Impact of Heeling - Canoe Design
Columbia, MD
Curiosity question - everyone knows the advantage of having a boat with a fair amount of uniform rocker for maneuvering in narrow creeks. But heeling should hypothetically lift the stems out of the water a bit - so the question is whether boats designed with a slight amount of differential rocker like the new Cirrus 14.6 from Swift or the Yellowstone Solo from Bell / Redfeather - boats that should hypothetically be a bit less maneuverable / straighter tracking than say a WildFIRE or Dragonfly - have any difference in maneuverability when heeled (and how much heeling is needed to see any real impact anyway)?
As indicated above, it's just a curiosity question - I think it would be fun to try to design a hull that has differential rocker but the sides are intentionally built to maximize free spin when heeled, negating the negative impact the differential rocker would have on maneuverability when paddled without any lean. Of course, I am so ignorant of watercraft design, this may be what has always been done anyway! :ROFLMAO:😂
I've never paddled any of the boats you mentioned or any boat with differential rocker for that matter, but being opinionated I'll offer an opinion.
I like a bow light trim, and with that trim I think I am creating differential rocker. The bow is free to turn, while the deeper stern will help keep your boat on track. When your stern is deeper in the water it acts like a rudder. It can keep you going straight when you're not leaning and it will help you turn towards the side you're leaning to when heeled over. The deeper the stern, the more rudder effect you will get, whether leaned or not. This is what enables me to paddle from the stern seat without getting blown around.
There are reasons for different hull shape designs. I think the ultimate reason, generally speaking, is to get your hull to do a lot of the work for you. In this case it can either help you go straight or help you turn, depending on your lean. I'm thinking that differential rocker will create some of this effect while maintaining a more flat trim.
I think I didn't word my original post well - what I was trying to ask is whether boats like the Cirrus and YS solo would be equally as maneuverable as a WildFIRE when heeled - does the heel remove the straight-tracking enough to make the heeled Cirrus equal in maneuverability to a WildFIRE?
I seem to recall John Winters saying that his asymmetrical canoes tracked best when there was enough weight in the stern to make it squat down a little. I have built and paddled almost all of his designs, and have routinely paddled the Osprey and the Raven heeled, both in tripping and non tripping situations. I haven't paddled the hulls you discuss, but I am going to assume that canoes with similar features will act in similar fashions.
I built the Barracuda, which was a performance type hull with very little rocker. Heeling it would have been a fairly frightening endeavour, although I'm sure there are some paddlers who could do it. I suppose someone who could heel it would notice a difference, but at 17 feet long, and the precarious nature of heeling it, I think the design characteristics would cancel out most of the advantages.
The Osprey was a good all around asymmetrical design with moderate rocker. It turned well, tracked well, did most things one would want of a canoe. I still heeled it on a fairly regular basis, but I'm not sure if it was out of habit or if performance was enhanced. I'm not one of those analytical fellas, I just tend to do what feels right.
The Raven is a highly rockered asymmetrical design, and quite a beast for a solo canoe. It is quite loose in the stays, and responds very well to directional strokes. I usually heeled it on straight stretches, as the hull actually tracked better in that position.
So to try to answer your question....I'm not sure heeling an asymmetrical canoe will provide you with more maneuverability. When I think back, I usually did it on straight stretches for increased tracking ability. I think on tight twisty little streams, paddle technique might be of more importance. Also, trying to reach a neutral balance in an asymmetrical canoe to lift the stern a bit might be more effective than heeling, hence the sliding seat found in some of these canoes.
Not to ignore your Cirrus vs WildFIRE inquiry but, having paddled neither, I'll help kill time until someone knowledgeable strays past...
I have to agree that what mem & al say above makes sense.
I built my Raven with the seat set rearward & contoured all the way to the gunwales so it would just naturally heel the canoe as I moved toward the paddle side. I was really surprised by how easily the hull tracked with single sided correction strokes and it makes sense that it might be the result of a deeper stern and the carving effect that al lauds. (I can easily see how mem paddles it all day without switching sides)
It, likewise, makes sense that seat placement / trim would play more of a role in altering handling characteristics... I'm really hopeful that someone knowledgeable in hydrodynamics or experienced with both hulls can chime in. Otherwise, we may have to get NikonF5user to buy (or, at least, paddle) both to satisfy our curiosity.
