Quiet Blade Shape
The shown area causes turbulence on the surface. The BB paddle is much quieter (also much heavier).
Tony, that part of a Zav where the shaft transitions into the blade is sort of fat, and it's always been unclear to me whether I should consider it part of the shaft or blade. I don't need to sneak up in perfect silence very often, but if that bent Zav were my only paddle, I would simply not bury that fat transitional area in the water. If I had my straight Zav, I would palm roll it and do a full in-water slice return without burying that fat transition area.
You haven't commented on the palm rolling suggestions, which makes me suspect you don't palm roll. In my experience, most flatwater paddlers with straight paddles don't palm roll simply because they haven't been exposed to it. I didn't start using it regularly until 2009 when I was about 64 and Marc Orstein urged it upon me. I knew how to do it, but didn't use it in whitewater at all, where it's not really apt, and I didn't use it with any regularity in flatwater because I had mainly been using bent shaft paddles in flatwater since 1984. Even my "straight" flatwater paddle for 25 years was actually an asymmetrical 2.5° Lutra S curve blade, which is not really amenable to palm rolls.
If you have a straight, symmetrical-faced paddle, try teaching yourself palm rolls for the Indian and box strokes. They are not only quiet, but fun, and a nice change of pace from the J and other correction strokes.
I have no evidence of any damage on tip or edges after more than 20 years
I was referring to the side of the blade - as you say the spline in the bottom should prevent damage to the tip. I was surmising about the edge but haven't actually had it happen in 3 yrs. Very glad to hear you never had an edge chip either, and over a much longer period.
I do palm roll with a straight shaft. Back in the day when I bowhunted, I did so mostlyin a medium sized river where current was brisk. I used whatever paddle and don’t remember being concerned wih more than crossing the stream and not missing my takeout on the other side. That area’s an outdoor mall on one side, the reserve on the other. Saddens me to think about it. Most of my sneaking since has been for photography. This was taken in an eddy on the Totogatic with my phone. Swirling my paddle in the current did the trick getting close. Straight shaft, not still water where actial strokes were involved. Seems like an abbreviated beavertail would be useful for stalking in marshy areas or windless, low current conditions.DSCN0643.jpeg
Ottertail. The narrow tip enters quietly, the power comes on gradually. Quietest paddle I've ever used
How deep must the water be to use that style paddle? I suppose one could partially dip the blade if not too awkward.
I do remember seeing a short beavertail at canoecopia. Badger paddles. Might check the Bongo paddle for backwaters around here. Hard to do downriver trips in ohio. Outfitters don’t shuttle anymore. Self shuttling is such a pain.
My custom carved (by me:) ) ottertail has 30" below the beginning of the throat. 22" of that are from the widest point down. I only use it in deep water.
Took the girl out to play hide and seek with blue herons and one bald eagle. The herons make a blood curdling noise when surprised on the perch. We got pretty close to a couple just lightly swaying with the bending branches explorer. It is quieter on the stroke, but like swinging a sledgehammer.
I took the opportunity to purchase a badger tripper (modified ottertail) to help with my shoulder and hand issues. Got the sassafras wood for light weight. Looked at this paddle at Canoecopia 2 years ago and can’t wait to get it wet.
I think long, narrow blades, like Otter tails, tend to be quieter that short, wide blades.
Beyond that, I think technique has more to do with it. I used to be a lot noisier than I am now because I didn't plant my blade before pulling back. I imagine a sharp edge helps too.
With a double blade, I've found that the reinforcing spine, on the back of most blades, causes a plunk sound when it enters the water.
More expensive paddles, with a foam core and a smooth back, are quieter.
IME, you are correct.
