- Joined
- Jul 25, 2012
- Messages
- 838
- Reaction score
- 26
Well then Memaquay, how about this; take a wire brush and coarse steel wool and remove all the dirt and red rust scale. Probably need to have a stick of wood to get the steel wool inside the eye. Hot water and soap to help move the crud. One of the reasons you prize it is that it's a neat old axe that you found. Let it stay looking like an old axe, only one that has been taken care of and restored to usefulness.
There is a certain nobility in looking like what you are, what you see is what you get. I would gently grind off that portion of the head that is mushroomed over from hammering and of course dress up the edge where the sharp is.
I'd bet that once it's cleaned and protected with heated bee's wax the natural surface will be nearly black, shinny on the sharp.
If you try what I've described here and don't like it, you haven't lost anything; you can still go the grind and polish route.
eek:
Your friend, Rob
Your friend, Rob
