Ausable River camping rules.
Western PA
What am I missing here? This sounds crazy...
  • • Do not tie/tack anything to standing trees, including (but not limited to) horses, pets, laundry lines, garbage bags.
In addition to what is stated in this rule, I assume this means no hammocks, no bear bag hanging or strap blue barrel to a tree, can't hang a gravity filter from a tree, no tarps tied to trees, tie-up canoe at camp, and I'm sure there's a few other potential violations I haven't thought about.
Geeze, even the BW allows tying/strapping stuff to trees. I understand and support "no nails, screws, etc" but strapping a gravity filter to a tree is worthy of a fine??
Where are you talking about? Is this a established camp site or in a park in general?
Established camps on Cooke Dam Pond.
Sites are reservable.
I was reading thru my reservation and I saw that rule. I still can't believe they enforce anything like that.
It does seem odd but if it's a drive-in campsite I'm guessing that it's been abused in the past, hence the rule, and it would be a bit more understandable.
Item 12 under "Need to Know":
There should be artificial trees in drive-in campgrounds - metal posts with cross beams and hooks - akin to established fire pits and grates.
I hate camping in full sun where all the trees are dead. I’ve been down the Ausable. It’s crowded. I’ve seen 5* campsites in BWCA ruined by overuse, rope hangers, and vandalism.
Do not tie/tack anything to standing trees... I assume this means no hammocks...
I wonder if the "do not tie" restriction is based on having trees essentially girdled from ropes or straps being tightly tied around them. Using a beefy tree strap with a hammock is different than tying a rope or thin strap around a tree, although with young or tight-barked trees even a strap can cause damage to the cambium if it doesn't distribute the force right.
I wonder if the "do not tie" restriction is based on having trees essentially girdled from ropes or straps being tightly tied around them. Using a beefy tree strap with a hammock is different than tying a rope or thin strap around a tree, although with young or tight-barked trees even an ineffective strap can cause damage to the cambium.
Back in my Wyoming outfitting days, I often used the cinch from pack horses as tree savers. They did a fine job of protecting trees. Seems like a product like that would be promoted more in regulations, and by outfitters.
So I tried to call yesterday to ask some questions. That was a joke. 100% automated, nobody to speak with.
So I messaged them, no reply as of yet. I'm not holding my breath.
.......I’ve been down the Ausable. It’s crowded. I’ve seen 5* campsites in BWCA ruined by overuse, rope hangers, and vandalism.
This is just a 2 night stop on our way to the UP. We wanted to see AuSable R but I am not expecting to be all by ourselves.
That's a heck of a tree strap. (y)
I was doing some web searches and there are quite a few straps available that look like they'd work, but they weren't exactly what I'd like to get. I want something to improve the weight bearing of the 1" straps I'm using now. They're OK, not great. May have to make my own.
Yes, that’s not one I’d use on a tree. The smooth ones from a lash rope are better for that purpose, but I’d have to dig for a picture of one of those. The mohair saddle cinches (pictured) are way too pricey and important for trees.
Have you had a look at climbing webbing or slings?
Some come in Polyester but even the Nylon ones are relatively low stretch.
I looked at slack line tree straps but didn't see what I'm after. I did find a utility belt that might work. I could easily remove the buckle and add some loops to hold my hammock ridgeline tree strap in place. The belt should provide better force distribution and extra padding against the tree. I have a single tree hammock setup with a Tensa pole so just need one strap.
I’d make the loops big enough to slip over the belt for smaller trunks.
The loops would center the 1" ridgeline webbing over the belt. I'd wrap the pad around the tree and pass the webbing through the exposed loops and tighten around the pad. Should be able to accommodate a wide range of diameters.
