The water gods were kind to me today and gave me just enough water for a day trip down the upper reaches of the Gila river between the cliff dwellings visitor center and grapevine campground. Gauge reading for this stretch was reading 50 cfs and after scouting what little I could from the road I decided it looked good enough to try. I had a blast but I certainly wouldn't want to paddle it with less water than this. It was a fun to paddle in a completely different ecosystem and topography than I'm used it. The section was plenty of fun with lots of riffles and small rapids. The low water made it difficult to pick a clean line and it was rare that I could bury the paddle for a full stroke at any point.
I stashed a bicycle in the willows at the grapevine campground so I could get back to the car. It's a 4.5 mile ride.
It's not much of a stream at the put-in and I was a little nervous about how many obstructions there may be downstream. And if the river should widen much from this narrow channel I would surely run out of water.
I put on the water at 1:30 and estimated it should take about 2 hours if it went smoothly. But with it getting dark at 5:00 and having forgotten to bring the headlamp and tail lamp for my bike I was a little concerned about it taking too long.
The small riffles came at a rapid pace and it was fun picking lines through them. I haven't been on any sort of moving water, other than flat water rivers, in years. It didn't take too long until I reached one that didn't have enough water to make it down so I was forced to walk this one
And not too much longer after that I came across a tree that was blocking the entire river. Thankfully it was just a short carry around it.
And even more thankfully this turned out to be the last major obstacle of the paddle. Every other obstacle I was able to paddle around and I managed, sometimes just barely, to find a way through all the rapids and riffles without having to get out and drag.
The scenery was great. So much different than I'm used to seeing from a canoe.
I really enjoyed the sections where the cliffs came right down to the water. There were also sections where the valley widened out into more of a typical riparian area with cottonwoods and willows.
As I continued downstream the flow gradually picked up. Deeper water was usually a bit easier to find and the riffles started turning into actual rapids now and again. I sure nothing would be rated more than a C1 and only a handful of those. Most were very easy and straightforward but some of them did require aggressive moves at the end. It was pretty common for there to be a sharp angle at the bottom of a rapid with the water pushing straight into a cliff or debris, requiring a quick turn in limited space.
My initial time estimate was right on and it took almost exactly 2 hours to run this section. I didn't rush but I also didn't lollygag because I was worried about it taking longer than expected.
I'd love to run this at higher flows and hopefully spend a few days running the long wilderness section below this as well.
