• Happy National Blueberry Day! 🫐💙
Best all-around design?
I have learned a lot about canoes in the past year. My first canoe was a 16' OT Camper, which is stable, great on ponds/flat water, but not very dynamic on moving water. About a year ago, I picked up an Esquif "Echo" and quickly learned that soloing is an entirely different experience from paddling a tandem. (I also learned not to wear waist-high waders while learning how to keep a solo upright on moving water.) Last month, I picked up a 17' MR Duck Hunter (Revelation hull), which I am looking forward to getting on the water, probably as a dedicated tandem.
In the past, I thought a 16' MR Explorer design was a practical design for a tandem to be paddled solo, but lately I have started to think that 16' Prospectors make a better all-around tandem for paddling solo on Michigan rivers and lakes. What do the experts say?
You will find many, many reinforcing opinions on the suitability of 16' class "prospector" hulls for solo paddling, particularly with large paddlers and/or large loads. However, not all prospectors are Prospectors, and the individual hull characteristics vary widely within the class.
@Gamma1214 is currently building the best ever all purpose hull designed for a mix of lakes and rivers. If anyone wants to refute that they can build one to test it out. ;)
Or you can attend the WPASCR in June & test paddle mine. I'm planning on having it done and taking it (maybe all 4 to see if anyone else wants to go rogue and build with weird woods)
Seriously, if you can make it, there are lots of hulls available to test out that weekend. Focus is primarily on solos, but the WCHA is typically well-represented too (mostly tandems).
This year it's June 5, 6 & 7 but I (and Alan's boat) may not be there until Sat the 6th.
Oh dang. I HAVE to go now...
My Nova Craft Prospector was fantastic as a river solo with a heavy load. Without the load, anything more than a soft breeze made it a real handful to control. The soft chines and moderate rocker made it very forgiving though.
Although not as forgiving in some situations (like an accidental side surf), I actually think the MR Explorer is a better all around hull. But if solo or lightly loaded and not in any significant rapids, the Malecite is even better.
I haven't been in one, but a Bell Northstar or Northstar Polaris is probably an improvement over that. Honestly though, I haven't paddled solo in a tandem for quite a long time now. Poling OTOH, a Prospector is hard to beat. But then again, I might say the same about the Explorer.
An Explorer was my initial thought. (And I may have an opportunity to purchase one in Eggplant, which will be hard to say no to.) I would consider a Malecite/Independence if I could find one within a reasonable driving distance from SE MI. Watching a movie on YouTube about a guy paddling a Nova Craft Prospector, solo, made me think about a prospector. Weight is also a consideration, and therefore, cost is a big consideration. I need to buy off the used market, which limits my options. Ultimately, what I am looking for is a durable tandem that is versatile, has depth and stability, that I can throw on top of my 4Runner and paddle solo, with a dog and/or fishing gear. One that I can get in/out of easily, without fear of dumping, when I stop to fish on one of the branches of the AuSable (MI).
The Malecite fits in the same class as the Northstar Polaris, Bell Northstar, and Wenonah Escapade. I consider any one of those perfect as a day tripping tandem that can be reasonably easy to solo. Not for much above class 1 though. That's where the Explorer and Prospectors come in. I myself would not buy another Prospector, but would instead go for the Northstar B16 because of the lower stems than a typical Prospector. People like to talk about 16-17' Prospectors as "all-around" canoes, but I consider them to be more specialized for river tripping with a load.
So, I'll give more detail about my Prospector perspective...
Most importantly, everything I say about it comes from my experience with the Nova Craft 16' Prospector.
Put a tripping load in that and point it down a class 2 to 3 river that moves continually, and it's pretty hard to beat, especially standing in the middle with a pole. But even with that load, the high stems present a troublesome sail when the wind picks up and current slows. A similar hull with lower stems may take on more water in class 3, but that wouldn't concern me unless rapids are too continuous to take the time to bail or dump. Since a lot of my time on the water seems to involve some wind, I consider that a bigger issue. And paddling or poling from near the center when solo (which is always the case for me, except on some day trips) allows bow and stern to rise over waves instead of plowing into or being swamped from behind by them. Adding spray covers or bags also mitigates the issue of lower stems.
There are several models around with similar bottoms but less prominent stems, the B16 being one of them. I consider that a better candidate for "best all-around" tandem.
Many boats will fit the definition of "good all rounder" some better than others. The size and shape of the paddler is as important as the boat in my experience. All of that before considering what is available locally for boats and geographically for paddling locations. What works good in the BWCA may not be a great fit for Appalachia. What may be for sale in New Jersey is likely quite different than what's available in Washington state etc.
Based on my limited experience with different hull designs I'd offer that a 15-16ft, arched hull with around 2" or rocker and 13" of depth will do 95% of what a canoeist needs.
Boats that fall within that range include the Esquif Huron and avalon along with various prospectors from different manufacturers, the Mad River explorer, malecite, or eclipse, the Dagger reflection, and Old Town's penobscot and canadienne among many others. They will all do well enough solo and better still with a certain amount of ballast. They can all handle an additional paddler and gear if necessary without being over encumbered and can be taken through moderate flat or white water with a bit of skill.
I've become quite fond of the Penobscot myself in the time I've spent with it. I've poled it, surfed it and run a stout Class III waterfall with it, even got first place in OC1 Rec at a local race.
When I found an old 18’ wood canvas Chestnut Cruiser (thanks fellow member Sweeper) that I shortened to 16’ during the restoration I found it to be an all around great hull. Lots of Prospector features but not as wide. It solos well, handles big water, good in moving water and lots of room for a shoulder season outfit (canvas tent, wood stove, wanigan etc).
