• Happy Birthday, Thomas Edison (1847-1931)! ⚡💡📽️
DIY composite canoe with foam core
Alan Gage
Super Moderator
NW Iowa
I thought it might be worthwhile to start a separate post on my composite build rather than burying it in the thread with the stripper build. While I have built a couple composite canoes in the past there is a lot of new ground for me to tread here and I thought others might find it entertaining to watch me stumble along.
Also, @Nick Pending has shared some particulars with me through PM and I'm hoping he, and anyone else that has advice to offer, will chip in.
I'm building a short 13' narrow tandem canoe meant for young kids. The canoe is being strip built but I decided to use the stripper as a mold for a composite copy as well.
After getting the exterior of the stripper fiberglassed I sprayed it with a few coats of PVA release agent and laid a layer of 6oz fiberglass followed by a layer of 5oz carbon the following day. There were extra layers of fiberglass at the stems for extra abrasion resistance since carbon is very weak in that category. Normally I would have put down a full layer of fiberglass over the carbon but I expect this canoe to see light usage. For a little extra protection I added extra fill coats to give a thicker layer of epoxy.
I left the stems of the composite hull open while laying the cloth. This helps separate the composite canoe from the mold. For anyone doing this in the future I would highly recommend doing the same. I imagine removing the boat with closed stems would be much more difficult.
I would also recommend laying tape along the sheer line of the mold as this is where you begin separating the composite hull from the mold and it can be tough so any little extra help would be welcome. I did not put tape along the sheer with this build and very much wished I had.
Once the composite hull was separated I made a couple spreaders to keep the boat in roughly the correct shape. It's floppy as a noodle right now.
I then sanded the interior in preparation for the foam core and final layer of Kevlar.
The foam I'm using is scored so it will easily conform to the shape of the hull with no heating. But the biggest reason I went with scored foam is because it can be rolled up and shipped in small packages, saving me a 6 hour round trip to buy large sheets.
I laid the foam in the hull and eyeballed where I thought it should be cut. I cut one side, folded the foam in half, and then marked and cut the other side so it would be uniform.
And that's where it sits right now. I'm going to think about the shape of the foam core for a couple days before I epoxy it in place. Right now I have it running up the turn of the bilge. As I remember the factory foam core canoes I owned only had a core on the floor and not up the bilge. But at least one did have ribs up the bilge.
Is there a good reason to not run the foam up that high or did the factory boats keep it low simply because it used less material and less labor to shape the foam?
I'm planning to vacuum bag the foam into place, which will probably be a circus. I think I have enough materials left over from when I was building about 6 years ago but I need to round them all up to be sure.
AWESOME !
I question, if the foam is that flexible ? Will it add enough stiffness ?
Another reason I went with a cedar insert.
I guess you will find out.
Just a thought, that hit me.
Maybe you had saved the plywood, that you cut the forms from ? That could be used to support the hull, while working the inside. Depending on how you cut the forms.
Bell did a trick, with his canoes.
He added Kevlar felt to the inside, as a wear pad/ skid plate, instead of on the outside, like after market skid plates.
I'm ready for your next steps !
Alan,
There has been much discussion around the dinner table about the best way to home build these full composite hulls.
I think we came to the same conclusions as your methods just now.
Minimal layers wet out over a non sacrificial plug, leaving stems open. Remove from the plug, close up the stems. Add foam stiffening inside, vacuum bag to force good adhesion. Add inside layer of whatever…
What thickness foam do you have?
We used 1/8” H80 for bottom and ribs on that copy of the Sawyer Cruiser, and I think it could be used without thwarts and gunnels!! Amazing how stiff that hull got.
I would guess the production guys use as little stiffening foam as possible, maybe up to the waterline, strictly a cost issue.
On our build, we ran the ribs up to the sheer line, and that made fitting of the gunnels cumbersome.
If you’re gonna add ribs, keep them below your gunnels.
Other than that, I think you’ve got an excellent procedure planned.
