New Issue with my Swift portage yoke
My Portage yokes double as a Back rest.
Spoke to swift. Ordered a couple replacements. They just rip them out then repair the gunwales. I’m thinking about a deep hole saw or a thin hack saw blade to get under the flange.
Not sure drilling them out would work. They might spin, and I’d give up the threads to use for upward pressure.
Well, your FB post turned up a couple of more folks that experienced the problem, so there's that. If you want to remove, repair and reinstall, I get it. One thing about the PlusNut and similar crimp-type fasteners is that they work best when installed in a flat geometry to get the optimum bite, and the Swift carbon/kevlar gunnels have a bit of radius; not sure it was the best choice for the application. I don't know if suggestions to flood the area around the insert with epoxy would help much. I would have liked to see an aluminum plate installed in the gunnels during fabrication, much like Wenonah does for mounting foot-bars, and an insert anchored to that.
I am working on a yoke for my Kee 14 that would grip each gunnel horizontally, since the inwale is angled.
Nice save.
Well, I had ordered 2 inserts and paid double their cost in shipping, so I didn’t completely escape unscathed. Swift recommended I ship the boat back to them so they could “rip out” the inserts and repair the gunnels, replace the inserts. Combined with the difficulty involved with just replacing the seat, the necessity of replacing the hull identification plate, I can’t say I’m as exuberant about this brand as I once was. Hopefully, “normal” maintenance will now prevail and I can get back to bashing wet rocks with confidence.
I think many of us (well me) thought you had pulled the inserts partially or completely out, so overthought the repair. Should have waited for the pics, I guess. Sorry you feel that way about Swift; though not perfect, I would say their customer satisfaction is quite high. Biggest complaint has always been the price, but the money fuels their innovation. Of all their on-line videos, the one about the fabrication and testing of their composite components was quite interesting.
What was wrong with the original plate?
The number convention Swift used in 2019 is not compliant to the convention used in many states. Too many numbers, manufactured date not represented correctly in the HIN. Swift has changed now but many older boats must be reissued a plate to register in the states where registration is required. Simple fix. Swift sent the plate, old one popped off with a little goo gone and a putty knife.
Just one more tail to chase. After two applications were returned in the mail, the State sent me to a park for “inspection.” No rangers there, had to make an appointment. Took two more phone calls to ODNR to learn what was wrong with the application and a supervisor finally called me back to explain the number was too long and only the manufacturer would be able to fix it. I’ve got the plate on now, but I’m going to have it inspected just to insure the application doesn’t come back a third time.
Yes it is quite the racket when you have to register a canoe both from in state and out of state boats. The OT camper I bought was a farm pond boat and never registered in Iowa. Had to have it inspected by the DNR and given more paperwork to fill out. Now a days a bill of sale has to accompany the boat registration slip too. I forgot to get one the last boat I purchased and had to contact the seller again. All this work for a $27/3yr sticker.
I'm a Swift fan. One time I almost ordered some carbon fiber thwarts from their Parts activity, which is the actual factory. They were quick to point out that the carbon fiber thwarts were not as strong as wood. Nice to know. When I posted on another site I got a couple of comments around how difficult it can be to get relevant technical information (like um, is Expedition Kevlar suitable for an expedition? Surprise, the answer is maybe not...but you have to learn that from other paddlers). So one of my only complaints about Swift is that they seem so obsessed with Marketing (hard to argue since it's working). I don't like their videos in general because they don't talk about tradeoffs.
So maybe we should give them some slack because the yoke should not be attached during travel. But come on, they advertise a $700 carbon fiber yoke and brag about the simple/strong system but don't mention that you should not use it to lift the boat? Not even an asterisk with a link to some guidelines for proper usage? Come on!
I never would have expected that a yoke is not meant to assist in flipping up the canoe. Nor would I have thought expedition Kevlar is not meant for expeditions.
As a matter of public policy, why would paddlecraft ownership be discouraged by taxes and fees? They don’t spew fuel into lakes and they promote physical fitness. Dumb.
Re Swift screw-in yokes, that's the price one pays for carbon fiber over foam gunwales.
Besides, while it's possible, I've never used a clamp-on yoke to flip a wood gunwale canoe onto my shoulders, nor do I recall ever seeing anyone do that. With a heavy canoe, it's much too risky that the clamp will slip during such a maneuver, causing me to lose control of the canoe and possibly risking injury to the canoe, if dropped, or to me. With a light and narrow solo canoe, flipping up by grabbing a clamp-on yoke is unnecessary for most reasonably fit paddlers.
Unfit paddlers can use a stern pivot half lift with both hands on gunwales if they are weak, and then walk backwards under the yoke. Some people carry a small rug to protect the stern stem and deck during a half lift pivot, or use a stem/deck Pivot Protection Doohickey like this one:
Canadians have this idea that we are over regulated, particularly when compared to the Land of the Free. But registering a canoe? That's horse pucky. What does one do with a home built canoe? Does it have to be inspected?
It would seem we live in a world where the manufacturer must anticipate every use or misuse of their product. Some examples of Swift user complaints from recent memory:
Why didn’t someone warn me not to use the kayak roller boat launch with my Carbon Fusion pack boat?
Why didn’t someone warn me not to use ratchet straps to transport my Swift?
Why didn’t someone warn me not to mount a clamp-on fishing pole holder to my carbon/kevlar gunnels?
Why didn’t someone warn me not to transport my Swift with yoke attached “FROM OHIO TO WISCONSIN”?
Swift’s business model is lightweight hulls and fancy finishes (the trade-offs should be obvious), and business appears to be booming.
I built a 19 ft sailboat many years ago, still have and use it.
As long as I didn’t put a motor on it, there was no need to register it. But, if ever I wanted even a little kicker to launch and land, it has to be registered here in NYS.
So I applied to have a HIN assigned, a state trooper came and checked it, verified that I really built it (receipts, pics in process) and it was assigned a HIN.
But any non motorized boat needs no registration here…
I've never had one inspected. In Iowa the state issues you a HID number and then you're supposed to apply that number to the hull in an permanent and acceptable matter. I still haven't quite gotten around to that.
