• 2026-29 Fund Drive needs only 6 MORE DONATIONS to reach target. Read the Featured Thread for details. Please donate!!!
A "Grand Illusion"?
I am now questioning my assumption that a Grand Illusion would have more initial stability than the Illusion.
Marc doesn't list any waterline beams, I frankly never understood how that could be measured, and I never trusted those measurements much anyway. Plopping your own body and gear in a canoe is the only real way to measure stability empirically.
However, theoretically, I was assuming a slightly wider Grand Illusion canoe would be somewhat more initially stable than its smaller Illusion clone.
But there is a counter-argument. While an Illusion may have a narrower waterline beam than a Grand Illusion when floating empty, the Illusion also has less volume. Therefore, for the same paddler/gear load weight, the Illusion will be pushed further down into the water. Given that these canoes are bubble-sided, an Illusion with a 200 lb. load may push down to a wider waterline beam than the Grand Illusion with the same load. Therefore, the loaded Illusion may buoy on a wider and more stable waterline beam than a similarly loaded Grand Illusion (but with less freeboard).
My countervailing theories confuse me.
Marc can provide empirical evidence because the Illusion is a larger clone of the June Bug. So, Marc, what is your empirical sense of the stability profiles of the Illusion vs. June Bug with the same load? Door A or Door B?
The beginning of your post had me concerned. I thought we were heading down the road of formulas and naval engineering etc. Thank goodness you were only theorizing. I love theoretical discussions because they are open ended and lead on to expressions of opinion and more theories. In this case, you conveniently provided a countervailing theory.
As to my empirical evidence: The Illusion has significantly more initial stability. I feel comfortable sitting upright in the Illusion, while having my lunch or simply stretching my legs. I'm never quite as comfortable doing so in the June Bug. I don't think twice about taking expensive camera equipment with me in the Illusion. I generally leave it home when paddling the June Bug. Given this empirical data, a Grand Illusion should exhibit greater initial stability.
Now back to theory, MY theory: Until the load in the canoe is such that it's draft reaches its maximum hull width, the hull behaves as if it were flared; stiffening -gaining stability - as it heels. Once the load is increased, such that the draft exceeds the maximum hull width, that theoretical flare ends and thus the gains in stability. (I hope I've articulated that in a reasonably coherent fashion.) Thus, according to my theory, the Grand Illusion, with its greater volume and maximum hull width should exhibit greater initial stability.