Ideally you would build in a female mold and vacuum everything, but for one or two boats, in the backyard, exactly what you’re doing seems best.
Somewhere here one of the guys built some crazy fast solo hull using carbon innegra. He made a full mold, I don’t know if I would ever go to that extreme, but I was really impressed by his commitment and his results. That thing was a work of art.
Is the stripper for the out-of-state kids and you're keeping composite for yourself? You mentioned in the thread this was excerpted from that you're in Iowa and the kids are in Minnesota. That doesn't mean that adults won't be in either boat at times, so I'd build somewhat for that, maybe just not super-robust, gonzo whitewater tough.
These are all personal opinions and methods and reflect what worked (sometimes what didn't work) for me. Others will have different results, sometimes as good or better, sometimes worse. Live, experiment, and learn and pass results good and bad on through these forums please!
My only trial of this method of what Alan is doing here was done in excess of 45 years ago, and I don't remember all details now. I know I popped the composite layers off the plug, pulled peel ply, and bagged the Airex core into place. I'm pretty sure I also bagged the following layer(s) in too. I'm pretty sure that with the core bagged in the hull would be stiff enough that there would be little problem moving it around and having fold issues, but before that it might have been more dicey?? I no longer remember.
Again, if at all possible, bag the core into place even if you hand lay up the full piece that covers it. Bagging is the only way to ensure getting the core down against the hull layers without lots of air potentially causing bubbles. The sand trick can work, but has limits, though it is easier to do. I have done several other hulls with cores, but all of them were done entirely within female molds.
I would agree with some narrow glass stem bands over the carbon, though the the ones for extra wear beyond just holding the two sides of the ends together wouldn't have to come up vertically very high unless you anticipate excessive collision practice. Above the loaded waterline a couple or three inches? I don't know what would be enough. I don't think you need the glass outside of the carbon unless I was paddling it. I'm hard on boats.
Many commercial hulls are purposely slightly longer the higher up the stems one gets as well as progressively flared slightly wider up the boat so as to enable manufacturers to pop hulls out of molds without having to later close the end as you suggest. Those guys have lots of practice at this, so do so at your own peril. I'd suggest splitting the ends, especially if there is any recurve at the ends where it would be mandatory. I have a couple of one-piece female molds with this lengthening and flare that don't need to be split.
Maybe putting the mentioned tape so that an edge sticks down below the trimmed edge of the stripper being used as a plug and acts as a drip edge for the resin? For instance use two-inch-wide tape and stick one inch of the width to the strip boat plug. Another inch would be hanging down free, and resin won't travel up the inside to cause the problem that Alan experienced. You likely don't need an inch hanging free, just an example for explanation. More is better principle? I've not done this so how much is up to you. Maybe stick strips of cardboard or something stiff to the inside of that sticky free edge of the tape to keep it from getting bent up and sticking to the plug and possibly allowing resin transfer like that? Just newspaper would likely even suffice. Not that this last observation really matters much but, if you aren't doing a full inside layer addition and your inwale isn't going to be very deep (narrow vertically, the side contacting the hull), don't let that tape line show on the inside of the boat by using an excessively wide portion of tape sticking on the plug. Opportunities abound throughout for experimentation here!
If instead of vacuum bagging you're using weight inside the hull like Jim Dodd describes (and illustrates in the original post that this topic was scraped from), a bed of some "formable" substance to lay the hull in for near-all-points support might work, though the lengthwise 1x4s Jim describes would certainly be easier. Any method could allow the hull to distort or change the molded rocker. You want to do this the least possible. Vermiculite compresses (maybe not enough?) and perlite may work better as I don't think it compresses as easily. I've not used perlite so don't know for sure that it would work well. Perlite with less compressibility might have sharp little points that could mar the smoothness of the hull? Use a mix of both? I'm just mentioning possible solutions. Not sure what either vermiculite or perlite costs these days, so may not be economically feasible for one or two boat hulls, just offering it as a possibility. This would likely have to be done on the floor which means uncomfortable bending over to work on it or building a table of some sort to raise to working height. Jim Dodd's slings with boards seemed to work for him at holding the 300+ pound load and sounds cheaper and easier to me. Don't know if it distorted the hull to any great degree or not. No guarantees a vermiculite bed or one of another material won't do the same. What's easiest and cheapest?
