• Happy National Drive-In Movie Day! 🚘🎞️🍿🍺💋
Installed the Rack
SW OH - Land of Opaque Water
Good weather yesterday so I installed the roof rack on the wife’s new RAV4. The crossbars don’t point the same direction; the bars’ profiles are at different angles.
Also, the factory rails on the car are not parallel. The rear feet are 3” inches closer together than the front. On my Explorer, I’m able to swap the front crossbar/feet with the rear and vice versa. The RAV4 will have separate front and rear units.
Now I’m wondering how the crossbar angles will impact the canoe cradles.
Just wondering what your rack set cost you (if you care to disclose). I may be looking at a newer vehicle and would be in need of a new rack, or used if I could locate one.
Consider the type of roof rails on your new vehicle. I have a Subaru Crosstrek with raised roof rails. I got a rack set - mounts, bars, and locks - by Malone for $219 (Cdn). That's about what Thule or Yakima would charge you for a plastic knob. Roof racks and roof boxes (i.e. large Tupperware) are, in my view, some of the most overpriced things you can buy.
Continuity is important too. I got the same Yak on my Explorer. Yes, they’ve gone up dramatically. I find their stuff lasts, though, and why skimp when safety is the #1 issue?
I may move the feet a few mm closer to see if that flattens the angle on the rear bar. It just doesn’t look right.
That gave me a good chuckle. I went through the whole rack research nightmare last year for my new Ford ranger, ended up with a set of truck box racks from Amazon that did indeed cost about as much as one knob from Thule. $169 all in if I recall. They're very good racks, not pretty or designed to carry 14 pound canoes, but they work fine for my big fugly cedarstrips.
I’m not thrilled with the way this rack fits. The landing pads need to be angled more. I’ll call Yakima (and try to speak with a human) to see if they have a better landing pad to compensate for the roof angle.
I think I'd ask (or look) to see if they make an adapter for round bars. Then you could rotate the gunnel stops as needed to align with each other. It looks like that version of Yakima's gunnel stops might work with a round bar and if they made an adapter for the landing pads it might be the least expensive solution. Maybe.
On my Subaru Outback, the factory rack is terrible for hauling canoes. I had to find a foot that allowed me to use my Thule square bars and the INNO feet did that but angled the bars. The rack carries the boats just fine.
I am a real long time Yakima user. My experience was similar to yours. Check with customer service but put the time in experimenting on your own.
Any chance you can share the exact Amazon link or the brand and name of those racks? I’ve been searching, but many at least look like they would not give my canoe enough roof clearance.
