Prospector 15 Third Seat/Width Modification
ABT
Festus, MO
Let me start by saying that I have been nothing but impressed with my Wenonah Prospector 15 since the day I got it. It has been everything I was hoping for - a good river boat, very maneuverable, excellent stability both initially and when heeled to the rails, excellent carrying capacity, etc. It is not fast, but I did not expect it to be.
I have primarily paddled it solo, from the bow seat facing backwards, trimmed with ballast in the other end. It is a bit of a nitpick, but the ballast situation has been somewhat inconvenient, as the placement of the bow seat requires a fair bit of weight for trimming. I have been filling a large dry sack with river water at the put ins, but the bag is heavy and unwieldy when filled with water, and is mildly inconvenient to dry out well when I get home (I usually set it up with a fan blowing on it so it won’t mildew, etc) and have to reposition it a few times over the course of the day to get it fully dry.
I’d like a more elegant solution, almost like a true solo canoe…. However, I really like this boat so I decided to add a third seat. I also figured it’s easy to change it back to stock, minus some new hardware in the gunwales if I didn’t like it.
The main reason I believe people do not do this on the P15 more frequently is that it is a very wide boat. The mfg. stated max width is 37”, although I measured it a little over that. I think plenty of people would prefer the ease of trimming from the center, and the ability to have better control with easier bow reach, but putting a seat in the center on this boat means a pretty far reach to the water that deters most people. I have read that Royalex/T-Formex boats can be narrowed, and thought I’d attempt it while I’m installing the new seat. This made things a little more tricky, and I wanted to do this very cautiously and without changing the performance of the boat too much. More on that in a little bit. Also, again, should be easy to go back to stock if I don’t like it. Due to the width, I went with a Northstar extra wide seat, they say it is reinforced for the wider span. To match I also used their thwarts and changed my handles out while I was at it. I really like their somewhat darker stained ash, and their thwarts are nicer looking. They kinda make the Wenonah yoke/thwarts look pretty clunky in comparison.
So here’s a rough placement “before” shot with the new seat laid over the original setup:
Before going very far I wanted to get an idea of what I was going to affect by narrowing the boat. I put the boat on my utility trailer and leveled the bed with the tongue jack, and a level in multiple places. To get an idea of how much I would affect the rocker, I measured from the trailer tongue to the tip of the stem in the bow, and from the concrete floor to the tip of the stem in the stern. Then, being careful to not move the boat, I removed the yoke and used a ratchet strap to *carefully* bring in the center. We then re-measured.
We found that by bringing the center in 2”, it caused both stems to drop by ~1/2”. This boat has a ton of rocker and maneuverability, so this loss at the stems did not seem to be a deal breaker for me. Additionally, the tumblehome became a little more pronounced as one would expect. Maximum width below the gunwales is hard to measure, and did change a little, but appeared to be less than I expected. The boat also measured slightly deeper according to my father but I did not verify this. I assume the boat is also slightly longer than it was before, but didn’t measure as it wasn’t a big concern of mine.
We left the ratchet strap in place to install both thwarts, and then removed it before installing the seat. Before cutting the thwarts or seat we made blanks/dummy pieces to check the fit and our measurements and I’m glad we did. Matching the taper of the boat on the ends of the pieces was a little more challenging than expected and several of the blanks we cut ended up too short by ~1/4” or so. This also happened when measuring the seat width because the drops place the seat at a different width than up near the gunwales. Using the blanks, we were able to make critical corrections before actually cutting the seat/thwarts. With this method everything came out great in the end with a good fit.
For the seat, I wanted it quite a bit higher than the stock Wenonah seats. I’ve never been able to kneel comfortably in this boat due to how low the seats are and how difficult it is to get my feet under them. I’ve been meaning to raise them, but now with the third seat I definitely wanted the option to kneel more easily. We made a quick and dirty mock up to get an idea of comfortable seat height for kneeling:
We ended up wanting around 9-10” below the seat, which I think is fairly tall, and this worked out to about a 2” drop from below the gunwales. The P15 is a deep boat and this wouldn’t be possible on a lot of shallower boats I believe.
