• Happy National Beer Lovers Day! 🍺
Is it time for skid plates (see pics)?
From my research, it sounds like skid plates are a hot topic. Some advicate for them, and it sounds like other believe they do not belong on boats. Given the pics below, do you believe it time? It does not appear to be in the foam. DO you think I could get away with one of the peel and sticks like EZkeel?
How long did it take for it to accumulate that much wear? It certainly doesn't look very deep or severe. If this happened over the course of years then something like EZKeel should be plenty. If it happened in 2 weeks you might want something a bit more robust.
That "damage" is very minimal, in my opinion it's just a tiny bit past the optimum time to apply skids.
EZ-Keel would work but real skids using Dynel will last a lot longer and provide protection from both scraping and impacts.
There are lots of old threads here in the archives with techniques and tricks to make them long lasting and less sloppy.
Unsure. I just bought the boat and I wasnt the one who caused the damage.
However, I can say I plan to run the boat in remote rivers. Often times they are rocky. So it will likely see some abuse.
How to make the EZ-Keel long lasting and less sloppy, or one of the more durable option?
The more durable options:
one last chip.....I assume a small chip like this we just feather/soften the edges, fill with epoxy, and blend smooth?
Hard to tell from the pic how deep that is but regardless I would fill with epoxy and then cover with a small patch of s-glass or dynel. I have a few similar "chips", if I just fill with epoxy it tends to need a refill fairly quickly if it's going to be getting the rough treatment (scraping/grinding on rocks).
I guess I would approach it this way:
If you think working with epoxy and composites for canoe repair sounds like fun then go ahead and give it a try with some skid plates.
If you think that doesn't sound something to do just for funsies then slap on the EZ-Keel strips and see how long they hold up. If they wear out quickly then you know what you need to do. If they last a long time then it was a win.
I've advocated against skid plates until the canoe actually needs them.
Yes.
Alan's dual approach makes sense to me, as epoxying composite fabrics has never been enjoyable to me.
Since I've never before heard of the product being discussed, properly named KeelEazy, I assume some other readers never have either. Here's a video of the KeelEazy canoe kit:
I went with the PereGuard. I'll prep the hell out of it (including light sanding for better adhesion) , but if it doesn't last, I'll you all know and brake out the epoxy.
Thought I would add this question to an existing thread rather than start a new - I am soon to get a Royalex solo boat that has a skid plate on one end (on the stern only). Do any of you see any logic in adding a plate to the other? What I would really like to do is remove the one skid and see what is beneath, but I know that's much easier said than done...
Personally, I wouldn't be adding one to the bow until you've got enough wear that you actually need it but I wouldn't be spending time trying to remove the one that's already on there. Just paddle the crap out of it and see if you can wear through it.
That'll let you see what's under it and it's more fun than scraping, sanding & sweating. (OK, maybe you sweat either way... still... see above)
