• Happy Disobedience Day! 🙈👎🏼🙅🏼‍♀️🚫🪧
US and CA approve "Level 50" PFDs: What they are
"The U.S. Coast Guard and Transport Canada are wagering they can change bad safety habits and dangerous figures with the recent approval of a new class of PFD called Level 50."
"Level 50 jackets are performance-rated personal flotation devices that provide at least 50 newtons of buoyancy, which is around 11 pounds of flotation. For comparison, most recreational PFDs for adults are currently rated at 70 newtons or around 16 pounds worth of flotation."
"And now the rankings are standardized from a minimum newton performance to a high end in the order of: Level 50, 70, 100, 150, 275."
"While Level 50 aids were approved as acceptable flotation by the U.S. Coast Guard back in 2025, no products have been manufactured or tested yet for approval in the U.S. or Canada. However, there are Level 50 PFDs in production by brands including Mustang Survival, allowing U.S. paddlers to catch a glimpse of what these buoyancy aids look like in use."
More details and explanations, with references to the older Type I-V ratings, and recommendations as to who should wear a Level 50, are in this article:
Interesting - I had looked at some 50N PFDs from Europe recently - had caught my eye due to the light weight (under one pound).
Likely not the right PFD for any moving water, but perhaps for those of us into traveling light on flatwater....
A few years ago I was looking at pfds and found a couple of 50 N, but they weren’t really for paddling. More like big heavy things to float an unconscious person, as I recall.
The type 50N is not a high flotation vest - you might be thinking about a type5 rescue vest. The 50N is a low flotation vest with only 11lb of buoyancy instead of the Type3 16lb of buoyancy that most of us use. From my point of view, it is an attempt to get ignorant people to wear a PFD and I doubt that it will make any difference at all. If someone won't wear a decent type3, they're not going to wear a type50.
We've all done it, advising those beginners you happen to paddle past that they should wear their PFD only to get a major stink-eye reply. Anymore, if I say anything at all, I just tell them that their body will be easier to locate if they wear a PFD.
Indeed. Low buoyancy.
The ones I was looking at were all slimmer-fit lightweight/minimalist vests for racers.
...their body will be easier to locate if they wear a PFD
That's typically when I wear one. If I think there's a high(er) likelihood that conditions might be lethal.
I'm absolutely sure that the addition of level 50 vests are designed to encourage use. Personally, I'd be more inclined if the state didn't order me to do it and peer pressure didn't attempt to shame me into compliance. (I don't encourage anyone to go without or get down on them for wearing one... )
Personally, I'd like to know that I tried to get the guy wobbling about in the coleman to put on a pfd when I read the accident report a few days later.
I don't think we have to read between the lines to guess this is aimed at SUP paddlers and river tubers. It's rare to see any of them wearing any kind of flotation. I don't expect this to change anything for the vast majority. They'll still buy a cheapo level 70 and bungie it to the deck or sit on it.
I'm pretty PFD compliant, but I don't wear one on a paddle board. I am attached to the board with a leash. I consider the board to be my PFD.
I always wear a pfd on a paddle board. I don't use them very often and I'm apt to fall in.
I don't really have much interest in this new pdf style. I can see the use, but I'm fine with the one I have.
Do you use a leash? If not, you would certainly need a PFD.
I do use the leash, and I never really thought about the fact that I'm connected to a large inflatable PFD. I don't use the paddle board that often and I haven't gotten to the point that I'm comfortable with it. So I wear a life vest, but that's just my personal preference.
I'm thinking more about this level 50 pdf thing, and I'm now wondering if there is some circumstance I might use it. I'm planning a river paddle next Wednesday, and it's going to be brutally hot. We'll start early and I'll start with the life vest, but I'm certain it will get uncomfortably hot to wear it at some point. Perhaps a familiar and easy paddle in hot temperatures would be a reason to consider something like this.
I only get on the board when it's warm enough to swim and I plan on getting wet. I guess I figure that if I wouldn't wear a pfd swimming why would I wear one on the board. Plus I started SUP in Hawaii where no-one wears one, and that's offshore in the ocean and in the surf.
That makes sense.
The SUP users around my area are diverse. There's the river boarders who all tend to wear PFD and no leash (once they get clued in), there's the flat water fitness paddlers who wear leash and no PFD. Neither of those groups are the target as far as I can tell. It's the SUP yoga group and the posers that are probably in most need of flotation and least likely to wear. I don't see that changing. What is unclear to me though is how much they're represented in drowning numbers.
Still what I see most in the news is people falling in from shore and out of boats when fishing. It's not always reported, but reading between the lines suggests that alcohol is often involved.
If I don't feel like wearing my usual PFD, I wear an inflatable.
That sounds like a fantastic place to learn SUP.
That sounds like a good option, I'll be looking into that.
It's nice on a hot day when odds of swimming are low but consequences are high. The thing is, how does one know it's going to work as needed unless you test it? Then you have to re-arm it. Besides that, I also blow it up manually to inspect before using. It's not something I use a lot, for several reasons - but I like to have that option.
Just a word of warning- in Canada, as in many jurisdictions, An inflatable must be worn, even if inflated "at all times while engaged in water activities" -after activation, the inflatable must be tested and recharged to be considered a legal PFD.
A buddy narrowly missed a nasty fine on a trip after accidentally triggering it, only because his paddling partner had a old spare PFD in the canoe that he used as a sit pad and pillow...
from Canboat-"An enforcement officer will only recognize an inflatable PFD of any kind if you are wearing it while on deck. If you are not wearing the inflatable PFD then you could be subject to a fine of over $250."
also they're illegal for whitewater use or by anyone under 16
