The Shenandoah by John Diller https://www.facebook.com/savageriverinc
[Admin edit: direct Facebook LINK to the Shenandoah prototype post]
@RPATCH test paddling a wood strip prototype of a new Savage River 14' solo canoe, tentatively named the Shenandoah, on a Mullica River water prairie on October 6, 2026. This prototype had adjustable gunwale width so as to adjust the rocker. It also had a bottom-mounted bucket seat, which could be sat-upon or kneeled-off, slid fore and aft, and raised or lowered in the front or back to adjust the height and cant angle. Feedback was provided to the Savage River team by several paddlers (including yours truly) on different rivers and a lake this week in the New Jersey Pine Barrens.
it also had a bottom-mounted bucket seat, which could be sat-upon or kneeled-off, slid fore and aft, and raised or lowered in the front or back to adjust the height and cant angle.
Oh, I get it now - thanks. So if I understand correctly, it must have only one thwart, which is adjustable in length (I wonder how much). And for that to work, the seat is necessarily floor mounted.I'm pasting Glenn's response from the "Photo of the Day" thread since it pertains to this hull and gives some good information:
@Glenn MacGrady I would be very interested in hearing more on the details of this seat if you can provide them. All of my homebuilt solo canoes have had a sliding bucket to allow an easy transition from sitting to kneeling and I've often contemplated a height adjustable version but never was able to come up with something that was practical enough to easily fabricate and operate. How was the performance of this seat in the field? Was it held secure or would it rattle around/come loose if inverted for portaging/car topping?
Exactly how the seat in my Solitude works. Similarly, I have to get out of the boat to adjust the hight. The Solitude seat, however, is suspended from the sides rather than floor mounted. I'm pretty sure that mounting on the floor saves significant weight. And of course, it eliminates any danger of entrapment.It traveled quite a ways fore and aft and was held in place just with body weight friction. If you raised your weight slightly off the seat you could slide it on the fly. It was also comfortable to kneel off of, but the undercarriage mechanism would keep your knees locked into a spread position,
There were two adjustable length thwarts made from telescoping tubes with hole perforations and a stop button or pin.
Or if possible to adapt it to an existing canoe that has enough flex in the hull to accept such.I can see the adjustable thwart idea making it possible to live with one canoe for everything....up to a point. (Perish the thought)
Edit: I wonder if this will be carried into a 15' model. Hmmm.....
Actually, I was thinking kevlar to gain tumblehome, not really needing rocker.Paddlers forever have been playing with the installation of shorter or longer fixed-length thwarts to adjust rocker, but I've never before seen telescoping, adjustable length thwarts. It worked to adjust the rocker on the thin wood strip Shenandoah prototype and presumably on a lightweight composite laminate hull, but it may not work the same on a plastic or wood/canvas hull.
Now that it's been done, it makes me wonder why it took so long. The material for rigging an adjustable thwart exists in great and cheap supply at thrift stores everywhere. It's the same material I've used for adjustable foot bars - aluminum crutches.
I think I paid $4 for the last pair I bought. Insurance or Medicare usually pays for them when someone is injured. When they're healed, many eventually dispose of them at thrift stores or yard sales. Why they don't hang on to them just in case they need them again is beyond me.It’s actually a very simplistic, elegant thing.
And your idea of crutches matches. Better than a tent pole.
Well of course I'm kidding..... sorta.Let's not go overboard or hyperbolic.
Even if a canoe's rocker can be adjusted 1⅛ inch, one still has to like the basic canoe design for one's purposes and circumstances. If there are 100 canoe models on the market, which is a very conservative assumption, the vast majority of people don't buy any given one of those designs—say, #27. How much more demand will there be for #27 if its rocker can be adjusted 1⅛ inch? I don't know, but it certainly will not make #27 a canoe for everybody or everything.