I am HUGE fan of the WildFIRE - and would never debate the need to buy one! 😁
I do want to paddle the Cirrus, because why not! Plus it's a Swift and a Yost design, both of which I love. :sneaky:
I have a royalex YS and a composite wildfire. Im comfortable heeling both and do, much of the time. The YS is maneuverable but less so, even when heeled appreciably. This is particularly evident in eddy turns and upstream facing rock garden play.
My main boat is a Swift Kippawa, another Winters design, and has a fair bit of differential rocker, but to be honest leaning it varies little from my old beater Scott Echo, which is symmetrical.The main difference is the wind load, but that could be a factor of the longer hull. the biggest thing I notice is how FAR I can lean the two, the scott doesn't like less than 3-4" of freeboard on the low side, while the kip can be leaned over to the point that wavelets cause it to ship water. the other thing is that the kip can spin on a dime and carve incredibly tight turns when leaned hard where the scott feels more like paddling a bathtub in a lean. both track fairly well leaned...
I don't think that a half inch of rocker difference will affect heeled maneuvers all that much with the Cirrus (2.5/2.0 inches), especially if you pitch the canoe forward a bit to release the stern. I've followed paddlers using a the Bell Yellowstone, with an inch of rocker difference (2.5/1.5 inches), and they were maneuvering through Pine Barrens creeks as well as paddlers with boats with symmetrical rocker. As you mentioned, there's more to maneuverability than just rocker, the overall hull shape affects performance as much or more than rocker alone. So the Cirrus, designed for moving water, should turn well even without nailing it to the rail.
Fun topic. I've owned a composite Yellowstone and Wildfire and agree with kona that the Wildfire is significantly more maneuverable. Yes you can lean a Yellowstone to the rail and spin it like a top but Wildfire will be more stable and spin faster. The Yellowstone did have better cruising efficiency.
On other boats I think it varies. My Merlin II and Keewaydin 15 have identical differential rocker specs and both are 15' but the extra volume of the Kee15 makes it much more maneuverable when leaned where the broad shoulders help lift the ends. Merlin II is no fun to freestyle and not much fun for spontaneous eddy turns but Kee15 is decent...much better.
I think my Swift Osprey (pic) may be my all time favorite solos because at 15' with differential rocker it cruises noticeably better than a WF which I value for upstream paddling yet it's an extremely maneuverable and playful boat that's very close to a WF for forward maneuvers...Osprey has harder chines and less secondary stability so it's happy to let you lean as far as you want any time. For super swift current a Fire boat is hard to beat.
I think the load in the boat can impact the answer too.
tketcham has it right. Heel is one factor but equally important is pitch. Canoes steer, primarily from the stern. Pitching the bow down (by shifting weight forward onto the paddler's knees) lifts (and frees) the stern while pinning the bow. Combined with some heel, almost any hull can be coaxed to turn. A bit of rocker is helpful, mostly in that i makes it easier to pitch the hull. If the combined pitch and heel raise the stern free of the water, asymmetry isn't a huge factor.
Personally, I prefer symmetrical hulls with modest rocker. They are predictable, whether paddling forward or in reverse. A well designed hull will, if paddled correctly, track easily, but will also turn easily with only moderate heel and or pitch.
As to the issue of heeling into (toward) the turn or away from it, the answer is,"it depends". All things being equal, the carving effect gained by heeling away from the turn is an advantage. As mentioned above, heeling away from the paddling side, when traveling straight ahead can reduce the need for corrective (J) strokes. When on a narrow stream, other factors come into play. Most folks feel more stable, heeling into the turn. Heeling to the offside can be unnerving. With practice, it becomes less so. Then there is the "tripping" factor, as in tripping over the paddle if the tip gets caught on the bottom or an obstruction. When heeled into the turn (an axle), if the the paddle tip catches on an underwater gremlin, there's a good chance of launching yourself out of the boat. Having a loos grip hand can minimize that risk. If heeled away from the turn (a post), if the paddle tip grabs on the bottom, more than likely you'll fall back into the boat, perhaps looking a bit clumsy, but none the less dry. Also, looking ahead, at the next twist in the river, what's your next move likely to be? Not having to switch heels, may be an advantage. In tight, twisty streams, such as we find in the NJ Pine Barrens, it helps to be looking two turns ahead, assuming the view is clear that far.
