- Joined
- Nov 22, 2021
- Messages
- 384
- Reaction score
- 587
My out of boat method is to sit on a cooler and measure from the top of the cooler to my nose. I then add 3 or four inches to that, plus whatever the blade length is. Obviously, as pointed out by others, the length of the blade matters in what length paddle you order. I have a modified special. I might even have two. I don't remember the blade length so let me run downstairs and take a quick measure. Oh, looks like I must have both a Ray Special and a Modified special. I believe the shorter one is the Modified special and seems to be about 27", the longer one is about 29".I have a paddle sizing question. I am ordering a Fishell Ray's Special, and am not sure whether I should order a 61" or a 64". My torso—top-of-seat to bottom-of-chin—is 27". My current quiver of paddles are a 60" Fishell Modified Ottertail, both a Breaking Branches 54" Expedition Plus and 57" Beavertail. The Modified Ottertail and Beavertail have a 33" and 32" shaft length, which seems to fit well. The Fishell size chart suggests a 61" Special for my height (5'7"), but that's a shaft length of only 30.5". Should I size up to a 64" so that the shaft length is 32"?
The best method is to sit in your loaded canoe and stick a paddle in the water, up to it's throat, and see how high the grip comes. For safety reasons it really shouldn't come higher than the top of your head and I go for about eye level. That's just to get you in the ballpark, not your "perfect" size.
I'd like to buy one of Werner's adjustable paddles and play around with different lengths and see if I end up liking a different length than I've been using.
