• Happy Invention of Scotch Tape (1930)! 🏴󠁧󠁢󠁳󠁣󠁴󠁿🧻3️⃣🇲
The Canteen
simple trick- make sure it doesn't leak, then put it away upside down. that way the ice forms first on the bottom and the opening stays clear
If it's cold enough the whole bottle will freeze solid. I was camped in 30 below F one time. I put a couple containers of very hot water inside of a cooler to keep my food from freezing. It didn't work, everything was frozen including the water. The eggs were frozen solid and the bread was too hard to slice. That was my last winter trip without a hot tent.
Yup, been doing that for years but I appreciate you mentioning it. I also have made insulated bottle holders out of old CCF pads. Nothing fancy. Just enough to go around the bottle, hold it in place with Duct tape, add a bottom & top cover and you're good to go. A whole lot less expensive than the OR insulated holders and just as effective.
If you're winter camping, another trick is to bury your water bottles at night. The snow will insulate the contents so the water doesn't freeze. Just be sure you mark where you buried your bottles. Playing Hide & Seek with your water isn't a great way to begin your morning when all you want is some hot coffee or cocoa (don't ask how I know...).
I've done many of both styles of camping, but I DO prefer waking up warm. For cold camping I do the same as snapper, but take it a step farther, I wrap the bottle and cosy in a layer or two of reflectix before burying it upside down, I also try to get it close to a foot down for more insulation then mark it with a stick and a bit of paper flagging tape. Just don't do what a buddy did- he put hot water in his then buried it, the heat melted the snow, which froze solid and conducted any heat left away- in the morning he had a basket ball sized chunk of solid ice which then required some judicious hatchet work and a couple of pots of melted snow to free and thaw his bottle....:rolleyes:
I guess that when I started tripping I probably used a Nalgene water bottles to carry water, then I switched to empty Gatorade bottles. They worked fine, but in the late 90s I started using a gallon canteen.
When I first moved to Ak. I went on a little gold prospecting trip with a friend and a friend of his. His friend was an older guy who drank whiskey with a water chaser. He had a gallon canteen that he hung from the side mirror on his pick up truck and I was impressed with this. The guy, Jay, worked in a liquor store and I would see him from time to time. Years later when I moved to a different house Jay became my neighbor. He still had his canteen which was always handy. He told me I should get one and related a story when he was in New Mexico and suffered severe dehydration in the desert and ever since has always had his canteen available. He said there was a gun store in Anchorage that could order me one. Actually the minimum order was for two, for 30 bucks, so two is what I got.
I started using them on trips. On portage trips I would only bring one and typically didn't fill it up to save weight. On river or big lake trips I would bring both of them filled up. They worked out good. I didn't filter water, preferring to boil it. Every evening I would make sure to boil enough water to fill the canteen. That was enough to get me through the next day until I got to camp.
These canteens were not only good for tripping. I used them at home too. I always had one in my truck from May to October. The other one was usually in my Baker tent that was set up in my yard. In the winter I would keep one in my bedroom. Always having them around made it easy to keep on on my water intake. When I was thirsty or felt dehydrated I could guzzle down a pint and still have plenty left. For almost thirty years I've never had to worry about needing to get water, it was always with me.
You don't need a dedicated canteen for this. You could always use a plastic jug, but having a dedicated container enabled me to develop the habit of always having it around. For tripping it was nice to have the capability to have two gallons available. They are very light when empty and I sometime would bring an empty one to have the ability to store water later in the trip, like after the portages were done. I still use my two original ones after 25 years. When I brought one to Pa. I replaced it with another, so I still have two in Ak. The new one I got is lighter and cheaper than the original but will hopefully hold up as well. What are you guys using for water containers?
2001
2021 This one was chewed on, by probably a mouse.
October 2025
I have the same style canteen! Bought it forty years ago from Cabellas or maybe REI ? Don't remember. Carried in my Jeep and on camping trips all over the Four Corners of New Mexico and Utah and canoeing the Allegheny Rive in PA. I still use it and it has the same worn out blanket spot as yours. I
2001
October 2025
2001
October 2025
Have one just like that! I always had that in my Jeep and with me on camping trips throughout the Four Corners area of New Mexico during the early 80's. Like Jay, from living in the desert I learned to always have water in the car. Love my canteen, it is a little beat up but I'm attached to it, lots of memories.
In my whitewater days 40 years ago, I had a nice rubber bladder canteen that would collapse somewhat as it emptied. It also had a convenient string attached to the screw cap so you wouldn't lose it when trying to sip water between rapids. Blaze orange color and it floated. I have no idea what happened to it.
For a couple of decades now, I've always used soft, collapsible plastic bottles (usually Platypus) of 1 or 2 liters. Collapsible bottles fit better in the side pockets of my dry bags and Duluth pack, or on the floor of a canoe without rolling around. I've tried both the wide mouth and narrow mouths. Prefer a narrow mouth except when I want to mix something in the water such as powdered tea or Gatorade, which is easier with a wide mouth.
I find they do get slimy inside after a while even if I just stick with water in them. Then it's bleach time or toss time.
I was never aware of the chemistry dangers or microplastics until a few years ago. So, like atherosclerosis, in my ancient age I've either got the crud in me at some dangerous level or I don't. That said, I do take some care, but I still drink so much stuff out of plastic no matter where I am.
(Now, who's brave enough to start a pee bottle thread?)
Your water bottle needs to fit your kit. This canteen won't work for everyone, and I don't think it would have worked for me without the rest of my traditional gear. It easily fits in my #4 Duluth packs. It's the last thing that goes in the pack and I can pull it out without unbuckling the straps so it is easily accessible. More recently I've been putting it in either a pack basket of wannigan where it is even more easily accessible.
I don't think it would have been practical if I were using roll top dry bags. It's pretty essential for me as I don't bring a filter and it good to have the storage capacity.
I used to travel the timber with a gourd canteen. Works great but is too fragile, I stopped using it. Now timber romps or canoe trips are relegated to nalgene bottles. On cold trips, especially with no dog to keep me warm, I like to put boiling water in my nalgene at the bottom of my bedroll to keep my feet warm.
I've got an old platypus kicking around somewhere, I have the 2 litre with the hose and bite valve, when I was running whitewater or pushing for distance it lived in my day pack under the flap so I didn't need to carry it inverted or get a hernia from trying to drink from it, as it aged it would get slimy inside more and more often and I stopped using it for drinking- it was relegated to getting water to purify, and the hose was cut up to make my intake and outlet hoses for my miniworks longer, eventually I stopped using it at all when it started getting shiny spots which turned out to be it starting to delaminate, now it's in my "questionable value" pile