I take it you are asking about heeling from a centralized solo seat. I'll make some points, probably repeating what others have said.
1. Any canoe I've ever paddled will turn better when heeled. Heeling shortens the waterline and can pull the stern stem out of the water. If the stern stem is lifted far enough, there will be a "crack" between the water and the heeled stern stem. Some paddlers talk about "cracking" the stern to make turns.
2. Pitching the bow down will further shorten the waterline and increase the stern crack, thereby enhancing turns.
3. I have had a composite black-gold Bell Wildfire, which has symmetrical rocker, for 16 years and have also paddled the Royalex Bell Yellowstone (initially also called a Wildfire), which has asymmetrical rocker. The composite Wildfire turns somewhat better both unheeled and heeled. For one reason, the stern will crack more with the composite Wildfire's symmetrical rocker. However, the Yellowstone turns sufficiently well for just about any practical need.
4. I've never seen the new Swift Cirrus and haven't yet heard an informed review of it.
5. The turnability of a heeled canoe is also affected by the shape of the sides—how full the sides are, and how the fullness is carried along the length of the sides. I've paddled three canoes that turn significantly better than I expected from looking at their rockerlines, in all cases because of the "pivotability" of their side fullness.
Mike Galt's Lotus Caper, designed in 1982 or so, has almost no rocker. Yet, it can be free-spinned when heeled by a paddler below about 165 pounds. That's because Galt carried side fullness behind the paddling station and pinched the stern cheeks. These factors create a big stern crack when the hull is heeled, and hence easy turnability. Yet the canoe tracks firmly on its negligible rockerline when unheeled.
Nolan Whitesell designed his legendary whitewater canoe, the Piranha, with what he called "pivoting bulges" on the central sides of the canoe. As he put it, "I believe in side rocker." All whitewater canoeists turn soft-chine canoes with heels to the rail, and hence Nolan enhanced turnability with side fullness rather than radical rocker.
Just this past week I paddled a Savage River Illusion, which never appeared to me to be particularly turnable by looking at the rockerline of the hull. I was literally shocked at to how turnable it is, and I attribute some of that to well-placed side fullness, as well as to modest rocker and a short waterline. It has a shorter waterline than a Wildfire, and I now give it the edge over my Wildfire in both turnability and acceleratability. You can see the side fullness of the Illusion in this picture.
6. Tracking straight in any solo touring hull is much more a function of a paddler's stick skills than an a decreased inch of asymmetrical stern rocker. Just as pitching a touring hull forward will enhance turnability by pinning the bow and loosening the stern, you can modestly "skeg" the stern of a solo canoe by trimming it a bit stern heavy via a sliding seat or by putting a gear bag in the stern.
Although I'm not yet a paddler of dedicated solo boats, I've gotten a lot out of this thread. I was surprised that Marc said "canoes steer primarily from the stern". This surprised me because there seems to be so many different ways to turn using freestyle techniques. Since a lot of them involve lifting the stern (cracking) from the water I wouldn't have thought the stern would be so significant in freestyle.
Glenn's line about "skegging" the stern reinforced what I feel when I say I use the hull (stern) as a rudder. The difference in what I'm doing from the stern is that instead of a modest skeg I'm going all in with an extreme skeg. From this position I loose the ability to pin the bow, but find I rarely need to. If I need to turn into a stiff wind I sometimes need to back paddle which will pin the stern. causing the boat to spin into the wind. Water creates more resistance than wind, up to a point. Using that resistance effectively with your hull is a key to paddling efficiency, especially in the wind.
I don't really have much to add to the interesting observations above other than an image from when I was playing around with canoe design. No doubt many canoe designers can tell by eye and experience what shapes will work for what purposes but I did not (and still don't) have that level of experience. I was using multiple pieces of software to design the hulls and one of them allowed me to heel the canoe while observing the water line. It was interesting to see how much heel was required for the stems to break free (or not break free) from the water.
The image below is just a static shot straight on from the bow but when looking at it live I was able to rotate the image any direction I wanted, either horizontally or vertically, to see the canoe from all angles. You can see in this image that even at maximum heel* the stems do not break free from the water.