We did run into a little trouble with the very long seat drop bolts as I drilled the holes for a very tight fit. I wanted them to almost thread in the seat for a tighter fit. The drops had a larger pre-drilled hole than I thought they needed, but after trying to align the long bolts they made sense. I ended up drilling the holes in the seats out just a touch so the bolts could pass through easily which helped it all come together better. It’s hard to get perfect alignment when drilling the gunwales, and that long bolt can bind if the other holes are too tight.
Overall I think it turned out well:
The two inches narrower is very noticeable visually. I liked the looks before but this does seem better to me. The distance to the bow seat is really good for me, but someone over 6ft might find it too short and want to move or remove it (or may be able to use the bow seat as a foot brace…). The boat also seems a little rounder in the bottom, which also makes sense. I imagine it will feel a bit tippier due to this coupled with the higher seat, but kneeling easier should offset this somewhat. The boat also had massive initial stability to begin with, so it had some to spare I feel. It may also be a little faster with the more rounded bottom and being narrower, and may track a touch easier with the rocker change, but I’ll have to try it out to know for sure how the performance was really affected. My hope is that the maneuverability is still pretty great. Anecdotally the boat also seems much stiffer than it was before when handling/moving it around, possibly because of the increased arch in the bottom. Maybe it will oilcan less? Sitting in the center of the new seat, it’s still a hair too wide for a good reach, but it’s also not as bad as I feared. I also tend to prefer one sided paddling and heeling the boat over a bit so I’ll probably be more to one side anyway. When offset to one side just a little bit it felt great, but the real test will be in the water. The seat being higher also makes it easier to reach over the gunwale, offsetting the width issue some. Overall I think I’m going to like it this way a lot, but only time on the water will tell. I’m dying to try it out now, but it’ll have to wait until at least next weekend, and some warmer weather would be nice…
What about the portage yoke? Or do you have plan to use the paddles?
Where I’m at portaging is not very common, so the loss of the yoke is not a problem, I’ve never actually used it for portaging to be honest. I usually hold it by the gunwale in the center with the boat on its side to get it from the car to the water or I have someone with me and we use the handles to help each other move the boats. Could always still use a detachable yoke, or a yoke strap, paddles, etc. if needed, although at 62+ lbs it’s definitely better with some help.
I had a chum who successfully did his on a kevlar boat too, I think it is a cool idea. Did you need to adjust the width of the bow or stern seat?
I was worried I would need to but with the amount I moved it, it didn’t turn out to be necessary. They are both tighter than they were, and there isn’t really a gap on the sides where there had been previously, but I didn’t find any undue pressure or signs of them visibly deforming any of the lines of the boat anywhere inside or out so I just left them. They may be part of the reason the boat feels stiffer now as well.
I went through this process with an OT Canadienne. I found a kevlar edition of the smaller boat which is 15'7". I swapped out the tandem seats for a solo seat and changed the thwarts. The standard location for the solo seat is around 11-12 inches behind the center thwart or balance point of the canoe. I made mine about 9 inches because I always paddle with my dog in the bow. The Canadienne had a beam of only 32 inches so it worked great and was very fast. But it was tender. You can heel your boat over a little paddling solo and it will not hurt a thing. Don't get balled up, just try it and see how you like. it.
  • Like
Reactions: ABT
Finally got to go try out the new seat with a short float on Current River. Overall I liked it a lot. The higher seat height is way more comfortable for me. There’s just a lot more I can do with my legs now aside from just straight out in front. Very easy to kneel as well. Also, as it turns out, if I sit just a hair forward on the seat, I can use the bow seat as a foot brace which also significantly added to the comfort. Stability is still really great and I had no issues standing and paddling, etc. however, I can no longer lean it over to the rails comfortably now that I am so much higher. It firms up about 2-3” from the water and I feel that any further and I’d risk counting fish. I do also feel like the oil canning was improved, but this could change on a 95 degree day with the sun beating down on it.
