An extra trippy Merlin canoe strip build
No pictures today but I did manage to get the inwales glued & screwed. I mixed the epoxy pretty thick (roughly 2 parts epoxy to 1 part sawdust) so that it wasn't runny but would still "squish" out.
I screwed up a little since, having done the Bloodvein the previous day, I knew almost exactly how much epoxy it would take and I mixed a double batch so I could do both sides without mixing again. Note: Don't do that. Larger quantities of epoxy "kick" faster and thickening it seems to accelerate the process even more. I got one side done, threw the rest of the epoxy away and mixed a fresh batch for the other side.
Screws were again placed 6-8 inches apart where the sheer rose away from the waterline and about a foot apart where it ran more parallel. I find that the screws really help in pulling the inwale square to the sheer.
I had to return to the boat shop about 3 hours afterward and might have saved myself a lot of work on future builds.
Up until now, I've always returned the next morning and cleaned up any runs while the epoxy was still green. Today, however, when I checked the runs, they were still soft enough to scrape away. I pulled all of the clamps, used a discarded piece of strip to scrape away the squeezed-out epoxy and it cleaned up in less than 1/2 the time.
I'll be at my buddy's woodshop tomorrow fixing the broken Bloodvein seat and machining this one according to the updated design.
Well, I'm unsure which of these screwed me but this build continues to fight me (but I'm winning... I think). I've begun to wonder if the canoe Gods are hating me for the crazy color scheme.
We machined the seat parts matching what we did to repair and reinforce the Bloodvein seat including the addition of a small tab under the seat to help prevent twisting. That tab becomes a PIA when fitting the seat supports so it will probably not be included in the future.
At any rate, we got the parts cut, mixed some thickened epoxy and clamped them together lightly. (for any future readers, I am now finishing this hull and the Bloodvein build at the same time so I may repeat things or might leave out some details because I covered them in that thread and can't recall what I put where)
Like on the Bloodvein, I decided to mount the seat directly under the gunwales. Due to the depth of this hull, I'll be a little short of my preferred 9 inches above the floor (the seat has about 3 inches of drop on the front rail) but it made it easy to hold the seat (in the wrong position but we'll get to that) while I fit seat supports.
I need to clean the shop thoroughly before the next build (it's getting completely trashed... even more than usual...) but I'll need a bigger boat shop to build 2 at a time. I had my epoxy station, belt sander, etc on the infeed table of the shaper so I had to get creative shuffling boats. This included a brief look at what this color scheme will look like in the sunlight.
Sticking it out the door allowed me to move the Bloodvein to the off-loading table once the outer gunwales were installed and I could then move the Merlin to the strongback cradle.
You may have guessed that I was fitting the seat supports (on the side that I could reach) while the boat was on the rear table. I could also reach those supports as the Merlin was hanging off of the porch so I used leftover thickened epoxy from the Bloodvein gunwales to glue those supports in place.
I should mention that (especially with asymmetrical hulls) it's really important pay attention to the boat's orientation or devise a system where the bow is always on the strongback in a certain direction. I did neither of those things and got really lucky that I didn't allow the epoxy to set up overnight.
As it was, I'd run short on clamps doing both sides of the Bloodvein so I made a run to Harbor Freight, ran a few errands for my Mom and the epoxy only had about 3 or 4 hours to cure before I could walk around the hull properly and noticed that something was wrong.
Yep, I'd installed the (highly contoured) seat facing the stern. Luckily, the short cure time allowed me to rip the supports off although it took quite a bit more effort than I'd have thought. I definitely know these aren't going anywhere once cured.
I used a scraper to clean off the hull and allowed the supports to dry figuring that I'd sand them off later.
Note: in case anyone is wondering, I tell you about the stupid things, not because I need the world to know that I'm an idiot but because I want everyone to know that even idiots can build these boats. I sincerely hope that including the "oh, $hit" moments doesn't discourage anyone but instead encourages those interested to give it a try.
It certainly helps to get lucky (as I did here) but just about anything can be worked around. (and, if not, it'll still burn).
Anyway... back to the build. If you've been wondering about the quotes at the beginning of this entry, your curiosity ends here.
I've been using a jigged trim router (a 1/4 inch trim router screwed to a piece of aluminum bar stock) to trim the "cap" portion of the inner gunwales flush with the hull prior to installing the outer half of the gunwales.
The bearing at the bottom of the blade rides along the hull and (usually) produces a smooth cut that is perfectly flush with the hull. It's really important though, to double-check as you go instead of just throwing it on there and letting it eat.
Whether the screws were insufficient to square the inwales or pulling the clamps early allowed them to twist (or both... most likely, it was both...), the inwales were twisted slightly and the router was gouging the hull wherever the blade touched before the bearing did. (not the best picture as I was also having other issues in this section but, hopefully, you get the idea...
I tried manually holding the depth but couldn't watch the both depth of the cut (only visible from below) and pay attention to the grain (only visible from the top) at the same time and I knew from my Freedom build that the router will splinter the Cherry quickly if going against the grain.
My solution was to use a small spokeshave to get it close and then sand it flush with the horseshoeing rasp and the longboard.
That worked really well even though it was slower than using power tools (faster than fixing disasters though).
I then started fitting the thwart and grab handles
used a 1/4 inch drill bit to create a divot in the outer glass and then used a 1/8 inch drill bit to drill pilot holes through the hull and into the thwart & grab handles. The 1/4 inch bit was then used to cut small divots onto both the cross pieces and the inner gunwales. These increase the surface area of the joint but also should prevent twisting once cured.
