Rain & Sweat in the 21st Century
SW OH - Land of Opaque Water
I trip to the clothing donation bin made me painfully aware that no one has made the perfect raincoat. In this day and age, you’d think a little thing like rain would fall to mankind’s technological bullet train. Nope, you’re either going to sweat or get soaked.
Not that I haven’t spent enough. I’ve owned paunchos, waxed cotton slickers, Goretex jackets, several membrane knockoffs, portable sweat lodge vinyl fabrics, and single-layer miracle fabrics that aren’t so miraculous. Wife and I were both soaked in our expensive single layer coats on vacation. I just ordered the wife a Patagonia Torrentshell 3L, which is highly rated (if that means anything). Her Marmot jacket is barely an impediment after a few minutes.
I’m going to spray something on my older Cabelas Goretex hunting jacket, as it’s about the best I’ve found for activity in the rain, although it eventually soaks through, has no pit zips.
I regret disposing of my old riding slicker. It was very dry but smelled like horse sweat and didn’t have a hood. You can bet if there was rain in outer space NASA would have developed something stupendous by now.
It keeps a difficult one. And there is not one answer to all wet problems. HIgh active/heart rate movements require something differne compared to low heartrate stuff. Solid water that most here like to stay on top is another challenge. Temperature is another. I think i have 8 shells I when paddling. Halve of them are not waterproof by any means.
kokatat drysuit
peak uk ocean boothy
fjallraven ecoshell cag
sandiline cag
some cotton weave thing that should become waterproodf when wet
patagonia nano puff
flanel cotton shirt
light weight upf 50 protection shirt
depening on temp /what kind of water /enviroment. how long is the paddle/with who/weatherforecast and i guess 10 more maybe less obvious reasons i pick one. (and in most times a spare).
obvious question is do i stay dry? IN most occassions yes.
next question is : is it comfortable ? IN more then in the previous question
Have i been wet end misserable (yes in a few occassions)
HAve i had hypothermia (yes and i think i have had hypothemia and been missearlbe . but also in hypothemaria and in good spirits. Those are the scary ones. is it just mild hypothemaia sn spirits good because it was nice to be outside playing with water cuurents and friends .
or was is one sted further and in good spirits because i had lack of judgement. I guess in a few years body core temperature meters are widely availeble to monitor this.
I see cattle or horses standing out in the rain and am envious. Maybe we could figure out a way to use their hides as rain gear? Probably not as light as Dyneema.
No shortage of leather jackets out there.
I think we would be better off to copy their ability to endure without complaint.
Yeah, having spent many years working outside in the weather, I still have not found a fool proof way to stay dry. The key word seems to be "working". It's pretty easy to stay dry if no work is being performed. So if I have a choice, I either don't do anything physical that will generate heat and sweat, or I stay inside - or at least under cover.
A few things have worked fairly well...or at least help. People often say Goretex doesn't work, but it does if it's maintained and not overwhelmed by heat/sweat or immersion. I can sit or stand in the rain, covered in Gtex, and stay dry so long as I don't move much. That includes not letting any rain invade through collar or cuff. Cuffs must be almost dry-suit snug. Hood, if relied on, must be generous. I don't like hoods though because they restrict visibility and hearing. So it must be a good hat. The best rain hat design has been with us for a couple centuries, at least. I have a lightweight Sou'wester that goes on every trip, and it allows no rain in my collar. Yes, it is Gtex lined.
As long as I keep efffort low, Gtex works pretty well. I also found a low tech solution, which I came into back in my motorcycle days - waxed cotton. I put untold miles on the Barbour Suit, comfortably dry in downpours. I even wore that gear at work, but found it lacking (as is everything) when working up a sweat or doing anything that required reaching overhead.
Feet are a problem. Waterproof shoes don't stay waterproof for long. If any kind of shoe or booty is worn with the dry suit, moisture can't escape. My feet sweat easily but don't tend to get cold, so I just ignore that. I'll even sometimes just wear sandals in the rain.
If on a river with good flow, staying dry in the rain hasn't been a problem. Lakes and portages while making good time..... I'm just gonna get wet. As long as I have good base layer, a windproof shell, and a dry change of clothes for camp, I'm okay with that.