I found paddling/reaching the water to be very reasonable and had no issues keeping a vertical paddle stroke when I wanted to. However, the new set up will take some getting used to in terms of accelerating quickly and dealing with bow movement. This boat had a lot of rocker before, and a strong forward stroke would always move the bow and require correction, and a J stroke on most strokes was common but not a big deal. But I guess previously the extra length in front of me and more weight on the stern helped with tracking more than I thought. Now, trying to pick up speed quickly requires switching sides every stroke for a few strokes until I have enough momentum that a J stroke doesn’t slow me down too much, and the bow movement/swing is much larger so switching sides is almost a necessity. This was definitely not the case before. I found I could also do an aggressive C stroke on the bow and turn it into a J and stay relatively straight while accelerating but this will take some more practice to do smoothly. Needless to say, maneuverability was great and changing direction to avoid obstacles was easily accomplished with very little input. Any loss of rocker was not really noticeable to me (maybe offset by more bow control and better trim). Once under way at a decent speed I do think the boat is a touch faster and cruises a bit easier, although it is by no means a huge difference.
Overall I’m happy with the results. The added comfort, versatility, and maneuverability is well worth any increased difficulty/correction in keeping it going straight when starting from slow/drift speed. This was also a pretty short float of only around 3 hours so i may figure out a better way to deal with the acceleration as I get more seat time.
@ppine and @memaquay , I'm surprised one can do this with kevlar boats without issues. Good to hear, though....
@ABT I appreciate the methodical approach here. I've been toying with doing something similar but wouldn't have thought to so methodically measure the stem heights, rocker, etc.
Re your bow and stern seats, I've noticed a lot of woodwork isn't sealed at the ends because it's trimmed to fit after varnishing. If you have exposed end grain and it's pretty tight against the hull, I'd wonder about water getting into the end grains and not drying out properly, leading to end rot, which seems to be where it usually happens. But perhaps I'm overthinking it, or your seat ends are varnished.
Re the more sensitive bow movements, is it possible it's just because you have less total weight in the boat now that you're not adding a water bag to the bow? Plopping that bag btwn your knees would be an easy test. I'd think the tracking would firm up with more weight?
Finally, not to hijack a great post, but I have to ask - do you pole? I lived along Current River for 4 yrs and one of my great regrets is that I didn't know about poling while I was there - if memory serves it would be a great poling creek. I hear some of the creeks closer to STL like the Meramec can be great for poling too. The Prospector should be a good poling boat, and you could do away with shuttles, which can be really time consuming in the Ozarks as you well know.
This is a good point and I have worried about this too. I would be surprised if the seats were sealed at the ends. I meant to do a better job of sealing the center seat ends before install as well, so at some point I will probably pull all of them and varnish the ends just to be safe.
I think that’s definitely a possibility. I’ve given this a lot of thought since then and towards the end of the day we did move all of our gear into the end of my bow. Just a couple of dry clothes bags so not a ton of weight at all, but it did affect the trim noticeably, I guess because it’s so much better balanced now. I do think it helped tracking a small amount, but definitely not a huge difference. Before this though, apparently my bow stem was completely out of the water. In photos after the bags, the trim is perfect but there is really not much of either stem in the water. I think before the new seat, when I was in the bow seat backwards and the water bag in front there was definitely a lot more of the stern stem in the water and the bow was about how it is now when evenly trimmed. I’m a big dude so I would have thought just myself would be enough weight, but this is a wide boat with a lot of capacity, and I am now thinking based on the photos that more weight near the paddle station to try to get more of both stems submerged may very well make a big difference. Your idea is a good one and I will definitely be trying it out next time I go. Here are some zoomed in pics of the stems after the bags were placed in the bow:
As far as poling, I really have never given it a shot. I can easily stand in the Prospector though, so I should definitely try it. I will probably be on the Meramec and the Big closer to STL a lot more than the Current this year and I agree they would both be good candidates for it. If I give it a go I’ll let you know how it turns out!
Actually I moved the solo seat further from the mid point to account for my canine paddling partner.