*I say maximum heel because if heeled any farther the resistance curve goes the wrong way (the canoe will want to tip rather than resisting tipping). But the caveat is that the software cannot account for the paddler leaning or shifting weight**. It assumes a static load at a fixed height no matter how the boat is heeled. Imagine a mannequin firmly strapped to the seat. A paddler, by shifting weight and using a paddle for some bracing effect, can likely heel the boat further.
**Actually, I believe the software can account for this but not "on the fly." I would have to input the specific numbers to reflect the new paddler position. I never got that involved with it to try that out though.
makes me think of the SRT
I can see from Alans photo above why a boat heeled to the right would want to turn to the left with an even keel. There is more under water surface area on the left side of the boat (right side in photo) that would create more drag on that side. This should cause the boat to turn left. This had been a mystery to me, because with a bow light/ stern heavy trim my boats turn towards the side of the lean in a big way. I guess at some point the skeg effect of the stern is greater than the drag from the hull, which would be diminishing as the wetted surface of hull got more narrow towards the end of the boat.
Speaking of hull design, I'm going to mention my Bell Seliga. This boat has a more dramatic difference between being heeled over and no lean at all then any of my other boats. When level it tracks great and with just a slight lean it turns great. The hull has a very large radius in the chine and almost no flat area, which may account for this, it also has amazing secondary stability. It makes me wonder how Joe came up with it without the aid of computers, and I doubt he was able to make many prototypes, if any. Was it luck, or maybe it was figured out before by BN Morris, or the Native designs he may have copied?
Another boat with interesting characteristics pertaining to leaning is my shallow V hull Malicite. This boat feels like it has three different hulls to choose from. One for going straight, and one for carving left and one for carving right.
I hope this isn't too much thread drift from talking mostly about solos.
The Malecite is an interesting sideline to this discussion, since what little rocker it has is in the stern. Unfortunately, it's been a very long time since I last paddled it solo. So I can't say much about that. Paddling it tandem with my wife, it doesn't get leaned much to turn, other than catching an eddy or peeling out - so that doesn't add to the conversation. Paddled flat by us (wife isn't interested in learning paddling skills) all turns are initiated from the stern.
More recently, I have poled it - in reverse. Not because I wanted the rocker ahead of me, but because the solo seat would otherwise be in the way of where I need to stand. In that use, I generally do turns with offside edging. It's much quicker than the other way. I think it has less to do with the stems than the carving effect of the curve of the side of the hull above the chine. It should be noted though that I am usually standing aft of the center and slightly "stern" heavy. The secondary stability of the Malecite is good, but not good enough to inspire me to edge enough to lift the stems clear out of the water - unlike my Coho.
All of my other canoes have symmetrical rocker or no rocker.
Frankly, my perception is that given a high degree of secondary stability, a zero rocker boat (such a my Solo 14) can be made to turn about as well as one of similar size with moderate rocker, if one is willing to put it on edge. And I don't think that necessarily means the stems are out of the water. Just getting the "blade" of the stem closer to parallel with the surface of the water (or for another description - more in line with the desired movement) reduces resistance to turning.
I haven't proven it to myself for lack of a suitable canoe (the subject of this thread), but I suspect that a long solo canoe (15.5' or more) with no rocker in the stern and a little in the front may require less work when fighting heavy wind on flat water than the same length with zero rocker, but maybe not any better than a shorter solo with symmetrical rocker.
Those are my thoughts, based on my limited experience (compared to others here) with various canoes under various conditions. If I ever acquire a fast solo with asymmetrical rocker, I may modify my opinion.
I always thought the Malecite was symmetrical under the waterline with the asymmetry only being the sheer line, but I may be wrong. It is a boat that you need to be concerned with trim and lean, on moving water anyway. Like my other tandems, it solos well from the stern seat, especially with a little weight in it.
As far as asymmetrical rocker, for a solo boat or otherwise, I'm with Marc O and think I'll stick with symmetrical. I can't think of a reason not to.
I thought that too, until I got one. In fact, I remember seeing specs listed somewhere that showed zero bow and 1" stern, and I thought at the time that must be a misprint. But then I observed it on my own two examples. Actually, I think it would be described more accurately as deadrise. All the catalogs I can still see just call it minimal rocker but don't say which end(s).
I prefer symmetrical too, on rivers. But on lakes, I don't really have a preference. Actually getting into something like a Trillium or Magic might change my mind.
