• Happy National Apple Day! 🍎
Blue Hole Canoe MSB Royalex Canoe
OK....I have concluded that have a canoe problem, similar by problem with Cross Country skis, and maybe fishing gear, and maybe camping gear.
I purchased a 1981 Blue Hole Canoe which I think is an MSB model. It measures 17 ft 6 inches with a 36-inch beam and weighs around 90 lbs. The outer gunwales are rotted, but the inners are fine. The thwart, handles, and yoke just need sanding and staining/oiled/varnish. The Royalex is sun faded, but it looks like a little elbow grease and rubbing compound should take care of that (see pic below). Some of the foam core is showing on the bow stem, nothing that GFlex and a Kevlar skid plate can't fix. Overall, this is one solid canoe.
It will be interesting to see how this canoe paddles.
Nice find, it looks like it is good shape.
I had an OCA. I don't know if it was factory, but it had oak trim. It might have had oak gunwales. It was a fun and seaworthy, but heavy.
I am sure I can find some spruce at my local specialty lumber supply store. I was thinking ash or maybe cherry, and spruce will be considered. Depends which wood is more workable for the upward bend at the bow. I also have 16 ft Old Town Canadienne that I picked up for $60 that will need the new gunwales as well. I would like to use the same wood if possible. The MSB will be first since this canoe is in such good shape, the Canadienne is ROUGH!
Not MSB. MGB.
In the early 1980s, Blue Hole hired then-famous Tampa canoe designer Mike Galt to design a tandem hull for them. They sold the aluminum trim version as the MGA and the wood trim version as the MGB. The wood trim was frequently ash inwales and mahogany outwales (or vice versa, I forget).
Except: Your hull does not look like a Blue Hole MGB as I recall it. The MGB was a flared hull with forward prow stems. Your stems look more vertical than forward. Does the hull have a serial number?
Yes, TBH09302M81. I think the MGA and MGB are different models from the one that I have. I came across the MSB model designation in my research yesterday, now I cannot find it. I will post the reference if I come across it again.
That HIN won't decode because it's 11 not 12 characters long. (Did you leave out a character?) However, the "TBH" MIC is Blue Hole and the 81 at the end would mean a 1981 model. The only question is what 17+ foot model it is.
I have the 1986 Canoe Magazine buyers guide issue. It lists only two Blue Hole canoes that year over 17 feet with wood trim. The MGB (aka Galt Cruiser) model is 17-6 long, 36 gunwale/32 waterline wide, 23-13-20 deep, with asymmetrical rocker and a shallow V bottom. The Wood Duck 17A model is 17-3 long, 36/34 wide, 23-13-23 deep, with symmetrical rocker and a flat bottom. Both are listed at 78 lbs. I also think I recall at least some MGBs having a sliding bow seat.
Maybe Blue Hole had another 17+ foot model in 1981, but I don't recall an MSB. For tandem canoes, I recall the 15-9 OCA and OCB, which differed only in aluminum vs. wood trim; the 17-6 MGA and MGB, same thing; and the 17-3 Whitewater 17A and Wood Duck 17B, which differed not only in trim but also in depth, the 17A being 25-15-25.
A book on the "whole history" of Blue Hole Canoe was written by the original owner, Bob Lantz, and is available on Amazon:
LEAN DOWNSTREAM !!: THE WHOLE HISTORY From Beginning To End of The Blue Hole Canoe Company
Aha, attached is a PDF file of the entire 1982 Blue Hole catalog. It lists only five models, three being over 17': the MGA, MGB and 17A. No 17B Wood Duck, with shallower depth than the 17A, listed in 1982.
The catalog also clarifies that the MGA had the sliding bow seat, but not the MGB. Also, that the MGB had mahogany outwales, slotted mahogany inwales, and ash thwarts and seat frames.
I did not include the A at the end of the serial number. TBH09302M81A. The canoe is exactly 17 ft 6 inches, weights 90 lbs, beam is 36 inches.
