prefer a strictly chronological system and truly hope that this site will never go threaded.
If you really want to make it clear who you are replying to you have two options;
Use the Quore+Reply function or use an @GDahl to indicate who you are replying to.
There is another (not canoe related) discussion board that I read and post every day, it recently converted to a threaded format, it's a true pain in the you know what and in a matter of a few weeks the participation rate has dropped like a giant boulder in the river, gone from hundreds of posts per day to a tiny fraction.
Thanks recped. So my best option would then be to send a private msg in reply to a person? When
a message gets relegated to the last (eg p10) page of a thread, perhaps it won't be seen by the intended recipient....
When you quote a post, the forum default settings will generate a notification to the quoted user. There will also be a notification sent to the owner or "watchers" of a topic when you post.
Also, when you visit a thread while logged in to the site, the default setting is to take you to the page where you left off. In this case, when Erica logs back in and visits the thread, the browser will take her to her last unread post.
Another note: (because you mentioned sending a private message... I think they're termed "Direct Message" here... tomato / tomato...)
A PM is useful if the poster hasn't been active in awhile (hover your cursor over the poster's screen name & it will show when they were last active unless they've shut off that feature in their settings but most don't). A PM sent through the site will also send a notification to the email address associated with their account so if prompts them to check in and respond.
Gail, I'll try to explain things a slightly different way.
When you add a post to a thread, it will always go on the end of the thread. However, we have three thread "widgets" on the home page of the site. One widget is called "Latest Posts", which lists the 14 threads that have the latest site posts in them. When you add a post in Thread A, for example, Thread A will pop up to the top of the Latest Posts widget. However, if someone else one second later makes a post in Thread B, Thread B will become the first one listed in the Latest Posts widget, and Thread A (with your new post) will drop to second place. Hence, the Latest Posts widget is a dynamically changing list of the 14 threads on the site that have the latest posts in them. Everyone who logs on will see that same list. But the list can change fast if the forum is very active.
If you want to see a list of the threads on the site that have posts that are new to you—that is, unread by you—you would click the "New Posts" link. Everyone who logs on to the site will see a different set of threads in their New Posts link because everyone will have read and not read different posts.
If you want to catch a specific member's eye when you make a post, you can do three things. You can "Reply" to a previous post they made, or you can "Quote" just part of a post they made (as I did in this one with you), or you can include their name in your post with an @ tag, such as @GDahl. Any of these methods will cause an alert to go to that poster, notifying them that you have replied to them, quoted them, or tagged them. An alert is signified by a number that will appear on the Bell icon in the upper right corner of the home page. (You will probably get only one alert from this post of mine even though I both quoted and tagged you.)
Of course, if you want to message a member privately instead of publicly, you can always use the DM feature.
The main features of our Xenoro software are explained in this thread:
I generally just use the "new posts" link because it'll show me every post made on any subject since I last read it, Occasionally, if the thread hasn't been used for a few months (or even years) I'll back up a couple of posts to refresh my memory, then read through all the new comments.
Once in a while I'll hit a post I don't remember ever seeing before, in which case I'll use the "unread" link to see if maybe it "lived and died" while I was away for an extended period.
Between these two links and the notifications at the top right, I don't think I've ever missed a reply or comment in over a decade.
If I want to ensure an intended recipient sees my comment I always hit the reply widget, if it's just a general comment I'll post normally
