• Happy World Emoji Day! 🌎🌐🗺️
Puffer Tents
"People certainly might be inspired to get out and camp more if pitching a tent becomes as simple as connecting a battery-powered electric pump and letting it fill the tent into shape while they take care of other camp setup duties. And if that tent sets up in about two minutes flat, all the better. That sounds way better than messing around with a complex spider web of pole segments, elastic cords, sleeves and clips."
". . . the Puffer includes an integrated air mattress for a floor, providing cushy comfort you can't forget at home. Because they're designed for different pressures, the base and frame inflate via separate valves, and to make it that much easier, Puffer lists the ideal pressures on the corner that houses both valves."
"The Puffer tent alone weighs 18.2 lb (8.3 kg), while the primary components of the accompanying kit (electric pump, stakes, carry bag) push total weight to 22 lb (10 kg)."
Gram weenies, run away in horror. Base campers and glampers, think about it.
https://newatlas.com/tents/puffer-inflatable-a-frame-tent/
22lbs, Chinese 40d TPU, $650? Not for me, but an interesting product. Inflatable floor is asking for trouble, given my luck with sleeping pads. But hey, this how innovation happens. Thanks for sharing!
I'm staying this week in a Nemo tent (Aurora 2P). They started by offering tents with sleeves for inflatable poles. Nemo no longer offers tents with inflatable poles, only aluminum poles. IDK the reasons.
I do like the Aurora 2P and don't mind the slightly long bunch of poles or setup time. Weight is nice enough but not ultralight.
My canoe kit ships 2 weeks from today!