With every intention of attaching everything needing thickened epoxy this afternoon (seat supports, thwart, grab handles and outer gunwales), I needed a good way to hold the seat supports without reaching over the gunwales.
I solved that by cutting some leftover Poplar strips about 31 inches long and wedging them between the hull and the seat support (the lack of fill coats greatly increases traction for this operation)
PS: please ignore the air pockets under the glass. I meant to fill them with epoxy (using a hypodermic needle works pretty well) but don't really have time if this one is making the trip to WPASCR on Friday. (I mean, why not, right? Probably be the only one there)
These strips DID try to force the top wider so a large bar clamp was needed to hold the correct dimension.
Next I fitted the outer gunwales starting at opposite ends, cutting the stock flush on one side and allowing it to run past on the other. (Sorry, I can't believe I didn't take a picture of that... it was the same as I did the Bloovein yesterday)
After all of that, I started mixing epoxy, thickening it with sawdust, buttered all surfaces liberally and slapped them in place. Thwart & grab handles got a 1 3/4 inch deck screw to hold them (pulled tight so the head would be below flush and covered by the outwale), seat supports anchored with Poplar and the gunwales clamped fast with any (and almost all) available clamps.
I'm headed over early in the am to clean up both hulls and I'm hoping to finish everything but lacing the seats by the end of tomorrow.
You're getting a lot of work done!
I appreciate you showing your mistakes. I agree with you that it's important that new (or potentially new) builders should see that all of us deal with mistakes and setbacks and that they are all fixable.
And that phrase given to me last build comes around ... again .... "It's only a mistake if you refuse to fix it"
I appreciate you posting everything, I agree it is important to newer builders to see mistakes, both to be able to avoid some of them, but also to realize that it isn't the end of the world, just the start of a lesson.
Photo documentation may be lacking but I got 'er done. Now to wrap this up...
I clamped the seat to the porch railing outside and rounded the edges of the seat frame with an 80-grit belt sander belt that I'd cut in half and then 120 grit plumber's sanding cloth (again, not sure what it's really called... hopefully, you get it). Not only is the seat more comfortable with rounded edges but (I believe) the frame is actually stronger with a radius.
Next, I painted it with Spar Varnish and hung it over the side to dry for 24 hours (applying a second coat 2-3 hours later while it was still tacky)
I needed to quickly remove the squeezed-out epoxy from the gunwales so I strapped the hull to the strongback to prevent it from flopping while I used a progression of the rough & finish sides of the farrier’s rasp, then a longboard with 40 grit to level everything. I finished it with 80 & 120 grit also rounding the edges as I had done for the seats
As I’d done with the Bloodevein (and in the hope of finishing in time for WPASCR), I opted to oil the gunwales, etc instead of spar varnish since the Watco Teak oil said that it was ready for use in 6-8 hours instead of the “ready for light use in 24 hours” restriction of the varnish.
As I mentioned in that thread, I was careful to avoid getting the Watco on the fiberglass parts but as I was finishing the second hull (I honestly can’t remember which was first), it occurred to me that it was probably not the buried cloth that Watco was warning me against and I did not apply a second coat because I was afraid of what might happen to the epoxy
I’ll apply Spar Varnish when I sand out the runs & varnish the exterior. (the Watco says that it can be top-coated after 72 hours)
I centered the seat on the seat supports, used a large bar clamp to pinch the seat in place and then, doing one side at a time, I drilled through the seat and into the support below with a 3/8 inch drill.
I then lifted the seat and, using a 1/2 inch drill, chamfered the top of the hole to allow for a slight flare on the anchor.
The anchors are self-threading and are installed using an allen wrench.
I did one side at a time, installing the seat and loosely bolting in 1st side before moving to the other.
The seat frame was then removed and (as you might guess) I gathered as many colors of 5/32 paracord as I could find. I abandoned the shop for this part and opted for an old table under an even older shade tree.
My usual weave has a cord every 1 inch and this results in a comfortable seat that has nice support and adds a hint of color. It takes almost 100 feet of paracord for a seat this size. For this project I wanted more color (I mean, who wouldn't, right?) so I doubled the weave by placing one cord every 1/2 inch. I pulled them to what I would describe as "reasonably snug" but didn't attempt to stretch them as tightly as possible.
Almost 3 hours later, I was able to bolt it back in place.
The boat was then launched off the 2nd floor porch and I took another pic for @Roybrew
There are still runs in the epoxy to sand out, a little feathering to do on the extra glass on the stems & both inside and out will need spar varnish but I figured that was good enough to throw in the yard and, subsequently, on the shore of WPASCR.
It may also be interesting to see how much weight the Spar Varnish adds... the boat currently weighs 37 pounds.
I got a kick out of seeing it on the water
That was fun, and it achieved the primary goal of being "trippy" ... you need not worry about being unique in that one.
FYI 3 coats inside and out usually clocks in around 1.8 pounds (at least for Epiphanes)
It needs a distinctive paddle to match
Nope, I'd see (at least part of) the paddle every stroke.
Extra trippy colors are for the (WTH?) benefit of others and (possibly) to help searchers positively ID any remains.
So far, my gunsmith friend's reaction was my favorite. He loves order and is very traditional. He shook his head & said quietly "Just because you CAN do something, doesn't mean that you SHOULD" 😁
Glad you enjoyed the ride.