Modern materials can be breathable and waterproof, they just can't be breathable and waterproof at the same time. That $900 Arc'trryx will breath OK when the relative humidity is low and it's not raining, but no material known to man can transport sweat and vapor away from our bodies when the air outside is already near saturation.
The only thing that can help when you are active is a lot of ventilation. I use an Outdoor Research Foray jacket because it has large pit zips that go all the way to the bottom of the jacket, so you can basically unzip the sides altogether for maximum ventilation.
If it rains hard Helly Hansens. Or Goretex. That is what I learned in Alaska. For lighter rain and intermittent rain Filson waxed cotton. For rain near freezing wool Filsons. Sure they cost a lot. but they are worth it.
If you are paddling and portaging, you are working and generating heat. The moisture has nowhere to go.
I agree that modern materials have improved but have not solved this problem. I hate getting wet from the inside. I would rather get a little wet from the outside.
I tried everything in Alaska with 150 inches of rain. We had to work pretty hard and it was always wet. We waded rivers. When the rain stopped the brush was wet. I wore a union suit of wool even in July and August. Filson tin pants and Filson tin cruiser, sometimes Filson wool cruiser.
For paddling, sometimes you need a dry suit or a farmer John wetsuit. A paddling jacket can add a lot of warmth. But I did not like sweating in those contraptions. For salmon and steelhead fishing insulated neoprene waders.
I've never had good luck with Gortex and wouldn't put any faith in other "breathable waterproof" products either. If I want to stay dry I use PVC coated rangear, the type worn by professional fisherman and construction workers. There are two keys to staying dry from the inside. One is to dress down at least one layer then what you think you might need to prevent overheating. The other thing is to maintain airflow through the sleeves and pant legs. You want straight legs and sleeves without any elastic to tighten them at the cuffs. You want to buy them on the roomy side, even if you have to cut down the pants and sleeves. When I cut down the pants I cut them short, (like over the ankle) to maximize airflow. This works well paired with knee high rubber boots. I only use bib style pants because a tight waist restricts airflow.You may also get by without having to button up the jacket, especially if you're leaned over paddling.
My goal is not to stay 100% dry. For the sake of maintaining airflow I'm willing to get a little wet through the sleeves or jacket front. My goal is to stay what I call, "Comfortably Damp." I only take the rain jacket in the summer and leave the pants home, but I bring a large contractor size garbage bag to drape over my legs when I'm in the boat, or I can wear it as a skirt on a portage. The PVC stuff is heavy and bulky, but if you need to stay dry it's what I trust.
The last couple years I've been taking a Frog Tog rain jacket. It's lighter and not as stiff as the PVC coated stuff. I would have recommended it but I haven't had to test it in a heavy rain yet.
I have a hat with a four inch brim which keeps water off the head. I have some kind of sealed hunting jacket. Which has a hood if needed and covers my butt. What I like best is my riding rain skirt. It lets lots of air in - its basically a wrap skirt and you can tie as tight or loose as you like. The back is longer than the front, so when paddling it forms a cover between you and your gear.
I have to go along with lowangle al with his choose of rain gear. I have tried many other rain suits but the old PVC suits I used while working in construction seems to work best for me.
I'm with you there, I could have bought a new boat (or at least a good used one) for the amount I've spent on raingear over the years from the old knee length rubberized "slickers" to modern triple laminate space age synthetics, but nothing has compared to my old bibs with the bottom elastic cut out (learned from a real Newfie fisherman) and a Viking commercial fisherman's jacket, for one the jacket has NO elastic and relies on velcro backed up with buckles, and waterproof zips- does it keep the weather out? Heck YES, but does it breathe well? Heck NO... BUT it has enough openings and zips to keep the worst sweat and condensation at bay while still blocking wind and rain, a pair of merino long johns (and sometimes nothing else) is enough to stay comfortable in all weather, even below freezing...
Idunno. I tried the rain slicker route when working on the rails, and it was pretty much useless. Water running into the arms with every overhead reach. Restricted movement that interfered with work. And the sweat....
That Barbour Suit was much better.
Hmmm. Might have to reconsider that kilt.
An ankle length kilt.
