• The 2026-29 Fund Drive needs 15 MORE DONATIONS to reach target. Read the Featured Thread for details. Please donate!!!
Deciding which canoe
Other than my Hornbecks, each of my solo canoes was ordered with a 1.5" riser above the highest available stock high seat. All are paddled with a single blade paddle, single side. I had to argue with Joe Moore when he did not want to do it with my PB Shadow because he has had three previous customers return theirs with that modification because they couldn't keep their canoe upright. But it works fine for me and is sufficiently stable if I don't hold a heavy camera higher than my head while stationary.
One question I have has to do with stability while quietly fishing in a non-moving canoe. My Bluewater kevlar canoe, which I used for many years to fish in, was 16'6", flat-bottom, and wide. I do not remember the width at the gunwale but very stable. Never an issue.
A Swift Prospector 13' is only 27" at the gunwale and waterline. but a maximum width of 30".
Is 27" wide enough to comfortably fish (baitcasting) on flat water? How would the stability be when the the canoe is not moving yet I'm casting, reaching for lures, and reeling in lunker bass?
That will be very dependent on the person paddling and the seat height. It will also depend on the actual shape of the hull (two canoes with the same specs on paper might feel quite different in terms of stability on the water). I did plenty of fishing from a Bell/Northstar Magic, which is on the tippier side of solo tripping canoes, with no issues. But I spent a lot of time in that boat and was very comfortable in it.
I don't remember if you mentioned it earlier in the thread but were you otherwise happy with the Bluewater other than weight? If you had no complaints about its performance but know it was stable and comfortable for you then I would lean towards something similar in size and shape.
It doesn't sound like you're looking for a performance canoe nor to necessarily build your paddling skills. Just something to fish out of on flat water on smaller water. That is not what 95% of people on this forum are using their canoes for so some recommendations are likely to be biased away from your use case. I know nothing about the Swift Prospector 13, it might be great for you, but keep it in mind.
If you don't need the shorter length a longer canoe should, all else being equal, feel more stable.
I prefer a canoe no longer than 14' and the weight less than 30lbs.
This was what you were originally looking for, and after several suggestions of the
Swift Prospector 14 (or 15), now you're considering...
I'd say no, a Swift Prospector 13 isn't going to be a good fishing canoe for you*, especially if you plan on standing when fishing. We have a Prospector 13 and it's a great canoe for sitting or kneeling, but I wouldn't want to spend much time standing up in it fishing. The Prospector 14, with another foot in length and two inches in width, would be a much better candidate. In either the carbon or Kevlar layup the weight is under 30 lbs.
*Added: The Prospector 13 is actually quite stable for a small canoe, but that depends on your weight. We're under 150 lbs and can sit comfortably on the kneeling seat and it seems pretty stable. The P13 is great for exploring small ponds and streams, and it seems popular with double-blade paddlers, so if you fit the canoe and aren't planning on doing any standing, it might work well for what you're after. If your weight better fits the Prospector 14, it would probably be comparably stable sitting on a kneeling seat. And as NikonF5user mentions, you can order them with adjustable seat heights so it would give you options.
I have two 14' solos. The Mohawk Solo 14 and the Wildfire. I prefer to be kneeling for stability while fishing in the Wildfire, which is closer in width to that 13' Swift. Sitting to fish is easy in the Mohawk, but good luck finding one. I wouldn't stand to fish in either, although I have stood in the Mohawk to pole it upstream.
That's all to say I wouldn't expect to be able to stand to fish in that Prospector 13, and I probably wouldn't be real confident about fishing in it from the sitting position. The Prospector 14 would be okay sitting if you're hips are loose (it was for me) - especially if you have a foot bar.
If you must stand while fishing and you aren't overly concerned about speed, I would suggest that you look at the 14' Wenonah Fisherman. I did a lot of standing in one when I was still pretty new to canoe poling, and it was at least as easy to stand in as the 16' Old Town Camper.
Edit: Unfortunately, the lightest you can get is 36 lbs. @Canoewiia do you really need to stand?
I did get the impression that both the Trillium and Firebird are not meant for meandering around a pond's water lillies and fishing. More of a performance package for open water.
