• Happy National Beer Lovers Day! 🍺
Building Laminated Canoe Paddles
There was some reference in a John Winters article that suggested that a plain cloth paddle face might result in better paddle performance, due to the somewhat rougher texture on the face creating more turbulence during a power stroke. I haven't personally tried that yet, but there is some technical suggestion that there may be an advantage to leaving the face unfilled, as you do.
I wonder if any of this could be analogous to the dimples on a golf ball?
"Function of Dimples​
Dimples on a golf ball are crucial for its performance. They help reduce air resistance, known as drag, and increase lift. This allows the ball to travel farther and more accurately compared to a smooth ball. The dimples create a thin layer of turbulent air around the ball, which clings to its surface and minimizes the wake behind it."​
Ah, yes, upon further review, the rotation of the ball is critical to the function of the dimples, and absent a stroke with furiously continuous palm rolls... not applicable.
I rescind my earlier comment so as to avoid derailing Marc's wonderful thread!
Yes, maybe not analogous to golf ball surface turbulence, but at a minimum the rougher weave surface does increase surface area, which should increase drag and therefore decrease some of the inherent slippage in a paddle stroke. At least when just “pulling the boat to a planted paddle” as the common way of explaining the physics of the catch and power stroke is often described. Whether that increased surface area is noticeable would be the question. How comparable is the increased SA to simply increasing the blade width a small amount? That might be an interesting investigation…
Not a derail, at all. In fact, I anticipated this discussion and thought about initiating it my self. My personal take, after having read much of the "dimple theory", quite some time ago is that IF there would be any advantageous effect to leaving the cloth texture, it would be minimal to non-existent. I've tried to see if I could detect any difference between the performance of my River blade as compared to my Freestyle blade and I cannot detect any, except for some minor, additional turbulence when slicing the River blade. I suspect that is due mostly to it's thicker edges, as compared to my freestyle blade. Both blades are the same size and shape and both paddles are the same length.
In response to several questions about the edging around my river and shallow water special blades, it is Dynel cord, saturated with epoxy. Dynel is commonly sold as a thin cloth but it is also available as "cord". The material that I use is very much like a very heavy shoe lace, approximately 1/2" wide and 1/4 inch thick, prior to being saturated and compressed. Used in this manner it makes for a highly abrasion and impact resistant edge. Application is a bit tricky as it must be uniformly saturated and compressed. Being as thick as it is, it does not saturate easily.IMG_1540 cr en sml Dynel cord.jpgIMG_1543 cr en sml Dynel cord.jpgIMG_1544.JPG
As for the clothespins, they are on the opposite side of the blade as well. Had I taken the photo from a different angle they would have been shown.
Ahh. I misinterpreted the photo. I thought the paddle was flat on the table surface with the clothespins side protruding over the edge. I now can see the entire blade has been elevated off the table surface.
Marc, you have referred to your different paddle models in several posts, and in one picture I see paddles with seemingly different blade shapes hanging by a window. Perhaps at some point you could show us a comparison photo of your shallow water model vs. the others.
Glen,
These are four paddles that are in various stages of completion. From left to right is a
  • Freestyle Blade which is complete and ready for delivery
  • River Blade, sealed and ready for the application of fiberglass
  • Shallow Water Special which has been glassed but not yet varnished
  • Shallow Water Special-Extra Wide--Ultra Light, ready for delivery.
Shallow Water Specials have blades, similar in shape to the Freestyle and River blades but they are approx. 2" shorter. They are generally shipped with shafts that are 2" shorter than that which the paddler generally uses. The combined reduction in blade and shaft length allow paddling in shallow water, without having to hold the grip in an uncomfortably high position.
The Ultra Light blade is primarily paulownia, a very soft, very light weight wood. It reduces the weight, below that of a cedar blade, by a couple of ounces, however it requires some fiberglass layers, laminated into the shaft to maintain adequate stiffness.IMG_1570 cr en sml 4 paddles_freestyle_River_shallow water_shallow water wide blade.jpg
I like that shallow water special. Much as I love my ottertail, there are numerous places I can’t use it here in the Big Bend (FL).
I designed it, for conditions, such as you encounter. The idea came about during a Pine Barrens (NJ) trip, some years ago. Several folks were commenting on the awkwardness of having to hold their grip hands high, to avoid bottoming the blade. One or two on the trip had short beater paddles that they used in the shallows, but they were heavy clunkers. When I got home, I built the 1st Shallow Water Special. I tweaked it a bit before arriving at the current design, which has been quite popular.
Several have messaged me, from this and other forums, about better photos of the freestyle blade that was show in the group of four paddles, earlier in this thread. The freestyle blade has thinner edges and instead of Dynel, the edge is triple laminated hardwood. The tip is a non-Dynel composite. The blade is sheathed in 4 oz fiberglass (as opposed to 6 oz on the river blades) and the weave is filled before varnishing to provide a smooth, glossy or satin surface.
Regarding weight, another common question; All weights are nominal and will vary from paddle to paddle. Of those currently in the shop, The Freestyle blade is 21 oz, the River blade is 23 oz and the Shallow Water Special is 19 oz.
comIMG_1641 cr en sml freestyle_shaft blade intersect_Lee Oconnell.jpgIMG_1632 cr en sml freestyle_grip_Lee Oconnel.jpgIMG_1633 cr en sml freestyle_tip_Lee Oconnel.jpgIMG_1634 cr en sml label_freestyle_Lee Oconnell.jpgIMG_1637 cr en sml freestyle_grip-shaft interface_Lee Oconnell.jpgIMG_1636 cr en sml freestyle_blade-shaft intersect_Lee Oconnell.jpg
I recently came upon a source of recycled, old growth, western red cedar. It's beautiful wood but certainly not clear stock. It takes a lot of planning on how/where to cut/mill, to work around the knots and other defects. Given the scarcity and cost of buying clear stock and the fact that it is a limited resource, it is to me, a worthwhile endeavor. The other day, while milling this wood, I got the idea of building a paddle entirely of recycled/repurposed wood. Over the years, I have accumulated a small stash of such material. It's not finished yet (I'll post more photos as it progresses) but it looks pretty nice, so far. It will be a shallow water special.
The shaft core and the blade are all repurposed, western red cedar.
The tip, grip blocks and grip cheeks are repurposed, hard maple flooring.
The shaft faces are repurposed beech. I don't recall where I acquired that.
The source of the western red cedar is old utility poles. Apparently, back in the day, many of the very large, cross country poles were WRC and they are being replaced with concrete and or steel poles. Once the outer portions of the pole are milled away the "core" is clean, and has been "air dried" for the better part of a hundred years.
This will be a "stock" paddle, as I already have a shallow water special of my own. I don't usually build stock paddles but this seemed like a fun project and I had the time.IMG_1659 cr en sml shallow water spec_recycled.jpg
This will be a "stock" paddle, as I already have a shallow water special of my own. I don't usually build stock paddles but this seemed like a fun project and I had the time.View attachment 151846
Beautifull. Shaft length?
I hope you can do.many more of these .
