- Joined
- Mar 20, 2013
- Messages
- 3,356
- Reaction score
- 988
They work. They're standard practice in Alaska. They'll put out over 5000 volts if you set them up right.
same here in the Yukon, they are more and more used up here!!
I wouldn't want to portage even just the Electra Bear Fence. At 40 Kg it would make for some tough portages.
Keep Your Tinder Dry
Chekmate
If all else fails a suicide bomber vest. It wont protect you, but at least you get the last word.
Your best defense against bears is your brain. Learn their ways, and learn to live with them.
ppine,
You sign off as “Forester.” I’m just wondering if your nickname on this site refers to Ponderosa Pine, or perhaps Pinyon Pine.
I worked in Alaska. We saw bears every day. Look at their body language. Avoid eye contact. Slink away slowly. Leave them an exit. Be on the look out for clacking teeth, growling, huffing and worst of all the bluff charge. Make noise when you travel. Bring a dog as a first line of defense. Carry bear spray. Don't sleep anywhere near food.
Avoid tall grass and areas with limited visibility. Make plenty of noise. Understand when bears are most active, low light conditions and at night. Be careful not to stumble on one sleeping during the day. Make noise and let him know you are coming. Don't sneak around in the woods. When you go ashore get in the habit of looking around for tracks. If you see tracks don't camp there.
Some black bears are predatory, mostly young males. Notice their behavior. Some are hard to get rid of. They leave and come back always on your 6, behind you. Loud noise helps, boat horn, firecrackers or warning shots.
The coastal brownies are huge and territorial, but usual not that aggressive when they are fed on salmon. Watch your step in dense vegetation near streams, like alders.
At first I carried a .44 mag in Alaska. This was before bear spray. After a couple of close encounters I always carried a big bore rifle. I had the safety off a couple of times, but never fired a warning shot. Try to understand how they think.
