• Happy National Apple Day! 🍎
Headlamps
Sweeper's thread here (it's all his fault) gave me a serious case of GAS pains.
http://www.canoetripping.net/forums/forum/gear/miscellaneous/892-gear-acquisition-syndrome
So naturally I turned to the dependable home remedy for the gear challenged tripper. No, not a mustard poultice, and definitely not booze; not this time. No, I shopped.
Although we've never suffered equipment failure due to the elements I thought it might be prudent to hedge my bets and opt for a headlamp model with a high IPX rating. The Black Diamond Ion has a rating of 8, and without too many doodads to complicate matters for when I send my missus out into the northern slashing rain and howling winds to check on what went bump/growl in the night, I can sleep easy knowing her headlamp won't fail her. And if she runs into trouble, I was thoughtful enough to buy two; I'll keep a spare in a tent pocket for her just in case it'll take her two trips to sort things out.
https://www.mec.ca/en/product/5050-384/Ion-Headlamp
This is only one of the many piece I've bought this winter. I've had some serious GAS Pains, out with the old in with the new and shop till it hurts. When you can't paddle, buy.
I use the cheap energizer 3aaa headlamps. I'm afraid I will lose anything smaller and more expensive. I have a pile of them, one in each car, each pack, in my everyday bag. As for a mini lantern, I've had good luck with UCO's mini led lantern. It also uses 3aaa batteries.
Jason
The Lucis require being out of the pack or closet to recharge. We have three,, and they need to be tied down..When one blows off a chickee you can see it but getting to it is another matter.
Mine sit on the south facing window sill next the solar flashlights. They don't like the cold either.
Thank you. Keep it up because that's my source of headlamps. I found a nice Petzl at a campsite a couple of years ago.
The one thing we've never done is leave equipment behind. Even when we stop on a Carry for lunch or the last person sweeping the carry, once everything is up, the area is swept for anything that's not naturally supposed to be there. So I'm not going to buy something because I'm afraid I'll lose it.
We've dropped a couple cameras in the water, but that doesn't stop me from carrying a good one.
I tend to lose them (and other stuff) around the house, rather than on a trip. Someday I'm going to find a portal to a secret room with all the gear, tools, clothing, and other things that have disappeared from inside my house!
My take on outdoor illumination, "go big or go home!"
This is a 7800 (tested) lumen 12 XP-G led headlamp powered by three high amp Li-ion batteries. (3 of these will jump start your car)
Set on high, it's unsafe in non-expert hands*. On low Moonlight mode it's soft, gentle, lovely light @ 68 lumens.
After we are done pissing off the nearby neighbors with the outrageous bright light and things things get boring around the fire, we can - crisp up bacon, reheat bannock, heat up the gravy for biscuits, etc.
* a concentrated beam is said capable of incinerating Coleman gas lamps at nearly 100 yards. Fight fire with more firepower?!
...and meanwhile back in camp southcove (alias Cyclops of the X-men) cooks his breakfast merely by looking at it.
"How crispy do you want your bacon? Eggs over easy? "
I like the looks of that. Pocketably small, singe headband-style strap, waterproof (except battery compartment???), two AAA’s, basic functions without too many doo-dads.
I/we don’t really need another flashlight. It might make a good birthday gift for wife or sons, and if I like it buy another.
Must. Resist. Urges.
Especially since I swore off Black Diamond products after my last (replacement) purchase.
Black Diamond battery op lantern. I bought it because I read in the tent for an hour or more every evening. The Black Diamond was spec’ed to run for 70 hours (on low). Hot dang, that should get me through a long trip on one set of batteries.
I never got more than 5 or 6 hours out of it.
I figured it must be defective, and returned it to REI for a replacement.
Brought the new seemingly identical Black Diamond lantern home, took it out of the blister pack and dang near broke it just putting the batteries in. Really flimsy construction on the replacement lantern, same 6 hour run time.
No more Black Diamond stuff for me.
Still, I’d like to have a look at that Black Diamond Ion. Or maybe a feel.
If it is packaged in a blister pack, so I can’t fondle it, check the headband comfort, open the battery compartment, have a feel for the on/off switching protection, maybe not.
I am sure that blister packs are useful for protecting products in shipping and are easy to display, with info & specs on the packaging, but it can be a crapshoot of construction quality under the plastic bubble.
Shopping for my headlamps wasn't easy. For me shopping never is.
I had a conversation with myself standing in front of a wall of headlamps "Mike doesn't like those, but what about these?"
But let's not get ahead of ourselves, let's go back to the beginning.
In the beginning, God created the heavens and the earth...
And God said "Let there be light", and there was light.
God saw that the light was good...
and then Brad promptly lost that light somewhere amongst basement clutter and junk. But yes, it was a good one.
So Brad checked out the selection of headlamps online.
After much perusing and procrastinating (which pretty much describes my shopping "strategy"), I decided on two models. Neither of which I bought, naturally, because I had a last minute conversation with myself standing in front of the...you know.
I clicked and flicked, poked and prodded, and eventually fell for the simplistic charms of the BD Ion.
Then I got it home and only then remembered what Mike said about the battery compartment. There was a moment when the companionable devil on my left shoulder dressed in red work coveralls said "Use a feckin tool to pry that sonoffabitch battery compartment open!!" while the impracticably white dressed prima donna on my right shoulder said "Shoulda listened to Mike." Awww fff. I put the bread knife down and tried one last time to gingerly pry open the tight plastic itty bitty door...and it popped open. Let's hope the batteries last a long time. The unit seems solid and easy to operate. I showed my wife, and like always with any new thing I buy, she was unimpressed. "Where's the other headlamp? I liked that one. It was a good one"
Ohh ffffff sometimes ya can't win.
blister packs are a contraption of the devil.. For sure you have to use your pocket knife in an awkward way and try not to decapitate the purchase ...and instructions if there are any..
Lets have a talk about instructions that don't come with the package.. Visit www.youwannaknowhowtoturniton.com
Like with any other sort of tech product where the users might be a bit more demanding, discerning of their new toy - lots of manufacturers in the marketplace have no knowledge of what they are selling or why their in house buyer picked that one, or that one, or... they just want to leverage their good name with 'their own products' .
Even Beans has some really questionable products; I returned a headlamp and a camp latern this past year that were newish to their outdoor catalog, relative garbage, old school in output, smoothness of beam, garbage nasty blue tint. Disappointing.
I would recommend picking a few online and then heading to a brick and mortar store to check out the design aspects important to you.
