A "Grand Illusion"?
Floral City, Florida
A Grand Illusion?
Over the past several years, I’ve had conversations with folks who liked the Savage River Illusion (my design) but felt it was too small for them. “Too small” meant different things to different people. For some it was limited weight capacity for tripping. For others it was a matter of their own body weight and for some it was limited space to move around adequately. Those with long legs felt they could not easily get into a transverse position. Some of those folks purchased Harmonies, outfitted as solos, but other felt that the Harmony was too large and thus the idea was born for a Grand Illusion.
The Grand Illusion would be a scaled-up version of the Illusion. The handling characteristics and appearance would be similar. Below is a table listing the basic specifications for the Illusion and those anticipated for the Grand Illusion.
Before building the prototype and then the plug, from which Savage River would produce a mold, I’d like to “test the waters” as it were. See how much serious interest there is in the boat. If you would seriously consider purchasing a Grand Illusion, please note that in your comments or email me. I’m in no way asking for any sort of commitment, but I am trying to gauge the level of interest.
If the project is deemed feasible, my intent is to build the prototype this winter and have it available for test paddling this spring. If all goes well, hulls could be available from Savage River by spring of 2028.
Pricing for the Grand Illusion should be approximately $200-$300 more than a similarly equipped Illusion.
Length overall Gunnel width Maximum Width Rocker Estimated load
Grand Illusion 14’ 6” 28” 30” 1.5” 240# @3”WL 330# @4”WL
Illusion 13’ 6” 26” 29” 1 3/8” 215#@ 3”WL 305#@ 4”WL
Gave the table formatting a try. It's VERY kludgey, but does work...
Savage River Canoes - comparison of Grand Illusion (proposed) and Illusion solo canoes.
OverallWidth(inches)EstimatedLoad (lbs)
ModelLengthGunnelMaxRocker3" WL4" WL
Grand Illusion *14' 6"28"30"1.375"240#330#
Illusion13' 6"26"29"1.5"215#305#
* Proposed by Marc Ornstein.
I guess it depends on how big you are :D I certainly have a hard time getting transverse, not possible in my wildfire and even in the shearwater which matches the width of the Grand Illusion I don't really fit, so far only the esquif adirondack at 31" and the pocket canyon at 34" have I been able to get fully transverse. I'd most likely still fall in the Harmony group size wise
Thanks Tom. I had it in a table format but it didn't post that way.
I don't have any experience with the Illusion, nor do I expect to buy anything quite in that class in the near future. But my perspective would be this...
At my 5'11" and 160 lbs, I have never done any multi day tripping in any canoe shorter than 14.5'. I have never been in a solo canoe (other than with seat on the floor) less than 14' in length. I think I would be fine for a week with minimal gear in the Wildfire, and it's certainly more than enough for day trips up to and including class 2. But my current quest is for something about 15', my 15.5' solo canoes feeling to me like just a little more boat than I need.
If I was near one, I would certainly give the Grand Illusion a try. The Illusion.....not so much.
If you get the chance, you might also try the Harmony, at 15'.
Canoe design is a fascinating subject. It is great to design your own boat.
I paddled lots of different canoes over the last 46 years but never really warmed up to solo boats.
A 29 inch beam makes me uncomfortable. I would rather just paddle a tandem boat when I am going solo. I have done it so often it just seems natural.
As one who bought an Illusion earlier this year, I certainly would have tried out a Grand Illusion if both had been available to me. It makes sense as a market alternative for all the reasons Marc is considering.
I'm 5-9 and my weight has yo-yo'd a lot the past four years, between about 175 and 210. I've paddled the Illusion at close to both those weight extremes, and am pretty sure I would choose the Illusion over the Grand Illusion at any place in that weight range.
One reason is that I did not buy the Illusion to be a wilderness gear tripping canoe. One can trip, of course, in virtually any canoe including an Illusion or it's smaller sister, the June Bug. However, I have long felt that a serious canoeist should own several canoes that are specialized or optimized for different purposes.
Hence, even if I still tripped, I wouldn't wilderness trip in an Illusion because I bought it as a maneuverable and ultra-lightweight hull for twisty stream canoeing and day play tripping. My Bell Wildfire was more voluminous than an Illusion and I didn't choose it often for overnight trips. I prefer a 15' canoe for tripping, and hence would still trip in my 15' Hemlock SRT or my Swift Keewaydin 15.
Of course, a Grand Illusion would be more conducive to tripping for someone in my weight range or above, so if I didn't have an SRT and a Kee 15, I might very well consider a Grand Illusion as sort of combo day play and tripping canoe if I could only have one canoe.
Another reason I might consider a Grand Illusion over an Illusion, regardless of my weight, is for greater initial stability. I have always been a kneeler, but as I'm now an octogenarian, I do need sitting breaks a lot more often than I used to. I don't feel comfortable sitting in the Illusion other than in calm water near shore. Perhaps that will change with more experience, given that I've only paddled my Illusion for 10 days since I bought it. In any event, for folks who want to sit as well as kneel, I assume the Grand Illusion would have more initial stability for sitting.
transverse position
Transverse position, especially a fully transverse position, is completely irrelevant to me. And, in my experience, is irrelevant to 99% of paddlers. If you want to go transverse, get a raft. Oh, I can go transverse in my Nova Craft Bob Special, which has a gunwale width of 35", but I never choose to do so, and the wide beam makes it a slow canoe. It's a decent blend of a platform canoe, a below average performance canoe, a small tandem canoe, and a solo canoe, but in no event am I ever motivated to go fully transverse with my legs. I do sometimes angle my legs and torso toward my paddling side, but I don't consider that "going transverse".
I can be instructed on this point, but going fully transverse is only useful on quiet water when paddling backwards with cross-reverse forward strokes, and even then one doesn't have to go fully transverse, or transverse at all, if one's torso is limber enough. Paddling backwards with cross-reverse forward strokes is itself a rarely needed skill. In my opinion, it's more useful in whitewater, and whitewater paddlers do it while their legs are locked in thigh straps or machines, preventing any transverse positioning.
(Historical note: Some of the most famous, and crawl-nimbly-around-inside-the-canoe famous, canoeists of the past 150 years have been small of stature and light of weight—to wit, Nessmuk, Reg Blomfeld, Omer Stringer, Bill Mason, Cliff Jacobson, Harold Deal, Mark Molina, Karen Knight, and some guy from Floral City, Florida.)
Yet, cross-reverse paddling is a cool maneuver, and a good sport canoe (aka freestyle) boat control drill, and I'll soon start a thread on it—as I have recent photos of @tketcham and @85dragonfly paddling cross-reverse in the New Jersey Pine Barrens.
That certainly looks like a canoe I could do most things in, including poling. Once upon a time, I had planned to have Kaz build me an AC/DC with similar solo/tandem/poling use in mind. I delayed and that ship sailed, of course. Anyway I've been following Glenn's plan since then (but lagging behind I think, with only seven different canoes), so no need for a "do-all" boat.
Call me a 1%'er then. 🤪
When I first saw that Cross Reverse was one of the four quadrants of maneuvers taught at the Adirondack Freestyle Canoeing Symposium, I thought: "WTF?" But after learning how to paddle in reverse facing "forwards", I find it quite useful and often paddle cross reverse after discovering narrow, twisty, debris-choked dead-ends. Having a canoe with an extra inch or so of width would be helpful, so I could see it being a selling point. (I don't get fully transverse in my Firebird, which has a similar hull profile to the Illusion, but I make do.)
Looking forward to the discussion...