I used peel ply instead. A definite dearth of elbow grease available here. It just means I'm basically lazy.
In my private note to you, I mentioned using something like an ice pick to punch a mess of holes into the foam so that all the air could be pulled from under it. Probably left you scratcthing your head. I used unscored foam in large pieces, whereas you mention you have the scored version, so you wouldn't need to do that. I missed your mention of that in my initial quick read. I also used quarter inch foam, which is thicker than yours. Many commercial builders use 3/8ths thickness, maybe even more(?), but I don't think that's necessary. I had to heat form mine.
As you mention, I think the pros only do it for ease and some weight savings, but they almost all also run ribs up the sides. Your foam is much thinner than what the pros use so maybe it's a good idea to go higher. Personally, I wouldn't. Whether you do go up past the bilge or not, if you're not going to do the foam ribs, I would also recommend putting some extra narrow layers of stiffening fabric once in a while to act as ribs, or the boat might seem a bit floppy with very little thickness of fabric from the stiff gunnels down to the stiff foam. Your three layers essentially hand layed up might be stiff enough, but I'm not sure. What I'd recommend is some heavy unidirectional Kevlar strips maybe two inches wide or so running from beneath or on top of the foam up to just short of the gunnel so it doesn't impact inwale installation as Stripperguy mentions. Glass or graphite (carbon) would work also and be better for compression loads, but heavy Kevlar uni will suffice and is lighter. The carbon on top of that inner Kevlar layer might look cool (oooooohhh, carbon fiber!) to those impressed by it, but if you use it, cover it with a light glass layer to keep from scoring it with gear or footwear scuffs, etc. I think you definitely want those ribs in the seat area to transfer loads from the gunnels to the foam below it. Ther emight be enough layers elsewhere that you don't need it on this little boat, but I don't know. I'd also recommend at least one in the center, maybe more than that spaced between them, but it's a short boat, maybe you can get away with two, or in any case not as many needed as I think (and as I said I tend to overengineer structures).
It's a matter of making sure you have everything you need, and having done it before helps considerably. It's been so long for me now that I'm sure I'd forget a few things. Make sure you put a resin trap in the line before the pump so you don't fill it and epoxy the whole thing together. If you're just gluing the core down, that isn't as hard but doing full layers of fabric entails lots more. What I used to do is dry runs. I'd get all the fabric into the mold get the sealant tape down and the bag on and sealed down, then draw a vacuum as tight as I could and leave it for a few hours, checking for leaks. Then I'd pull the bag back on one side and do a quickie wet layup on all layers at once, leaving air in all over the place, which would get squeegeed out before the resin set. Later after more practice, I'd just pull the bag back at one end and pour all the resin in and rock the boat back and forth side to side and end to end some, then reseal the bag and draw the vacuum. Then start squeeging. I wasn't using fast hardeners, was using industrial resins and hardeners that would give me like 6-8 hours of working time. In fact, I was adding an accelerator to speed set some. This was ages ago and I don't have a clue as to what's available now.
To respond to Jim Dodd just below, the floppiness of the core in this state doesn't matter at all. Gluing it down and then adding the reinforcement on top is what stiffens the cored boat. The foam stiffness doesn't matter as long as it's strong enough not to shear apart. All the stiffness is in the layer(s) sandwiching it. I don't think Alan will have any problems with floppiness that Jim envisions. Further down Stripperguy mentions how stiff is eighth-inch fully cored boat is, but Alan isn't fully coring this one. I'm sure bringing the core up the bilge will stiffen more, but not as much as Stripperguy experienced. I'd still go with at least ribs of some sort under the seats. Maybe not needed elsewhere, but you might get some wiggle without at least one, maybe two or three, between the seats, especially with two-layer boats. I could be totally wrong. I no longer have that boat I built long ago to check out.
