- Joined
- Apr 20, 2022
- Messages
- 265
- Reaction score
- 553
YesDo you install thwarts in your SOF canoes?
And you can remove and nest a smaller canoe inside for easier transport
Thank you.. it’s the spruce green acid dye. They are very fun to build…and quick… I am impressed at how quiet they are. Reminds me of my wood canvas in that regard…but way lighterHave always wanted to build one of these !
Have watched many of the Cape Falcon videos.
PS. I like the color !
I was too as of last spring… Cape Falcon Kayak has many videos if you wish to go down that rabbit hole. The skin is a ballistic nylon that is made for the Skin Boat Store. This nylon is the 840 X-tra Tuff nylon and the urethane is a bio blend that is 2 part originally formulated for concrete floors. Brian has a mix ratio for each design based on size. Mine I believe took 3 or 4 coats… you have 24 hours before it will no longer chemically adhere to itself. My dye went on nylon first, but there are some colors that get mixed into the urethane and not dyed into the skin first.I know next to nothing about SOF canoes, so pardon my ignorance but what are the skins made of? The same fabrics as regular composite canoes? Just one layer commonly, or multiple? I’m assuming epoxied or resin impregnated through similar wetting out processes? Is the skin attached mechanically in any way other than at the gunwales?
These look really cool, and very interesting.
One skin layer of the nylonI know next to nothing about SOF canoes, so pardon my ignorance but what are the skins made of? The same fabrics as regular composite canoes? Just one layer commonly, or multiple? I’m assuming epoxied or resin impregnated through similar wetting out processes? Is the skin attached mechanically in any way other than at the gunwales?
I've never built a canoe. Do you really use green wood for the gunnels? I'm taking down about a dozen white oaks next month to make room for a barn. 60-70 feet tall and at least 40' to the first branch. They're right on the edge of being large enough diameter to be worthwhile to mill into lumber but maybe I'll set one aside to replace the aluminum gunnels with wood on my Northstar Phoenix.This canoe is 13’8” and weighs in at 25.5 pounds. Material cost was around 550$. The hardest part was finding green white oak and clear cedar in the lengths necessary for the gunnels
Thank you… seat is very versatile… Peter Hornbeck and his crew had a great design…the maple leaf is in memory of my father… a true Canadian and inspired my canoe tripping… miss that ol' gentlemanGood looking boat, with nods to Hornbeck on the seat design and Swift with that maple leaf!
The gunnels are cedar… the green white oak is used for the ribs… they get steamed and bent and the green wood really makes this much easier… and decent rot resistance… sorry my post definitely a bit confusing on that endI've never built a canoe. Do you really use green wood for the gunnels? I'm taking down about a dozen white oaks next month to make room for a barn. 60-70 feet tall and at least 40' to the first branch. They're right on the edge of being large enough diameter to be worthwhile to mill into lumber but maybe I'll set one aside to replace the aluminum gunnels with wood on my Northstar Phoenix.
