• Happy Birthday, Meriwether Lewis (1774-1809)!🧭🗺️🏕🏞️
Finally got a solo
Maybe try swamping it in shallow water and see if it floats or sinks? If it sinks, you could consider carrying float bags like whitewater canoeists do.
That was my thought. If I had to guess, I'd say the canoe will be somewhat neutral buoyancy (won't sink but will "float" pretty much at the surface). It's pretty easy to determine by swamping it in shallow water and never a bad idea to tip a new canoe to find out exactly where the secondary stability ends.
I will probably use a ridge rest style pad for my Sylvania trip since I already have it and don't have time to buy, test and install pads. I was originally thinking about a removable pad but the glue in sounded easier for portages. I will see how i like using the removable one during my UP trip. The large northstar pad i used when I tested a couple boats was really nice.
I will be doing my first paddle up at my uncle's pond where I store my camper and other stuff like paddles and pfd.
Plan to test it's limits and see how it floats next weekend before I head to the UP for 3.5 weeks of camping. I will send some pics if i remember to take any.
Went to rei yesterday and bought some actual tie downs instead of ratchet straps to haul it, some good rope and lashing straps. Got some bungee and toggles also and made some of those bungee loop things. Getting excited to try the boat out. Need to get some tubing like gumpus showed me to put over gunnels while hauling also.
All the thwarts and seat are attached to small AL angle that is riveted under the gunwale. Wondering if for grab handles I can remove a pop rivet, cut handle to fit tight and just run a stainless screw through the rivet hole to install or if i need to add more angle brackets?
All the thwarts and seat are attached to small AL angle that is riveted under gunnel rail. Wondering if for grab handles I can remove a pop rivet, cut handle to fit tight and just run a stainless screw through the rivet hole to install or if i need to add more angle brackets?
I went back at looked at your pics a little closer. It appears your gunnels are Wenonah type, to which all thwarts and carry handles consist of tubular aluminum, bent at the ends and riveted to the gunnels, seats hung from angles sandwiched between the gunnel and hull. The person who retrofitted the Indy must have chosen to attach wood thwarts to small angles riveted to the gunnels. It might have been cleaner to maintain consistent hardware and go with aluminum thwarts and handles, but no worries.
I have seen folks do as you propose by running a wood screw through the gunnel into carry handles, not my favorite method, but it works.
Lastly, the Independence has MR's classic shallow v hull, with 2 1/2 inches of symmetrical rocker that begins near center (pic below for effect); it feels very different than most other canoes. It takes some getting used to, but if you give it time, I think you will come to lover her. SAM_0470b.JPG
I could be looking for another 3 years if I keep waiting for the perfect boat and perfect deal.
True canoe words.
Wise choice to buy the Independence now. It's been a popular flatwater and mild whitewater canoe for decades. It will take you a while to get used to its handling characteristics, and a lot longer to perfect single-sided solo correction stroke technique if that is new to you. Lessons would accelerate your learning curve. Consider these teaching symposia.
I've cut my own kneeling pads from both inexpensive 3/8" sleeping pad Ensolite and from 1/2" neoprene, and contact cemented them in. More recently, I've been using a removable rectangular pad in various canoes, which I bought from here. The removable pad is a bit more of a hassle to affix for portaging, but it has other uses such as a cushioned lunch seat and tent doormat.
So far it paddles really nice, feels stable. Cane seat ripped out on the second test paddle unfortunately. First time i got in from the dock, second was wet foot entry and must have just gotten one cheek on the seat at first. Will have to fix that before my trip next Wednesday. Really flies with my big double end canoe paddle. Tracks well with a single too. Pond is only 1/4 acre so not a ton of room to play but enough.
Over many years, I've come to dislike cane seats muchly, though they are traditional on wood/canvas canoes. As they age, they sag when wet, which means you end up sitting on the uncomfortable seat frame, and ultimately they always tear. I much prefer polypropylene or polyester web seats or the Nova Craft bootlace seats.
I just expect those cane seats to rip the first time out when I get an aged canoe, and I'm not disappointed. On several of them, I cut the cane away, gave the frame a couple coats of spar varnish, and did a Belgian chair weave with dacron cord. On the Moccasin, I just took it as an excuse to buy a contoured (yes, webbed) seat.
The seat pretty much fell apart when I started putting webbing on. I screwed it together with some 3" deck screws since I don't have many tools or materials here at camp. Hopefully it will hold for my trip. I will just order a new seat but just didn't have time between work and getting everything ready before we have to leave. Feels pretty comfortable so just a matter of how long it will last. I think I can have a new seat shipped to the county post office near the campground or maybe to the ranger station, will have to ask when I get up there. If it lasts through my 4 day trip at sylvania wilderness I will be happy.
The seat worked well, the sleeping pad as a kneeling pad did not. It slides around too much. I will probably order an actually non-slip kneeling pad to try.
