Rack for a utility trailer.
Just picked up a 5x8 utility trailer. I want to use it to transport canoes, including a 17’ Duck Hunter. I originally thought I would just mount 2x4’s to use as crossbars but I think I want the crossbars to be 2’-3’ above the sides.
The rails are easy to drill so I am looking for a rack that I can bolt on. Looks like there are multiple options if I want to clamp on bars, but I don’t think clamping is an option. Can anyone recommend a particular set of bars that I should look at?
Thank you,
JDG
I built a canoe/box trailer on an old boat trailer frame and extended the corner posts and drilled them for pipes. I have two lengths of pipes for carrying one or two canoes. I started a thread on here somewhere with the whole build. Although it’s not shown in the pics I did build a back door for the box.
before thinking about a rack, place a canoe on the trailer and make sure the tongue is long enough to keep it from hitting your tow vehicle on dips, bumps and turns, then pull it all the way to the side and check again. often utility trailers are to short to legally and safely carry canoes (check your local laws about overhang). Once you've established that it'll actually work, the most common answer is canoe trees made of square 1 1/2 or 2" tubing and/or angle iron welded in the shape of a capitol T or with a second crossbar for more boats. I prefer to have sockets welded to the bottom edge of my trailers and slide- through collars for the top edge, drill a hole through the collar and upright to take a bolt and wingnut to hold them secure
Canoe trailers are way under rated.
I bought a commercially made trailer with an extended tongue to handle an 18 foot OT. Pay attention to the suspension of lack of it. Small wheels and tires are not good on rough dirt roads. My commercial trailer bounced in ways that were hard to imagine.
All of these home made trailers are good. Canoes don't weigh much. They are easy to carry as long as the tongue is long enough.
Benson's method of tie downs is magnificent.
We borrowed a commercially made canoe trailer once that held 8 boats. It was large and stout with 15 inch wheels. It pulled straight and the cross bars slanted towards the inside of the trailer. Everything was padded. We hauled 4 canoes for a long trip to the desert in winter. It would be perfect for a canoe club.
Since most vehicles no longer have rain gutters, modern fancy roof racks are expensive and not that strong. It is easier to haul boats behind your vehicle than being exposed to strong winds on top of your vehicle. I used a canoe trailer for 30 years and feel lost without one.
I am already planning to extend tongue. The trailer has leaf springs for suspension and 20” tires. I'm addition to hailing canoes, I'll be using it to bring firewood downstate from northern MI.
We borrowed a commercially made canoe trailer once that held 8 boats. It was large and stout, with 15-inch wheels. It pulled straight and the cross bars slanted towards the inside of the trailer. Everything was padded. We hauled 4 canoes for a long trip to the desert in winter. It would be perfect for a canoe club.
My DH weights close to 80 lbs and is 37” wide and there is no way that I can get it on top of my 4Runner without help, which is a big motivation for getting a trailer.
careful- if it's capable of hauling firewood, the suspension may be so stiff that it'll pound your boat into dust- you may need to take it to a spring shop to have a leaf removed or softened. A half ton of firewood centered over the axle and 80lbs of canoe hanging 8' out either end of that axle will act wildly different- that firewood will work basically on the axle directly and be enough to compress the springs, while that canoe will supply massive amounts of torque as each end goes up or down while not compressing the springs noticeably, if at all. You might find that for the trailer to be manageable you'll need to keep 6-800 lbs of that wood in there to stop it from bouncing all over the road and creating a real safety hazard