I have a Firebird and it's a wonderful canoe for exploring swamps, marshes, and complex shorelines, but I wouldn't use it as a stable fishing platform. The Trillium is also a good canoe for exploring shorelines (based on my experience with a Hemlock Kestrel) but whether or not it's stable enough for fishing depends on your comfort in a narrow canoe.
And check out my previous post about the Prospector 13, I added that I wouldn't stand in the canoe to fish, but it might work if you just want a small, lightweight canoe to explore and fish from while seated.
Your Freedom 16'6" is a wide family tandem. Waterline width is just one factor; the Prospector 13 is an exceptionally low volume (small) boat that can only handle a max of 240 pounds. I can't think of a smaller solo on the market. The Prospector 14 can handle 400 pounds; it's on the very high end for solo capacity...it's not a small low volume boat. The 14 is much better suited for your use.
Between Fireburd and Trillium, Trillium is a better choice for you. The high rocker of the Firebird makes it super responsive; it will react to you casting. Trillium is a narrow solo but with the low seating position and a footbrace you might be fine with it although the Prospectir 14 would be better for sure.
Regarding adjustable seat height it's not all positive. A fixed seat adds a lot of structure to the canoe. A fixed seat will never feel loose. Adjustable seats add weight...but not a lot with Swift's design. I lift boats by grabbing front thwart and back of seat. So when I bought a Swift this year the fixed seat is definitely best for me...but for you the adjustable option may be best. With boats like Trillium they offer 2 heights of seat drops so most solo paddlers figure out what they like and then have a solid, fixed seat.
Great info, thank you all. Let me clarify a few things.
I've never stood up in a canoe in my life nor will I ever. Fishing will be done from a seated position using as baitcaster. 240lb maximum capacity is not an issue.
The length is only critical because I do not have a garage. It will be stored in the basement and I've since measured the maximum length to maneuver it rather than guessing. It is a 13' canoe which gives me just enough room. That could change in the future if I find an appropriate storage location but don't want to include that in the equation at this point.
OK good. I think ease of use may be the most important thing. The 27" waterline on the P13 is on the wide side for a short boat...if you can try one it may be just fine for you and I expect it would be a much better choice than Firebird. A footbrace adds security/stability. I'm not familiar with Hornbeck boats but I've owned one pack canoe and learned I'd rather be up a little higher on a seat than sitting on the floor.
My apology for thinking you'd mentioned standing for fishing. You did mention wanting to sit higher (as in kneeling seat height) rather than lower (as in a pack boat seat height), correct?
Finding a 13 foot canoe that is stable while fishing from a higher seat greatly limits your choices. The Prospector 13 is probably the most stable of the +/- 13 foot canoes I've paddled, other than the discontinued 13'-6" Wenonah Sandpiper. But I weigh less than 150 lbs so having 240 lbs in a Prospector 13 and comfortably fishing while sitting on a kneeling seat might be interesting. A foot brace would help with stability, somewhat. I'd certainly want to try it out before purchasing. On the other hand, if you are comfortable fishing from a lower seat height then the Prospector 13 might work well for you.
If there's any way you could accommodate a longer canoe, say a Prospector 14, that would be my recommendation.
I finally came to the realization that one canoe cannot serve every master. So, just a dedicated fishing/poking-around canoe for one person with a single conventional seat.
I agree with Alan Gage. I don't think you want a tippy, extremely expensive, high performance, sport canoe for your purposes. You likely would be happier with a small "pickup truck" canoe.
I recommend looking for an Old Town Pack on the used market. It is 12' long, 32" wide, has a stable flat bottom, weighs 33 pounds, and is made of indestructible Royalex (no longer available). It is a nicely stable solo fishing canoe from the sitting or kneeling positions. It is maneuverable enough to poke around swampy and twisty places, and you can paddle it with a single or double blade. Royalex will enable you to drag that canoe up and down your basement steps without worrying about damage. And, if you can find one, it may be under $1,000.
Old Town even made a model called the Pack Angler just for fishing. It has a different seat, a Scotty rod holder, a bow-mounted Scotty anchor system, and a nylon work deck in front of the seat. Here is one from a Facebook ad:
You can see the Pack Angler page in this 2008 Old Town catalog:
