Divinycell build
Ea. Washington
New member, have built before. I found this site, read basically all build posts.
Did anyone finally build a stripper from it and I missed the build log?
The idea has been knocked around. It seems like I remember someone building a foam strip canoe but I don't remember if it was here, elsewhere, or just in my imagination.
Found it. No ending though.
Yes, I remember now reading that one. But as you say, no ending.
I remember the ideas of how to lay/support the strips was being discussed.
I just repaired a carbon copied Sawyer 17’9” Cruiser
We had done a lousy job laminating the inside, including a barely stuck bottom layer of 1/8” H80. That hull was all polyester resin, I don’t recommend it.
I think I salvaged the build using a bunch of 3/8” H80 that I bought for next to nothing.
Around the dinner table, we have the plan perfected.
1 layer of carbon over the plug, 2 layers 6 oz E glass over that keeping the stems open. All epoxy resin.
Flip the hull, close the stems then add H80 to the football and maybe some ribs. That foam MUST be vacuumed in place. Finish the inside with another layer of carbon.
Unless we have or make a female mold, I can’t see any way to support the foam and still have an accurate shape.
1/8” H80 with single layers of 6 oz E glass is more than adequate strength for all but the most abused hulls.
I’ll start a new thread detailing the carbon copy build, subsequent lamination failure and desperate salvage attempt shortly (spoiler alert: I think I saved it)
If I had unlimited resources, I’d build some way to heat form full sheets of 1/8” H80 over a plug, but sadly my pockets are not that deep.
I was waiting for your reply @stripperguy
You had talked before of a female mold. Like you say, probably need vacuum to pull fabric close.
I had wondered instead of horizontal like a stripper, go gunnel to gunnel over a male mold. To hold bottom ends in place, cut it longer, tack it to a board, cut later. You mentioned before of what bends without heat, so i thought might work easier.
My son was thinking we could rough fit the foam over a plug then force it into compliance with the first layer of fabric, whether glass or carbon. Conceivably, glass might be easier for that first layer, carbon is kinda stubborn.
That foam could be in narrowish strips and maybe laid at a 45 degree angle, like some cold planked hulls. Or whatever it takes to not demand too much of the foam.
With foam directly against the plug, it should be easier to pop free too.
This will make for good conversation with my son at dinner tonight… I have finished most of my work on his new house and he’s available at least for a wet out.
Thanks for reigniting my desires.
Have you purchased any materials yet? And what sort of layup?
Got a hull shape? And a place to work? Workspace is often a stumbling point for us home builders guys
I was thinking a Bobs Special. Though that is still open. I began looking at more indepth what for. Small lakes, fly fishing, tandem for wife occasionally, typically dog. But I want sub 40#. I hit 44# on my last one in 1994, realize now after reading builds, I would have gone lower. Back then, no web for information, sharing.
Materials, was pricing it out. Ouch, I haven’t bought epoxy in 6 years when I built a pram for fishing.
And then…. I found 2 different used Wenonah Fishermen in kevlar, 36#. That’s tempting.
