• Happy Mountain Day! 🇯🇵 🏔️🌄
Coating the interior: Epoxy or Varnish?
Central Illinois
I'd like to coat a portion of the floor of my canoe in order to make the surface little smoother. The boat is a Swift Cruiser 16.8 in carbon innegra and the epoxy resin. I ordered the boat with a bench seat, because I frequently change positions between sitting, kneeling, or one leg forward and one leg back. I also like to paddle barefoot sometimes, but the texture of the carbon innegra cloth is a little abrasive on the tops of my feet as I slide them in and out from under the seat when I alternate from kneeling and sitting. The texture is fine on the soles of my feet, but it leads to rug burns on the tops of my feet as I slide them around, so I'm just looking to smooth it out a bit with a coating of something.
Any advice on whether to use an epoxy resin or spar varnish, or something else? It seems like varnish would be the cheaper/easier option, but I'm wondering if epoxy will be more durable and less maintenance down the road. Durability is a concern, because this will be applied in the hi wear area that gets ground in dirt and mud when I am wearing shoes. I'm only looking to coat a small area of the floor from a few inches forward of the seat to a few inches aft.
Also, I'd appreciate any recommendations on brands and application tips. If I go with epoxy, I was thinking West System or Silver Tip. If I go with varnish, something with a matte appearance would be a better match to the rest of the interior.
I don't know the answer to your specific question about varnish vs. epoxy, except to say I don't recall off-hand anyone varnishing the interior of a canoe but do recall many builder discussions about filling the interior weave with resin. My Mike Galt Lotus canoes have a football of gelcoat on the floor. Maybe that would be the most expensive and difficult to apply—not sure, no personal experience applying.
Myself, I solve your particular issue with a foam mat. The T-shaped mats extend backward under the seat.
On my Keewaydin15, I use a thin piece of yoga mat on the floor for some cushion and the ability to collect dirt. The mat is large enough to go from under my feet at the footbraces to under my seat. An added benefit is that it cushions and dampens the sound from moving things when I fish. if you really wanted to coat it then maybe epoxy paint, not epoxy resin, but consult with swift first an their suggestions.
A pad would, almost certainly, be the easiest option as well as being the easiest to maintain (just toss it when it gets worn too badly).
As for products, application, etc., I agree with the above and think I'd reach out to Swift and get their take on it. Either way, please let us know what your eventual solution is. I doubt that you're the first to have such an issue and you're unlikely to be the last.
If I go barefoot I'll get rug burns on the tops of my feet every time regardless of the canoe. If you fill in the weave a bit you're just changing the grit of the sandpaper. If my feet will be in direct contact with the hull I wear socks.
I was disappointed when Swift changed their Kevlar Fusion inner blanket to the coarse black and gold aramid weave in 2020, as I find it very abrasive as well when paddling barefoot. The coarse weave combined with the infusion process results in a scour-pad-like surface. I never had an issue with the older style fine weave Kevlar. The Carbon Innegra inner blanket is coarse as well?
Curtis used to paint the interior of his glass hulls with gray exterior floor paint as well as the bottom of his Kevlar Hybrid boats. I have done the same with several other hulls as well; it holds up well and is less abrasive to bare skin.
yes the kevlar innegra is also coarse inside, it concerned me a little at first but the yoga mat eliminates that and also gives me peace of mind if I drop a sharp object!
Thanks for the responses everyone. I did reach out to Bill Swift, who put me in touch with Mathew Steffler, their lead engineer. Matt agreed that epoxy would darken over time, and instead recommended using their UV Shield. It's what Swift now uses on the exterior of their boats, and also offers as an optional coating on their interior floors.
As some suggested, I have used removable kneeling pads/mats in the past, but I find them a little awkward when I'm changing positions so frequently, and I'd also rather not have one more loose item to deal with on portages.
I'll report back after I get it applied.
Coating the foot area with varnish or UV Shield, as Swift recommends, are good options but also consider wearing some sort of light weight protection on your feet. I generally wear a pair of thin, synthetic (nylon or polyester) socks. They not only protect my feet from abrasion but also from getting my soles sunburned. If I'm paddling in an area where I may need to get out to climb over logs etc. I wear neoprene booties with very thin rubber soles. They don't restrict movement much, stay in place on my feet and offer reasonable protection while walking.
Good point. I slip shoes back on before getting out, but I hadn't considered sun protection on the soles of my feet.
