After moving leftover materials from the new shed to the old shed I finally had room to move the Bell Mystic into the Canoe Shed to thaw out, the tarp I had put on it blew off and then the snow came.  First I had to get the ice off it and used a rubber mallet to gently pound it off, I was sweating hoping I wouldn't break the hull in the sub-zero temps.  It was only about 2 degrees out.  I swear I was dressed like Charlie Brown!
Last night I screwed in two hooks so I could suspend it from the ceiling as that is where the heat goes in this new shed. With my newly messed up rib it was a chore to get it up but there it was and the leftover ice and snow melted off quickly. I'm going to leave it there for a while so the core can dry out before I begin repairs. I gotta say with the shed at 16' x 20' there is not a lot of wiggle room with the boat at 18' 6" but with it up in the air I can access my cans of liquid courage no problem! There ya go McCrea! Also the majority of the heat is going up to the ceiling right now until I can get a fan installed to move the heat lower and of course some kind of walls would also help, in time.
The longest boat in the fleet right now and it's actually slotted for someone else. It is going to be an interesting and challenging rebuild. A few pictures. Damnation, it is so good to work on a boat again!
dougd
dougd
