Canoe protection clear coat/ epoxy
I have a Wenonah Canoe in there flex core lay up and most of the clear coat is gone and starting to look a little thin in spots. Whats the best stuff to apply to seal and add a little protection to the bottom? Also have a royalex lay up thats been through alot, would be nice to apply something on the bottom of that as well. thanks in advance for any advice.
Yellowcard, I don’t know about the “best stuff”. I have refinished the bottom of a couple worn and UV faded TuffWeave canoes, and a couple vintage glass & nylon boats by lightly sanding the bottom, rolling & tipping a coat of epoxy resin, letting that cure for a week or so, wet sanding the bottom and finally rolling & tipping a coat of spar urethane.
The boats came out looking like new, and have held up well over the years.
I suppose that could be cut down to a single step by using an epoxy resin with UV resistance. West 207 hardener has UV inhibitors, but I have never used it for that purpose.
For a Royalex canoe I would not go whole hull hog. If the damage is mostly restricted to the stems I’d add Dynel skid plates, or on a worn vee bottom possibly a full length skid at the apex of the vee, and I’ll be doing that soon to a well work ‘70’s Explorer.
Otherwise I’d scribe a mark near the waterline and paint the bottom with a couple coats of topside paint.
Badly scraped and scarred Explorer with scribe line.
P6130015 by Mike McCrea, on Flickr
New white-on-white bottom.
P6160010 by Mike McCrea, on Flickr
You could use a hull matching topside paint, or go two-tone with a different color.
Thanks for the reply. I was looking at the west system 105/207. Would one quart of 105 and one pint of 207 be enough to cover the bottom of a canoe? or do I need more.
My Royalex canoe has a small 1" crack thru the 1st layer, thinking I could just get a kevlar patch and put down the 105 over it? I'm not concerned about looks, just want a reliable fix.
I'm not a fan of kevlar for patching, just my take on it. I have a variety of different clothes I use. Since it's such a small crack I would be more then happy to send you some Dynel cloth which is my go to stuff for bottom work. Shoot me a PM with your address and I'll have it off in the mail this week!
dougd
A bit off topic but here goes...
Doug's reply is why this forum is so valuable to me. Folks helping folks, sharing advice and offering help where they can. It's a tremendous community of like minded people who will do what they can to keep you on the water. Thanks so much for all your generosity.
FWIW this is a scratched, scraped and scarred glass & nylon bottom after a coat of epoxy, wet sanding, and a coat of spar urethane.
DSCF1720 by Mike McCrea, on Flickr
Held sideway there for some diamond accents over patched and repair hardware holes. That boat, a Phoenix Vagabond, had been out and about on a few trips by then and the bottom refinishing held up fine. Still looks decent 10 years later.
I just paint em.
I use epoxy for repairs and coating wood. Then a couple of coats of high UV resistant varnish.