There were other things noted in the private message(s) to Alan, but I'll save some of that stuff for later topics. The info will be easier to find later if it's not buried in this foam core thread. I may append some other hints in a later note in this thread. May. I'll try to go over this a bit later and maybe clarify just a bit or edit and check for typos.
Good luck with the project.
My first Composite, I Mistakenly, used 1/4", Pink Building foam.
My hull layup, was 9 oz Kevlar, covered with a 6 oz E-glass, on the outside.
I preceded to glue in a foam insert, using sand, for weight.
Failing to do a test piece. ( Now I know better ! )
Hand laying another 6 oz E-glass, over the insert.
I called it good. After a year of paddling, I'm sure the bond gave way, between the foam and glass.
Oil Can city.
Interestingly, even with a case of Oil Canning, it handles surprisingly well.
I need to dig it out some day, and get it on the water.
Oil Can city.
Jim , that pink floored canoe is pretty at least. You need an energizer bunny on the bow deck, or maybe a pink panther? <G > Rig a small bowsprit and fasten the pink doll underneath it! That foam is polystyrene and has poor shear strength, likely your problem. It probably failed at the foam and fabric interface as you say. Can you tell if the delamination is inside or outside? Maybe both? I'm just interested, you don't have to check it just for me. If there are places under the foam where it didn't stick, the delam could have propagated from there?
This would have been even worse with the white "beadboard" foam, another form of polystyrene with even lower shear strength. You could cut around the edges of the pink "almost football" of foam and scrape and sand it out and then put in another one of PVC foam, which is stronger, Airex and Divinycell are a couple brand name examples. A bit of work, but would "save" the boat if you like it enough to keep and use or want to sell it. Use glass again to cover it, or even Kevlar or carbon. Any of those would be fine. I'd avoid Innegra, even if a hybrid with basalt yarns. Unsolicited advice you're not obligated to follow. Offered for anyone else who has done something similar and might want to fix it, or who might have a floppy bottomed boat and wants to fix it. Good luck, whoever you are! < G again >
A side note about that polystyrene white bead board, sometimes called styrofoam.
I have seen that foam installed in many motorhomes, both in floors and roofs laminated between various sheathings.
I have also seen many of these structural element “composites” fail. As some here may know, I occasionally buy and sell motorhomes that have need wrecked.
I’m often surprised at the engineering choices, or lack of engineering, in these overly expensive cheaply built units.
Back to Jim, I had the same thoughts…scrape or sand that stuff out of there and add in a layer of 1/8” PVC foam, laminate it with glass and you’ll have a composite hull that will likely out live all of us!!
I had hoped to epoxy the foam core in place this weekend but instead I worked on the stripper. The composite sits the same as it did in the last post other than trimming the foam a little.
I think I'll leave the foam running up the sides of the bilge as it is. I don't see any downsides.
if you're not going to do the foam ribs, I would also recommend putting some extra narrow layers of stiffening fabric once in a while to act as ribs, or the boat might seem a bit floppy with very little thickness of fabric from the stiff gunnels down to the stiff foam.......
I hadn't thought of adding any sort of stiffeners under the seats but that's a good idea. I don't think I'll use foam just because of the extra work involved. I don't have any unidirectional Kevlar but I do have some 3" wide Kevlar tape so I'll probably use that as well as cutting more strips from Kevlar scraps. I realize it won't be as strong but hopefully strong enough
This is 1/8" H80 foam as well but it's scored so it will follow curves without heating. There is a coarse cloth on the surface that holds it together. Because of this cloth (scrim) the edges of the foam can't be beveled before installation because once the scrim is sanded through the little blocks of foam start falling apart. It should be easy enough to taper after the install though.
