- Joined
- Aug 10, 2018
- Messages
- 2,551
- Reaction score
- 9,063
In response to a conversation started on this thread, I had an interesting conversation with an epoxy manufacturer today. I'll break it out here so as to not derail the original thread and to make it more searchable in the future (probably worth researching IMO):
In the above referenced thread, the question was raised if water temperatures in excess of 120° F would harm an epoxy canoe. I use RAKA epoxy on my stripper builds and they've always been extremely helpful when I've called (one reason why I'll likely never switch) and I was curious what their answer would be so I called today.
I spoke to Kyle who, although he had never heard of washing a canoe for invasive species mitigation, did confirm that their epoxy would soften if it was heated to 140° F (as in extended exposure to get the entire lamination up to temp) and that caution should be used to prevent deformation until the epoxy cooled.
Now, here's where it got interesting...
He went on to say that, after the epoxy was heated to that temperature and had cooled, it would essentially be work-hardened (I forget what term he used) and it would then have to be heated to between 180 & 200° F before it would again become soft.
I then speculated that direct sunlight (especially on a dark-colored hull) could probably exceed 140° F (proven in this study) and asked him if I should intentionally heat an epoxy hull to 140° F in a controlled environment before taking it to the woods. He confirmed that such curing would certainly be beneficial.
Has anyone else heard of heat treating epoxy in this manner? Do any of the commercial manufacturers (assuming they use epoxy) recommend (or condone) such treatments? Do they, perhaps, heat the hulls before shipment?
I'm pretty sure my future builds are going to spend some time in direct sunlight (and get checked with an infrared termometer) or get a nice, hot bath before taking them on their first trip... any thoughts?
