canoe strapping
I have 16ft field and stream that i haul on a utility trailer , I have strapped it too tight and now the bottom skid is now deformed ,how do I straighten it out ? thanks in advance
If you have one available I would use a halogen flood lamp instead of a heat gun.
The advantage of using a halogen lamp are several, as opposed to patiently (or impatiently) waving a heat gun around you can more slowly and carefully heat a larger area. Moving the halogen lamp closer or further away it is easier to control the temperature; you want it hot, but not so hot that you can’t briefly rest your hand on it without ouchie.
I have a single halogen flood light, and a double on a tripod stand, and have used one or the other to remove some serious dents and deformations from Royalex and poly hulls.