That does seem to be the best method. I did once make a sacrificial male plug which allowed me to close the ends during layup. I wouldn't be opposed to doing that again. It doesn't take long to strip a hull and I used short pieces of junk wood to do it with. I used Bondo to fill the knot holes and fair the hull and then just epoxied it with no fiberglass before waxing it and applying PVA.
A few years ago when I was building all the time I really wanted to do that just for the experience but I never could justify it. I bet you'd learn a lot.
Yes, that build was wicked. Super impressive.
Yes, to Nick, and stripperguy.
My plan is to remove the pink foam, and replace.
Either with foam, or a thin, 1/8" cedar insert.
Motivation is another factor. I may see how Alan's composite turns out ?
The lines come from a Jensen, tandem design, and reduced, for a solo.
This is one of my early stripper designs. Sadly, I sold the original canoe, but still have the forms.
All the more reason, to dig it out and maybe build another.
Well, today was the day. As with most of my projects it just kind of happened. I'd been rolling the process around in my head for the past week or so. I started pecking around with it this morning and just kept going.
I'd been thinking of the best way to support the flimsy hull and how to measure it to be sure it was in the correct shape. I had a few ideas that involved the laser level and comparing it to the stripped hull on the strongback nearby. In the end I went with something much more simple. Time will tell if it was a wise decision.
Currently the hull is sitting in some slings I'd made to support a canoe right side up. The slings are 1 1/2" wide webbing. I was worried these slings might cause indentations in the hull. So with the hull spreaders in place I picked up the canoe at each end and watched the bottom of the hull carefully. I could not see that it was changing shape with it was lifted off the slings so I just decided to leave it as-is for installing the foam core.
After reading the PDF I posted in the above reply I decided to trim the foam back a little so it didn't go so far up the chine. My reasoning for this was because of the difficulties that can be encountered trying to fill the open cracks where the foam is scored for contourablility. I figured the less the foam curved the better.
After getting the foam in the shape I wanted I outlined it on the hull in pencil before removing it.
Then I laid out the peel ply, which would go on top of the foam and cut it to shape.
Then I did the same for the breather material. This will go on top of the peel ply and allow air to be sucked out when the vacuum pump is turned on. Without some sort of breather the plastic bag could suck tight against the hull and create a dam that does not allow all the air to be removed.
Then I cut out the bag material itself and applied tacky tape to the perimeter of the hull. I'd seen a recommendation to cover the tacky tape with wide masking tape to better protect it against epoxy spills/drips. Since I'm guilty of getting epoxy on my tacky tape in the past, which is pretty problematic, I took the advice to heart and did so.
I also put a tape mark on the hull and on the bag material so I could quickly and accurately place it in the hull when it was time.
I decided I'd used thickened epoxy, figuring it would do a better job of filling the scores in the foam. I didn't know how much it would take but I figured 18 ounces would probably do it. Coincidentally it took nearly all of my cabosil to thicken that 18 ounces. I plopped it in the hull, began spreading it around with a notched trowel, and quickly realize that 18 ounces wasn't even going to be close to enough when spread with 3/16" notches.
So under duress I came up with plan B which was to only use thickened epoxy where it curved up the chine, where the scores would be open the furthest. There was enough thickened epoxy for that so then I turned my attention to the foam.
Again, in the PDF in the above reply, they highly recommended "priming the foam." This entails pouring epoxy on the back side of the foam, spreading it with a squeegee, and then working the epoxy around again with the squeegee. This forces the epoxy into the voids in the foam and gets rid of air pockets. This isn't just for scored foam but even for solid foam.
I was quite surprised how much epoxy the foam absorbed. I'd spread it with the squeegee and a few minutes later it would all be absorbed and I'd have to add more epoxy.
I poured unthickened epoxy onto the bottom of the hull, spread it around mostly evenly, and then put the foam in place. I was glad the foam was in 3 separate pieces. It made every step a little easier.
Now it was time to lay the peel ply, breather, and bag on top. Getting the bag placed correctly, sealing it to the tacky tape, and making sure there is enough "slack" that it doesn't pull too tight and bridge, is always stressful but it went pretty smooth.
