Placid Boatworks Ohneka. Rediscovered canoe worth considering?
New England
I'm sure I've seen I may have seen the webpage for the Ohneka tandem at Placid Boatworks' web site when I was shopping for a tandem canoe but dismissed it as a potential day tripper because it's marketed as a narrow canoe best paddled with lower seats and double blades. But after buying (and paddling) a Northstar Polaris and finding out how stable it is, I'm now curious if the Ohneka might work as a fast tandem day tripper using single blade paddles with seats set at the same (or taller) height as in the Polaris.
Has anyone had a chance to paddle this tandem canoe? I'd be interested in what you think about it as a day tripper for lakes and slow streams. We have a Northstar Polaris that works great for day trips but the Ohneka might be a fun canoe as well; even faster and less susceptible to the wind. It's got two inches less freeboard so I'd wonder about it in waves, though.
I'm now curious if the Ohneka might work as a fast tandem day tripper using single blade paddles with seats set at the same height as in the Polaris.
Tom, I've never paddled or even seen an Ohneka. Are you talking about paddling it sitting or kneeling? I doubt you can kneel at the stock seat heights, but the second half of the following video shows two guys paddling with single blades, sitting on the stock seat height buckets. I'm sure it is fast.
@Glenn MacGrady
Glenn, I watched that video and am not sure what the actual seat height is. Placid Boatworks describes their seats as follows:
Our carbon molded pedestal seats have undergone several iterations of R&D to come up with the most comfortable pack canoe seats available.
Although there is a slight difference in sit-bone-height-from-floor height between our seats (1.625” between the lowest and highest), “seat height” is a actually bit of a misnomer. What is really noticeable between them is the back angle when measured from the forward edge of the seat to the sitbone “pocket.”
Our seats are stackable; any of our higher seats will stack on top of any of our lower seats, leaving you different seat options for, say, another paddler using the boat or for paddling with a single blade paddle (a higher seat is nice). Stacked seats are held in place during portages with a simple lasso system.
So it's not clear just what the tallest seat configuration is with stacked seats. It might be fine since we're not planning on kneeling in the Ohneka, though the Placid website says kneeling is possible with their seat system.
At this point I'm just curious about the canoe. But it does look like a sporty tandem. :)
I'd sure love to try one. I'd be really surprised if it's less stable than my Solitude, which I sometimes stand in while going upstream with the pole. Doesn't look too shallow as a day tripper or racer to me, at least for paddlers me and my wife's size. Probably not novice friendly though.
Edit: Yes, it does look sporty.
I had a Rapidfire and loved the performance...fast, super efficient, seaworthy. I sold it because it was just too cramped...no extra space and no room for even a small dog; the bow position in that tandem looks like punishment to me. I also found the seat uncomfortable (looks like they changed it). I also concluded that I much prefer the normal (higher) seating position in my Advantage (and sliding seat) to the kayak seating in the Rapidfire even with the highest stacked seat.
Gumpus, thanks for your perspective. I have reservations about Placid Boatworks seating system for single blade paddling and would certainly want to give that canoe a good test before buying one. I've only been able to try a few of the canoes I've purchased over the years and it's worked out fine. But Placid's pack boats aren't typical canoes and that's why I'm curious about the Ohneka; it looks like a fun performance canoe IF we can sit high enough to be comfortable.
For background, I'd gotten the impression that Northstar's Polaris was a bit tender compared to other touring tandems but I was surprised at how flat(ish) the center section of the canoe is and how low they place the seats. I expected a more rounded ellipse. It creates good primary stability for a relatively narrow tandem but the canoe isn't as lively as I thought it might be and I'm finding the seats to be uncomfortably low after a couple of hours. So, I'm going to raise the seats about an inch, that should also make it easier to kneel when needed. Otherwise, (despite my nit-picking) the Polaris is a great tandem canoe; lots of fun. The Ohneka would be the tandem analog to my GRB Newman Classic, much like the Polaris is the tandem analog to our Kestrel.
I am really curious about this particular canoe, It appears to be a really sleek design. Hopefully I can get to try one out someday.
I'm fortunate to live just a couple hours away from Placid Boatworks so I hope to give the Ohneka a test paddle next summer. Whether or not I'd buy one is unclear; it's a lot of money to spend on a canoe we don't really need.
I've seen ithe Ohneka on the PB floor a few times, but as a C2 it did not interest me since I was more interested in Joe's solo boats at the tine. I have seen it race in the 90 miler once or twice, but do not know how it finished. Joe stopped production on it for a few years, unknown why but it is back in production now. There was one on display at this year's 90 mile finish under Joe's demo tent. Maybe a modified design?
Interesting. I haven't come across much about this canoe using web searches but this is a specialized canoe so no surprises there. I did find a mention about Charlie Wilson having one and how fast it was but they didn't say if he and his partner were using bent shaft paddles or how high the seats were set.
I plan to raise the rear and center seats on my Polaris. I had a Bell Northstar that I probably should have kept; my take is that it was s bunch more lively than Polaris. For me the Polaris might be better for paddling with inexperienced folks and kids. Rutabaga had a stealth Polaris marked down from $5495 to $3995 in their going out of business sale and I'm glad someone else bought it since new boat bargains are rare and it was calling to me.
That's good to know. I've long thought that the only thing I'd give up the Malecite for would maybe be a Bell Northstar. Maybe I should not consider the Polaris a substitute.
