• Happy National Knife Day!🔪⚔️🗡️
Carbon Fiber paddle repair
Mendota Heights, MN
Added an epoxy "rock guard" to an older carbon fiber paddle my daughter will be using this year. My question is can I roll on a thin coat of epoxy or varnish on the entire blade? In order to flare the rock guard I sanded a little of the finish on the blade as well as scuffs and gouges from prior use.
If it has a coating of varnish, I'd give it a light sanding, and go for it. The worse that could happen, is it might delaminate.
What did you use for rock guard ?