After turning on the vacuum pump I was having trouble with the initial location where the vacuum hose penetrated the bag so I moved it to a different location. Then I went all around the perimeter tracking down leaks, which sucks. There was a big leak at the front of the hull that took quite a while to find but once the majority of the leaks where sealed the bag pulled down tight and is doing its job.
And that's where it sits right now. There are still some small leaks that I'm not going to chase down. I know I'll never get a perfect seal so rather than shutting the vacuum pump off after vacuum is achieved I'll just let the vacuum pump run until the resin has hardened.
Yeah, it isn't as easy as it sounds !
Looks good though !
Good penetration, as it's coming through the foam, and peel ply.
How long did it take ?
When I did my wood insert, I was always afraid of the pot life time, and if I could get things in place, before the resin started to kick.
Great you could see the capillary action ! I couldn't, when I used sand.
Pretty Cool Alan !
I'm not quite sure. I'd guess 2 hours start to finish?
No epoxy remained in the cup more than a few minutes so I didn't feel too rushed but I was getting a little worried by the time I finally found my big vacuum leak. At that point I went back to the cup that had mixed the first batch of thickened epoxy and it was still pretty soft, which was a relief.
I pulled the bag off tonight and I'm happy with how it turned out. The cracks where the 3 pieces of foam meet is perfectly flush and the edges have a slight taper. There is squeeze out all along the perimeter.
When I run my hand over the foam I can feel a couple spots that are slightly higher. When I run my hand on the bottom of the hull I don't feel a corresponding dip so I don't think it's hull deformation. I'm guessing that either the foam isn't in full contact in these areas or that the epoxy had started to gel before the bag was able to force the excess out.
When I press on the hull I can't feel the foam deform at all so I'm hoping it just small pools of epoxy. The spots are all in the center of the hull where it would tend to pool. They're very slight and shouldn't be a problem.....as long as it's just pools of epoxy and not voids.
The only problem I'm having now is removing the tacky tape. I've never had it be so stubborn. I usually do this in the winter with a 60 degree shop so maybe that's the difference? It's coming off extremely hard and is leaving behind a lot of residue. I'm inclined to wait for it a cool down a little before I try again. Or maybe I could use a razor blade to help lift it as I pull?
This is wild!
Thanks for taking us along, I've enjoyed watching this one! Interesting stuff. Can't wait to see it on the water.
This weekend I closed up the ends of the canoe. I started by taping the ends of the wood canoe I'd used as a mold, applied peel ply, and then put the composite canoe back over the top to give me the correct shape
I did this one other time and had a really hard time getting the canoe back off the mold once both ends were done. This time I decided to only do one end at a time. This allowed me to easily lift the other end to help break the connection between the peel ply and the tape. I'm glad I did this because I was not having any luck separating it by just lifting on the end that had been closed in.
I finally got the tacky tape removed. It was a real pain. It turns out to be very susceptible to mineral spirits so that was the key.
First I tried dipping a spatula in mineral spirits and scraping it off but that was a no-go.
Then I tried dipping a sharp wood chisel in mineral spirits and that worked pretty well for the majority of it. Without mineral spirits the chisel got tied up like trying to fight a tar baby but the mineral spirits acted as a lubricant and I could pull off about 12" at a time when using the chisel before I had to re-dip it.
That left a thin but mostly solid layer of tacky tape still on the hull. I tried wiping it off but it was still too thick. But the chisel, repeatedly dipped in mineral spirits, made quick work of it.
This left a very thin and spotty layer that I could wipe off with a rag dipped in mineral spirits.
Yeah, a non tumblehomed hull, with non recurved stems ? You can get away with it.
That was the fear, I had. So glassed the ends, of mine, off the mold.
I eyeballed for plumb, clamped and glassed the inside first. Kevlar made it tougher the shape the ends
There were a lot of ways to glass the ends, and I'm sure they would all work.
