- Joined
- Nov 19, 2013
- Messages
- 1,645
- Reaction score
- 1,793
Coldfeet - For what it's worth, I found my pan in a July 4th flea market that's held annually up my way. I realize you probably want one now but it might be worth your while, if you don't find one in the meantime, to check some out when you can. Even down your way my guess is there are some indoor winter flea markets. Might we worth a trip.
BTW...my pan bottom is a bit wavy but so far it hasn't effected anything I've tried cooking. I think the key was mentioned already by Robin; getting the pan "seasoned" is important to the process. Originally my pan had some rust so I put in the required elbow grease after allowing it to soak in some Dawn for an hour or so. Once that was done I approached the seasoning by hand rubbing olive oil into the warmed up pan. I did this a couple of times and do it again after each use. So far, so good. Hopefully you'll have the same experience when you find your pan.
